Thanks Dirk. I will try it tomorrow. And thanks for the clarification on
interaction between StreamDevice and Asyn.
--- Rod.
Dirk Zimoch wrote:
Rod,
I tried to fix the drvLinuxGpib.c. Please try. I cannot test it here.
Dirk
Dirk Zimoch wrote:
Hi Rod,
Not specifying any terminator means: Do not touch the terminator
settings. That means use whatever is specified by asynDriver with
asynOctetSetInputEos and asynOctetSetOutputEos in the startup script.
If neither is used, the default is empty string for both. Setting the
terminator to "" or any other string overwrites the asynDriver setting.
I had a look at drvLinuxGpib.c and found:
* It never sets eomReason. Thus StreamDevice (or any other asynUser)
has no chance to find EOI.
* Under some circumstances it sets EOS to '\0' instead of nothing.
Dirk
- Reading scope waveforms with StreamDevice + asyn Rod Nussbaumer
- Re: Reading scope waveforms with StreamDevice + asyn Dirk Zimoch
- Re: Reading scope waveforms with StreamDevice + asyn Rod Nussbaumer
Re: porting strategy from IDL Paul Sichta
Re: Strategies for working with fast-changing large arrays Matt Newville
<2012>
Rec Proc Monitor for mbbi ZRST Peters, Charles C.
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
