g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: [CA] how to properly set up CAS and clients
To: EPICS Tech Talk <tech-talk@aps.anl.gov>
Date: Fri, 6 Jan 2012 14:23:58 +0400
Hello everyone,
1. I am interested, how to properly set up the connection properties. I would like to have a soft IOC running on a laptop and access PVs on two more computers (clients) as well as on the laptop. I have also some instruments (a PLC and an oscillograph) with the Ethernet interface. Do all my Ethernet devices have to be in one subnet? Like this:
Laptop (RHEL 5.5): 192.168.0.1
PC 1 (Win XP sp3): 192.168.0.2
PC 2 (Win XP sp2): 192.168.0.3
PLC (Siemens 317-2 PN/DP): 192.168.0.4
Oscilloscope (Tektronix): 192.168.0.5
Subnet mask: 255.255.255.0
My IOC is running under RHEL 5.5 (linux-x86) on the VMware virtual machine with a Bridged setting on (PC1). Everything is connected with the help of a MOXA switch ("star-connection"). Later on I will add a Wifi router - so I could access PVs over wifi from another laptop (laptop2).
For the time being, I want to use CSS as a client. So, I would like to know how to setup connection properties on the server as well as on the clients (so everything will work either using css or caget, caput, camonitor). It's a little bit confusing, though I have read CA reference manual, there is no simple tutorial nor a helloworld sample :))
2. I am also interested about how to configure my own clients in the future. Can I use simple caget, caput, camonitor on client PCs in the meantime? Do these programs require base installed? What if a computer doesn't have base installed? Can I still access PVs through CSS or my own programed clients (using CAJ, Perl, C)?
I wish the EPICS community to get bigger and to make progress in the following year. Thanks for your support!
Sincerely,
Pavel Maslov, MSc
R&D Institute for Electro-Physical Apparatus
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
Prev: Motor module "unknown bit order" compiler error with vxWorks-mpc8548 Fong, Nia W.
Next: Calling Windows "managed code" from EPICS Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
