1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Reading scope waveforms with StreamDevice + asyn
To: Rod Nussbaumer <[email protected]>
Cc: epics Techtalk <[email protected]>
Date: Mon, 16 Jan 2012 13:46:07 +0100
Rod,
I tried to fix the drvLinuxGpib.c. Please try. I cannot test it here.
Dirk
Dirk Zimoch wrote:
Hi Rod,
Not specifying any terminator means: Do not touch the terminator settings. That means use whatever is specified by asynDriver with asynOctetSetInputEos and asynOctetSetOutputEos in the startup script. If neither is used, the default is empty string for both. Setting the terminator to "" or any other string overwrites the asynDriver setting.
I had a look at drvLinuxGpib.c and found:
* It never sets eomReason. Thus StreamDevice (or any other asynUser) has no chance to find EOI.
* Under some circumstances it sets EOS to '\0' instead of nothing.
Dirk
/* drvLinuxGpib.c */
* Copyright (c) 2004 by Danfysik and Cosylab (Danfysik has funded the work
* performed by Cosylab).
* linux-gpib port driver is distributed subject to a Software License Agreement
* found in file LICENSE that is included with this distribution.
/* Author: Gasper Jansa, Cosylab */
/* date:  18AUG2006
   date:  19OCT2006 - changed get/set options to check the option key and value
   date:  07APR2008 - added support for secondary address, address 30 bugfix
   date:  20JUN2008 - modified time of start of the poll_worker thread - after iocInit*/
#include <signal.h>
#include <errno.h>
#include <osiUnistd.h>
#include <stdlib.h>
#include <stddef.h>
#include <string.h>
#include <stdio.h>
#include <string.h>
#include <epicsTypes.h>
#include <epicsEvent.h>
#include <epicsThread.h>
#include <epicsInterrupt.h>
#include <iocsh.h>
#include <callback.h>
#include <cantProceed.h>
#include <epicsTime.h>
#include <devLib.h>
#include <taskwd.h>
#include <initHooks.h>
#include <gpib/ib.h>
#include <epicsExport.h>
#include "asynDriver.h"
#include "asynOctet.h"
#include "asynOption.h"
#include "asynGpibDriver.h"
#define DEBUG 0
typedef struct GpibBoardPvt {
    char *portName;
    void  *asynGpibPvt;
    int ud;
    int uddev[31][31];
    int ibsta;
    int iberr;
    int sad;
    int boardIndex;
    int timeout;
    epicsBoolean srqEnabled;
    CALLBACK    callback;
    epicsBoolean srqHappened;
    pid_t worker_pid;
    asynInterface option;
}GpibBoardPvt;
GpibBoardPvt *pGlobalGpibBoardPvt;
static void report(void *pdrvPvt,FILE *fd,int details);
static asynStatus connect(void *pdrvPvt,asynUser *pasynUser);
static asynStatus disconnect(void *pdrvPvt,asynUser *pasynUser);
/*asynOctet methods */
static asynStatus gpibRead(void *pdrvPvt,asynUser *pasynUser,char
*data,int maxchars,int *nbytesTransfered,int *eomReason);
static asynStatus gpibWrite(void *pdrvPvt,asynUser *pasynUser,
                    const char *data,int numchars,int *nbytesTransfered);
static asynStatus gpibFlush(void *pdrvPvt,asynUser *pasynUser);
static asynStatus setEos(void *pdrvPvt,asynUser *pasynUser,const char *eos,int eoslen);
static asynStatus getEos(void *pdrvPvt,asynUser *pasynUser,
    char *eos, int eossize, int *eoslen);
/*asynGpib methods*/
static asynStatus addressedCmd (void *pdrvPvt,asynUser *pasynUser,
    const char *data, int length);
static asynStatus universalCmd (void *pdrvPvt, asynUser *pasynUser, int cmd);
static asynStatus ifc (void *pdrvPvt,asynUser *pasynUser);
static asynStatus ren (void *pdrvPvt,asynUser *pasynUser, int onOff);
static asynStatus srqStatus (void *pdrvPvt,int *isSet);
static asynStatus srqEnable (void *pdrvPvt, int onOff);
static asynStatus serialPollBegin (void *pdrvPvt);
static asynStatus serialPoll (void *pdrvPvt, int addr, double timeout,int *status);
static asynStatus serialPollEnd (void *pdrvPvt);
/*local methods*/
static asynStatus checkError(void *pdrvPvt,asynUser *pasynUser,int addr);
unsigned int sec_to_timeout( double sec );
/*interrupt handlers*/
static void srqCallback(CALLBACK *pcallback);
/*EPICSTHREADFUNC poll_worker(GpibBoardPvt *pGpibBoardPvt);*/
void getAddr(int addr,int *primAddr,int *secAddr);
static asynGpibPort GpibBoardDriver = {
    report,
    connect,
    disconnect,
    gpibRead,
    gpibWrite,
    gpibFlush,
    setEos,
    getEos,
    addressedCmd,
    universalCmd,
    ifc,
    ren,
    srqStatus,
    srqEnable,
    serialPollBegin,
    serialPoll,
    serialPollEnd
static asynStatus gpibPortSetPortOptions(void *pdrvPvt,asynUser *pasynUser,
		const char *key, const char *val);
static asynStatus gpibPortGetPortOptions(void *pdrvPvt,asynUser *pasynUser,
		    const char *key, char *val, int sizeval);
static asynOption GpibBoardOption = {
      gpibPortSetPortOptions,
volatile int work;
void signal_handler(int signum){
	if(signum==SIGUSR1)
		work=0;
static void poll_worker(GpibBoardPvt *pGpibBoardPvt)
       	/*mask for srq bit*/
       	int mask=SRQI;
	struct sigaction new_action,old_action;
	work = 1;
	new_action.sa_handler=signal_handler;
	sigemptyset(&new_action.sa_mask);
	new_action.sa_flags=0;
	pGpibBoardPvt->worker_pid=getpid();
	sigaction(SIGUSR1,&new_action,&old_action);
	while(work){
	       	ibwait(pGpibBoardPvt->ud,mask);
		callbackRequest(&pGpibBoardPvt->callback);
		epicsThreadSleep(0.001);
/* poll_worker is started after iocInit finishes */
void poll_worker_starter(initHookState state)
	if(state == initHookAtEnd)
		/*create thread only if not yet created*/
		if((!epicsThreadGetId("PollThread")))
			epicsThreadCreate("PollThread", epicsThreadPriorityMedium,
				epicsThreadGetStackSize(epicsThreadStackSmall),
                       	        (EPICSTHREADFUNC)poll_worker,pGlobalGpibBoardPvt);
	GpibBoardPvt *pGpibBoardPvt = (GpibBoardPvt *)pdrvPvt;
	if(DEBUG) printf("drvGpibBoard:report!!\n");
	fprintf(fd,"GpibBoard port %s, boardIndex %d,timeout %d.\n",
				   pGpibBoardPvt->portName,pGpibBoardPvt->boardIndex,pGpibBoardPvt->timeout);
	int addr = 0;
	int primaryAddr = 0;
	int secondaryAddr = 0;
	asynStatus status;
	if(DEBUG) printf("drvGpibBoard:connect!!\n");
	status = pasynManager->getAddr(pasynUser,&addr);
	if(status!=asynSuccess) return status;
	asynPrint(pasynUser, ASYN_TRACE_FLOW,
			        "%s addr %d connect\n",pGpibBoardPvt->portName,addr);
	if(DEBUG) printf("ADDR: %d\n", addr);
	 if(addr==-1){
		 pGpibBoardPvt->ud=ibfind(pGpibBoardPvt->portName);
		 if(DEBUG) printf("DESCRIPTOR: %d\n",pGpibBoardPvt->ud);
	         if(pGpibBoardPvt->ud<0){
			status=checkError(pdrvPvt,pasynUser,addr);
        	        if(status!=asynSuccess)return status;
		/*disable autopolling*/
		ibconfig(pGpibBoardPvt->ud,IbcAUTOPOLL,0);
		/*set general timeout for board*/
       		ibtmo(pGpibBoardPvt->ud,pGpibBoardPvt->timeout);
	else{
		getAddr(addr,&primaryAddr,&secondaryAddr);
		/*third argument:secondary address,last two arguments are:set EOI line and set eos*/
		if((primaryAddr>=0 && primaryAddr<=30) && (secondaryAddr>=0 && secondaryAddr<=30)){
			pGpibBoardPvt->uddev[primaryAddr][secondaryAddr]=ibdev(pGpibBoardPvt->boardIndex,primaryAddr,secondaryAddr + 96,pGpibBoardPvt->timeout,1,0);
			if(DEBUG) printf("DESCRIPTOR: %d\n",pGpibBoardPvt->uddev[primaryAddr][secondaryAddr]);
			if(pGpibBoardPvt->uddev[primaryAddr][secondaryAddr]<0){
		else{
			asynPrint(pasynUser,ASYN_TRACE_ERROR,
				           "%s addr %d connect illegal primary or secondary address (primary:%d,secondary %d)\n",
					              pGpibBoardPvt->portName,addr,primaryAddr,secondaryAddr);
			return asynError;
	pasynManager->exceptionConnect(pasynUser);
 	return asynSuccess;
	int addr=0;
	int secondaryAddr = 0;	;
	asynStatus status;
	if(DEBUG) printf("drvGpibBoard:disconnect!!\n");
			        "%s addr %d disconnect\n",pGpibBoardPvt->portName,addr);
	/*disconnect device or board*/
	if(addr==-1){
		ibonl(pGpibBoardPvt->ud,0);
	 	/*destroy poll_worker*/
	 	kill(pGpibBoardPvt->worker_pid,SIGUSR1);
	else{
		ibonl(pGpibBoardPvt->uddev[primaryAddr][secondaryAddr],0);
	pasynManager->exceptionDisconnect(pasynUser);
	return asynSuccess;
	int option,value;
        int addr=0,j=0;
	char cset[] = "1234567890ABCDEFabcdefxX";
        asynStatus status;
	int parseStatus;
	if(DEBUG) printf("drvGpibBoard:gpibPortSetPortOptions!!\n");
	asynPrint(pasynUser,ASYN_TRACE_FLOW,"%s gpibPortSetPortOptions\n",
	j = strspn (key,cset);
	if((*key != '0') || ((*(key+1) != 'x') && (*(key+1) != 'X')) || ( j != strlen(key))){
				           "%s addr %d gpibPortSetPortOptions illegal option: %s\n",
					              pGpibBoardPvt->portName,addr,key);
		return asynError;
	parseStatus = sscanf(key,"%x",&option);
	if(parseStatus != 1){
		return asynError;
	parseStatus = sscanf(val,"%d",&value);
				           "%s addr %d gpibPortSetPortOptions illegal option value: %s\n",
					              pGpibBoardPvt->portName,addr,val);
		return asynError;
	if(DEBUG) printf("option %d set with value %d\n",option,value);
	if(addr==-1){
		ibconfig(pGpibBoardPvt->ud,option,value);
	else{
		ibconfig(pGpibBoardPvt->uddev[primaryAddr][secondaryAddr],option,value);
 	return asynSuccess;
	int value,option;
	int addr=0,j=0;
	asynStatus status;
	int parseStatus = 0;
	if(DEBUG) printf("drvGpibBoard:gpibPortGetPortOptions!!\n");
	asynPrint(pasynUser,ASYN_TRACE_FLOW,"%s gpibPortGetPortOptions\n",
			        *pGpibBoardPvt->portName);
				           "%s addr %d gpibPortGetPortOptions illegal option: %s\n",
		return asynError;
	parseStatus=sscanf(key,"%x",&option);
		return asynError;
	if(addr==-1){
		ibask(pGpibBoardPvt->ud,option,&value);
	else{
		ibask(pGpibBoardPvt->uddev[primaryAddr][secondaryAddr],option,&value);
	sprintf(val,"%d",value);
	if(DEBUG) printf("option %d get with value %d\n",option,value);
 	return asynSuccess;
 	int addr=0;
        asynStatus status=asynSuccess;
        double timeout = pasynUser->timeout;
        int ibsta;
	if(DEBUG) printf("drvGpibBoard:gpibRead!!\n");
	epicsThreadSleep(epicsThreadSleepQuantum());
	asynPrint(pasynUser,ASYN_TRACE_FLOW,"%s addr %d gpibRead\n",
	/*set timeout*/
	ibtmo(pGpibBoardPvt->uddev[primaryAddr][secondaryAddr],sec_to_timeout(timeout));
	/*read data*/
	ibsta = ibrd(pGpibBoardPvt->uddev[primaryAddr][secondaryAddr],data,maxchars);
	/*ibcnt holds number of bytes transfered*/
	*nbytesTransfered=ibcnt;
	if (eomReason != NULL)
            *eomReason = 0;
            if (ibsta & END) *eomReason = ASYN_EOM_END;
            if (ibcnt == maxchars) *eomReason = ASYN_EOM_CNT;
	if(status!=asynSuccess){
		epicsSnprintf(pasynUser->errorMessage,pasynUser->errorMessageSize,
				            "%s readGpib failed %s\n",pGpibBoardPvt->portName,gpib_error_string(pGpibBoardPvt->iberr));
		return status;
	asynPrintIO(pasynUser,ASYN_TRACEIO_DRIVER,data,ibcnt,"%s addr %d gpibPortRead\n",pGpibBoardPvt->portName,addr);
	/*if last response is shorter than previous*/
	if(ibcnt<maxchars) data[ibcnt] = 0;
        if(DEBUG) printf("DATA READ: %s\n",data);
	return status;
	int addr=0;
	if(DEBUG){
		printf("drvGpibBoard:gpibWrite!!\n");
		printf("WRITING STRING: %s \n",data);
	asynPrint(pasynUser,ASYN_TRACE_FLOW,"%s addr %d gpibWrite nchar %d\n",
			        pGpibBoardPvt->portName,addr,numchars);
        /*set timeout*/
	/*write data*/
	ibwrt(pGpibBoardPvt->uddev[primaryAddr][secondaryAddr],data,numchars);
	            "%s writeGpib failed %s\n",pGpibBoardPvt->portName,gpib_error_string(pGpibBoardPvt->iberr));
	            return status;
			        data,ibcnt,"%s addr %d gpibPortWrite\n",pGpibBoardPvt->portName,addr);
	return status;
	if(DEBUG)
		printf("drvGpibBoard:gpibFlush!!\n");
	/*nothing to do*/
	return asynSuccess;
	int addr = 0;
        asynStatus status;
	if(DEBUG) printf("drvGpibBoard:setEos!!\n");
			        "%s addr %d setEos eoslen %d\n",pGpibBoardPvt->portName,addr,eoslen);
	if(eoslen>1 || eoslen<0){
				           "%s addr %d gpibBoard:setEos illegal eoslen %d\n",
	         return asynError;
	if(eoslen==1){
                ibconfig(pGpibBoardPvt->uddev[primaryAddr][secondaryAddr],IbcEOScmp,1);
		ibconfig(pGpibBoardPvt->uddev[primaryAddr][secondaryAddr],IbcEOSchar,*eos);
		ibconfig(pGpibBoardPvt->uddev[primaryAddr][secondaryAddr],IbcEOSrd,1);
		if(DEBUG)
			printf("Seting EOS: %u\n",*eos);
	else{
		pGpibBoardPvt->ibsta=ibconfig(pGpibBoardPvt->uddev[primaryAddr][secondaryAddr],IbcEOSrd,0);
		if(DEBUG) printf("Disabling EOS\n");
	return asynSuccess;
	int addr = 0;
	asynStatus status;
	int ieos;
	             "%s addr %d gpibPortGetEos\n",pGpibBoardPvt->portName,addr);
	if(DEBUG) printf("drvGpibBoard:getEos!!\n");
	if(eossize<1) {
		            "%s addr %d getEos eossize %d too small\n",
		                pGpibBoardPvt->portName,eossize);
		*eoslen = 0;
		return asynError;
	ibask(pGpibBoardPvt->uddev[primaryAddr][secondaryAddr],IbaEOSrd,&ieos);
	if(ieos==0){
		*eoslen = 0;
		if(DEBUG) printf("EOS disabled\n");
	else {
		*eoslen = 1;
		ibask(pGpibBoardPvt->uddev[primaryAddr][secondaryAddr],IbaEOSchar,&ieos);
		if(DEBUG) printf("EOS: %d\n",ieos);
		eos[0]=ieos;
	return asynSuccess;
	int addr = 0;
	asynStatus status;
	if(DEBUG) printf("drvGpibBoard:addressedCmd!!\n");
	asynPrint(pasynUser,ASYN_TRACE_FLOW,"%s addr %d addressedCmd nchar %d\n",
			         pGpibBoardPvt->portName,addr,length);
        /*set timeout*/
	if(DEBUG) printf("DATA: %s\n", data);
 	Send(pGpibBoardPvt->ud,MakeAddr(primaryAddr,secondaryAddr),data,strlen(data),1);
        return asynSuccess;
static asynStatus universalCmd(void *pdrvPvt, asynUser *pasynUser, int cmd)
	int addr=0;
	asynStatus status;
	char chcmd[20];
	asynPrint(pasynUser,ASYN_TRACE_FLOW,"%s universalCmd %2.2x\n",
			        pGpibBoardPvt->portName,cmd);
	if(DEBUG){
		printf("drvGpibBoard:universalCmd!!\n");
		printf("CMD integer: %d\n",cmd);
	sprintf(chcmd,"\\%x",cmd);
	if(DEBUG)printf("CMD string: %s\n",chcmd);
	ibcmd(pGpibBoardPvt->ud,chcmd,strlen(chcmd));
	return asynSuccess;
static asynStatus ifc(void *pdrvPvt,asynUser *pasynUser)
	int addr=0;
	asynStatus status;
	if(DEBUG)printf("drvGpibBoard:ifc!!\n");
			        "%s ifc\n",pGpibBoardPvt->portName);
	ibsic(pGpibBoardPvt->ud);
	return asynSuccess;
static asynStatus ren(void *pdrvPvt,asynUser *pasynUser, int onOff)
	int addr=0;
	asynStatus status;
	if(DEBUG)printf("drvGpibBoard:ren!!\n");
			        "%s ren %s\n",pGpibBoardPvt->portName,(onOff ? "On" : "Off"));
	ibsre(pGpibBoardPvt->ud,onOff);
	return asynSuccess;
	if(DEBUG)printf("drvGpibBoard:srqStatus!!\n");
	*isSet=pGpibBoardPvt->srqHappened;
	pGpibBoardPvt->srqHappened = epicsFalse;
	return asynSuccess;
	if(DEBUG)printf("drvGpibBoard:srqEnable\n");
	pGpibBoardPvt->srqEnabled = (onOff ? epicsTrue : epicsFalse);
	return  asynSuccess;
	/*not used*/
	return asynSuccess;
static asynStatus serialPoll (void *pdrvPvt, int addr, double timeout,int *statusByte)
        char serialPollByte = 0;
	int ibsta;
	if(DEBUG){
		printf("drvGpibBoard:serialPoll!!\n");
        	printf("ADDR: %d\n",addr);
		printf("uddev: %d\n",pGpibBoardPvt->uddev[primaryAddr][secondaryAddr]);
        /*set timeout*/
        ibsta=ibtmo(pGpibBoardPvt->uddev[primaryAddr][secondaryAddr],sec_to_timeout(timeout));
	if(ibsta&TIMO)
		return asynTimeout;
	if(ibsta&ERR)
		return asynError;
	/*serial poll*/
	ibsta=ibrsp(pGpibBoardPvt->uddev[primaryAddr][secondaryAddr],&serialPollByte);
	if(ibsta&TIMO)
		return asynTimeout;
	if(ibsta&ERR)
		return asynError;
	*statusByte = (int)serialPollByte;
	return asynSuccess;
	/*not used*/
	return asynSuccess;
         pGpibBoardPvt->ibsta=ThreadIbsta();
         pGpibBoardPvt->iberr=ThreadIberr();
	 if(DEBUG){
	 	printf("drvGpibBoard:checkIberr\n");
	 	printf("ibsta: %d\n",pGpibBoardPvt->ibsta);
		if(pGpibBoardPvt->ibsta & DCAS)
			printf("IBSTA bit 0\n");
		if(pGpibBoardPvt->ibsta & DTAS)
			printf("IBSTA bit 1\n");
                if(pGpibBoardPvt->ibsta & LACS)
                        printf("IBSTA bit 2\n");
                if(pGpibBoardPvt->ibsta & TACS)
                        printf("IBSTA bit 3\n");
                if(pGpibBoardPvt->ibsta & ATN)
                        printf("IBSTA bit 4\n");
                if(pGpibBoardPvt->ibsta & CIC)
                        printf("IBSTA bit 5\n");
                if(pGpibBoardPvt->ibsta & REM)
                        printf("IBSTA bit 6\n");
                if(pGpibBoardPvt->ibsta & LOK)
                        printf("IBSTA bit 7\n");
                if(pGpibBoardPvt->ibsta & CMPL)
                	printf("IBSTA bit 8\n");
		if(pGpibBoardPvt->ibsta & EVENT)
			printf("IBSTA bit 9\n");
		if(pGpibBoardPvt->ibsta & SPOLL)
			printf("IBSTA bit 10\n");
		if(pGpibBoardPvt->ibsta & RQS)
		        printf("IBSTA bit 11\n");
		if(pGpibBoardPvt->ibsta & SRQI)
		        printf("IBSTA bit 12\n");
		if(pGpibBoardPvt->ibsta & END)
		        printf("IBSTA bit 13\n");
		if(pGpibBoardPvt->ibsta & TIMO)
		        printf("IBSTA bit 14\n");
		if(pGpibBoardPvt->ibsta & ERR)
		        printf("IBSTA bit 15\n");
	 	printf("iberr: %d\n",pGpibBoardPvt->iberr);
	 if(pGpibBoardPvt->ibsta & TIMO){
	         asynPrint(pasynUser,ASYN_TRACE_ERROR,"%s addr %d : device timed out.\n",pGpibBoardPvt->portName,addr);
		 return asynTimeout;
	 if(pGpibBoardPvt->ibsta & ERR){
		 asynPrint(pasynUser,ASYN_TRACE_ERROR,"%s addr %d : %s.\n",pGpibBoardPvt->portName,addr,gpib_error_string(pGpibBoardPvt->iberr));
		return asynError;
	return asynSuccess;
       if( sec <= 0 ) return TNONE;
       else if( sec <= .00001 ) return T10us;
       else if( sec <= .00003 ) return T30us;
       else if( sec <= .0001 ) return T100us;
       else if( sec <= .0003 ) return T300us;
       else if( sec <= .001 ) return T1ms;
       else if( sec <= .003 ) return T3ms;
       else if( sec <= .01 ) return T10ms;
       else if( sec <= .03 ) return T30ms;
       else if( sec <= .1 ) return T100ms;
       else if( sec <= .3 ) return T300ms;
       else if( sec <= 1 ) return T1s;
       else if( sec <= 3 ) return T3s;
       else if( sec <= 10 ) return T10s;
       else if( sec <= 30 ) return T30s;
       else if( sec <= 100 ) return T100s;
       else if( sec <= 300 ) return T300s;
       else if( sec <= 1000 ) return T1000s;
       return TNONE;
	GpibBoardPvt *pGpibBoardPvt;
	callbackGetUser(pGpibBoardPvt,pcallback);
	if(!pGpibBoardPvt->srqEnabled) return;
	pGpibBoardPvt->srqHappened = epicsTrue;
	pasynGpib->srqHappened(pGpibBoardPvt->asynGpibPvt);
	if(addr < 100){
		*primAddr = addr;
		return;
	*primAddr = addr/100;
	*secAddr = addr%100;
	return;
int GpibBoardDriverConfig(char *name,int autoConnect,int boardIndex,double timeout,int priority)
    int size;
    asynStatus status;
    if(DEBUG) printf("GpibBoardDriverConfig\n");
    size=sizeof(GpibBoardPvt)+strlen(name)+1;
    pGpibBoardPvt=callocMustSucceed(size,sizeof(char),"GpibBoardDriverConfig");
    pGpibBoardPvt->portName =(char *) (pGpibBoardPvt+1);
    strcpy(pGpibBoardPvt->portName,name);
    pGpibBoardPvt->boardIndex=boardIndex;
    pGpibBoardPvt->timeout=sec_to_timeout(timeout);
    callbackSetCallback(srqCallback,&pGpibBoardPvt->callback);
    callbackSetUser(pGpibBoardPvt,&pGpibBoardPvt->callback);
    pGpibBoardPvt->asynGpibPvt =
    pasynGpib->registerPort(pGpibBoardPvt->portName,
       ASYN_MULTIDEVICE|ASYN_CANBLOCK,autoConnect,&GpibBoardDriver,pGpibBoardPvt,priority,0);
    pGpibBoardPvt->option.interfaceType=asynOptionType;
    pGpibBoardPvt->option.pinterface=(void *) &GpibBoardOption;
    pGpibBoardPvt->option.drvPvt= pGpibBoardPvt;
    status = pasynManager->registerInterface(pGpibBoardPvt->portName,&pGpibBoardPvt->option);
    if(status==asynError){
	    errlogPrintf("GpibBoardDriverConfig: Can't register option.\n");
	    return -1;
    pGlobalGpibBoardPvt = pGpibBoardPvt;
    /*register for init */
    initHookRegister(poll_worker_starter);
    return 0;
/*register GpibBoardDriverConfig*/
static const iocshArg GpibBoardDriverConfigArg0 =
    { "portName", iocshArgString };
static const iocshArg GpibBoardDriverConfigArg1 =
    { "autoConnect", iocshArgInt };
static const iocshArg GpibBoardDriverConfigArg2 =
    { "boardIndex", iocshArgInt };
static const iocshArg GpibBoardDriverConfigArg3 =
    { "timeout", iocshArgDouble };
static const iocshArg GpibBoardDriverConfigArg4 =
    { "priority", iocshArgInt };
static const iocshArg *GpibBoardDriverConfigArgs[] = {
    &GpibBoardDriverConfigArg0,&GpibBoardDriverConfigArg1,&GpibBoardDriverConfigArg2,&GpibBoardDriverConfigArg3,&GpibBoardDriverConfigArg4};
static const iocshFuncDef GpibBoardDriverConfigFuncDef = {
    "GpibBoardDriverConfig",5, GpibBoardDriverConfigArgs};
static void GpibBoardDriverConfigCallFunc(const iocshArgBuf *args)
     GpibBoardDriverConfig(args[0].sval,args[1].ival,args[2].ival,args[3].dval,args[4].ival);
static void GpibBoardDriverRegister(void)
    static int firstTime = 1;
    if (firstTime) {
        firstTime = 0;
        iocshRegister(&GpibBoardDriverConfigFuncDef, GpibBoardDriverConfigCallFunc);
epicsExportRegistrar(GpibBoardDriverRegister);
Re: Reading scope waveforms with StreamDevice + asyn Rod Nussbaumer
Re: Reading scope waveforms with StreamDevice + asyn Dirk Zimoch
Prev: Re: Reading scope waveforms with StreamDevice + asyn Dirk Zimoch
Next: Re: porting strategy from IDL Paul Sichta
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Reading scope waveforms with StreamDevice + asyn Rod Nussbaumer
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
