g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Announce: sequencer release 2.1.4
From: Benjamin Franksen <benjamin.franksen@helmholtz-berlin.de>
To: <tech-talk@aps.anl.gov>
Date: Tue, 10 Jan 2012 14:20:09 +0100
Hi All
This is, again, a pure bug fix release.
As usual, documentation, release notes, download links, and install
instructions can be found on the sequencer homepage:
  http://tinyurl.com/epics-seq/
User relevant changes since 2.1.3 are:
* snc: fixed parser stack overflow
  This appeared when compiling deeply nested statements.
  The solution is to use a dynamically growing stack.
* pv: only install public interface header files
* pv: fixed a build problem on mingw32
  The solution is to use epicsShareClass on class
  declarations, instead of epicsShareFunc on methods.
* test: fix Makefile to allow building if sources are read-only
* docs: fixed some typos and a build problem with note:: directives
* configure: made 3.14.12.2 the default base release
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Prev: CSS app Launcher Patard Charles Henri
Next: RE: CSS app Launcher Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Next: Re: pyepics: Strategies for working with fast-changing large arrays Anton Derbenev
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
