Hello Lin Wang, At least some of the patches accommodating vxWorks 6.x can be seen at this URL. http://bazaar.launchpad.net/~epics-core/epics-base/3.14/revision/12090 In particular I suspect that some patches to src/libCom/osi/os/vxWorks/osdSock.h, documented in the above URL, are resolving this particular issue that you are encountering when using the earlier 3.14.11 release with vxWorks 6.x. Jeff ______________________________________________________ Jeffrey O. Hill Email johill@lanl.gov LANL MS H820 Voice 505 665 1831 Los Alamos NM 87545 USA FAX 505 665 5107 Message content: TSPA From: tech-talk-bounces@aps.anl.gov [mailto:tech-talk-bounces@aps.anl.gov] On Behalf Of ?? Sent: Thursday, December 29, 2011 6:19 AM To: tech-talk@aps.anl.gov Subject: Problem of "The CA server's beacon address list was empty after initialization" When I install EPICS 3.14.11 on RHEL4.8 for VxWorks6.8/vxWorks-ppc604_long, then create an example app, and load it to MVME5100, it will display "The CA server's beacon address list was empty after initialization?" like this: -> </home/wanglin/vx6_8_ep11App/iocBoot/iocexample/st.cmd ## Example vxWorks startup file cd "/home/wanglin/vx6_8_ep11App" value = 0 = 0x0 ld < bin/vxWorks-ppc604_long/example.munch value = 40806864 = 0x26ea9d0 dbLoadDatabase "dbd/example.dbd" value = 0 = 0x0 example_registerRecordDeviceDriver pdbbase value = 0 = 0x0 dbLoadTemplate "db/user.substitutions" value = 0 = 0x0 dbLoadRecords "db/dbSubExample.db", "user=wanglin" value = 0 = 0x0 iocInit Starting iocInit ############################################################################ ## EPICS R3.14.11 $R3-14-11$ $2009/08/28 18:47:36$ ## EPICS Base built Dec 29 2011 ############################################################################ iocRun: All initialization complete value = 0 = 0x0 -> The CA server's beacon address list was empty after initialization? I do not change any environment variables, and this problem do not happen to me for EPICS 3.14.12.1. It seems that the Bug #541358 mentioned before was fixed on EPICS 3.14.11, and the file iocinf.cpp and online_notify.c of 3.14.11 and 3.14.12.1 are the same. So, what probably results in this problem? And how can I solve it? |
EPICS Collaboration Meeting Spring 2012 [Happy New Year to All] Ernest L. Williams Jr.
RE: The crash of Matlab using LabCA Jeff Hill
<2012>
<2012>
ANJ, 27 Nov 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
EPICSv4
IRMIS
Talk
Bugs
Documents
Links
Licensing
