1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: problem with 64 bit build of EDM v1-12-68
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 13 Jan 2012 22:56:50 -0500
All,
I am attempting to build EDM on 64 bit linux for the first time.
configuration:
gcc 4.4.5  [Scientific Linux release 6.1 (Carbon)]
epics R3.14.12.2
EDM 1-12-68
calc_pv_factory.cc fails, see below.
Any advice?
John Dobbins
Cornell University
/usr/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dlinux -D_REENTRANT -O3 -Wall -DSINGLE_THREADED=1 -D__epics__=1 -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../../include/edm/os/Linux -I../../../../include/edm -I/nfs/erl/erp/epics/R3.14.12/support/base-3.14.12.2/include/os/Linux -I/nfs/erl/erp/epics/R3.14.12/support/base-3.14.12.2/include -I/nfs/erl/erp/epics/R3.14.12/support/base-3.14.12.2/../../extensions/include -I../../util -I../../lib -I/usr/include -I/usr/include/X11 ../calc_pv_factory.cc ../calc_pv_factory.cc: In function \u2018bool equals(const HashedCalcPvList*, const HashedCalcPvList*)\u2019: ../calc_pv_factory.cc:501: error: cast from \u2018CALC_ProcessVariable*\u2019 to \u2018unsigned int\u2019 loses precision ../calc_pv_factory.cc:501: error: cast from \u2018CALC_ProcessVariable*\u2019 to \u2018unsigned int\u2019 loses precision ../calc_pv_factory.cc:504: error: cast from \u2018CALC_ProcessVariable*\u2019 to \u2018unsigned int\u2019 loses precision ../calc_pv_factory.cc:504: error: cast from \u2018CALC_ProcessVariable*\u2019 to \u2018unsigned int\u2019 loses precision
../calc_pv_factory.cc: At global scope:
../calc_pv_factory.cc:613: warning: invalid access to non-static data member \u2018HashedExpression::node\u2019 of NULL object ../calc_pv_factory.cc:613: warning: (perhaps the \u2018offsetof\u2019 macro was used incorrectly) ../calc_pv_factory.cc:617: warning: invalid access to non-static data member \u2018HashedCalcPvList::node\u2019 of NULL object ../calc_pv_factory.cc:617: warning: (perhaps the \u2018offsetof\u2019 macro was used incorrectly) ../calc_pv_factory.cc: In member function \u2018void CALC_ProcessVariable::completeCreation(HashedExpression*)\u2019: ../calc_pv_factory.cc:1289: warning: comparison between signed and unsigned integer expressions
make[3]: *** [calc_pv_factory.o] Error 1
make[3]: Leaving directory `/nfs/erl/erp/epics/R3.14.12/extensions/src/edm/calcPv/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/nfs/erl/erp/epics/R3.14.12/extensions/src/edm/calcPv'
make[1]: *** [calcPv.install] Error 2
make[1]: Leaving directory `/nfs/erl/erp/epics/R3.14.12/extensions/src/edm'
make: *** [edm.install] Error 2
RE: problem with 64 bit build of EDM v1-12-68 John Dobbins
Prev: Re: Rec Proc Monitor for mbbi ZRST Andrew Johnson
Next: RE: problem with 64 bit build of EDM v1-12-68 John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: DBE_PROPERTY support in R3.14.11, gateway, CSS, MBBI/MBBO Re: Rec Proc Monitor for mbbi ZRST Dirk Zimoch
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
