caRepeater is not running only if I use pure Java. If on the contrary I set org.csstudio.platform.libs.epics/use_pure_java=false, then caRepeater launches right after I connect to a PV.
Guys, is it OK to use the pure_java Channel Access??
On Tue, Jan 24, 2012 at 9:47 AM, Pavel Masloff <[email protected]> wrote:
Hello to all CSS users!
I am wondering can CSS work without EPICS base? I reckon the only trouble could be is the carepeater program that searches for the remote IOC's beacons. Does this mean I should install EPICS base on each computer client in order to use CSS on these clients? If so, can I just copy the EPICS base (for a specific platform) directory and assign the environmental variables (easy solution)? Or I must compile base using make (which is tedious)?
Another thing I've noticed - I have got base installed, but I can't see carepeater.exe in the task manager. Even when I'm running an IOC. I've read somewhere that one should either manually start it or automatically on boot. How would you recommend me to do it (both on linux and windows)?
Thank you very much.
-- Sincerely,
Pavel Maslov, MS Controls Engineer at Pulsed power Lab Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
-- Best regards,
- Re: [CSS] work without EPICS base ? Kasemir, Kay
- [CSS] work without EPICS base ? Pavel Masloff
[CSS] 'Epics' menu in Preferences disappeared!!! Pavel Masloff
Re: [CSS] 'Epics' menu in Preferences disappeared!!! Kasemir, Kay
<2012>
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
