Hello all
I compiled areaDetector modules to link CCD detector. But when I run program in the Matlab by LabCA , the Matlab crash . The error code as follows. Does anyone know why?
[ 0] 0x0057c422 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwfl.so+00496674 fl::sysdep::linux::unwind_stack(void const**, unsigned int, unsigned int)+000036 [ 1] 0x0051d8f4 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwfl.so+00108788 fl::diag::stacktrace_base::capture(unsigned int)+000046 [ 2] 0x00826d50 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00302416 [ 3] 0x008274b7 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00304311 [ 4] 0x00405835 /usr/local/matlab/bin/glnx86/../../sys/os/glnx86/libstdc++.so.6+00739381 [ 5] 0x00405872 /usr/local/matlab/bin/glnx86/../../sys/os/glnx86/libstdc++.so.6+00739442 [ 6] 0x0040599a /usr/local/matlab/bin/glnx86/../../sys/os/glnx86/libstdc++.so.6+00739738 [ 7] 0x03300d65 /home/xxxx/shiyan/epics/src/base-3-14-11/lib/linux-x86/libca.so.3.14+00204133 tcpiiu::readNotifyRequest(epicsGuard<epicsMutex>&, nciu&, netReadNotifyIO&, unsigned int, unsigned long)+000357 [ 8] 0xa0ef1f38 /home/xxxx/shiyan/epics/src/base-3-14-11/lib/linux-x86/libca.so.3.14+2646748984
[ 0] 0x0057c422 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwfl.so+00496674 fl::sysdep::linux::unwind_stack(void const**, unsigned int, unsigned int)+000036 [ 1] 0x0051d8f4 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwfl.so+00108788 fl::diag::stacktrace_base::capture(unsigned int)+000046 [ 2] 0x00826d50 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00302416 [ 3] 0x008274f4 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00304372 [ 4] 0x006ce40c __kernel_rt_sigreturn+000000 [ 5] 0x006ce416 __kernel_vsyscall+000002 [ 6] 0x037b0e71 /lib/i386-linux-gnu/libc.so.6+00175729 gsignal+000081 [ 7] 0x037b434e /lib/i386-linux-gnu/libc.so.6+00189262 abort+000382 [ 8] 0x0040583a /usr/local/matlab/bin/glnx86/../../sys/os/glnx86/libstdc++.so.6+00739386 [ 9] 0x00405872 /usr/local/matlab/bin/glnx86/../../sys/os/glnx86/libstdc++.so.6+00739442 [ 10] 0x0040599a /usr/local/matlab/bin/glnx86/../../sys/os/glnx86/libstdc++.so.6+00739738 [ 11] 0x03300d65 /home/xxxx/shiyan/epics/src/base-3-14-11/lib/linux-x86/libca.so.3.14+00204133 tcpiiu::readNotifyRequest(epicsGuard<epicsMutex>&, nciu&, netReadNotifyIO&, unsigned int, unsigned long)+000357 [ 12] 0x032eed95 /home/xxxx/shiyan/epics/src/base-3-14-11/lib/linux-x86/libca.so.3.14+00130453 cac::readNotifyRequest(epicsGuard<epicsMutex>&, nciu&, privateInterfaceForIO&, unsigned int, unsigned long, cacReadNotify&)+000197 [ 13] 0x032fbd4a /home/xxxx/shiyan/epics/src/base-3-14-11/lib/linux-x86/libca.so.3.14+00183626 nciu::read(epicsGuard<epicsMutex>&, unsigned int, unsigned long, cacReadNotify&, unsigned int*)+000186 [ 14] 0x0330e71a /home/xxxx/shiyan/epics/src/base-3-14-11/lib/linux-x86/libca.so.3.14+00259866 ca_array_get_callback+000186 [ 15] 0x07631716 /home/xxxx/shiyan/epics/src/extensions/src/labca_3_3/lib/linux-x86/libezcamt.so.0+00022294 [ 16] 0x076329b9 /home/xxxx/shiyan/epics/src/extensions/src/labca_3_3/lib/linux-x86/libezcamt.so.0+00027065 ezcaEndGroupWithReport+002345 [ 17] 0x01bd026f /home/xxxx/shiyan/epics/src/extensions/src/labca_3_3/lib/linux-x86/libmezcaglue.so.0+00012911 multi_ezca_get+001247 [ 18] 0x01b40cc8 /home/xxxx/shiyan/epics/src/extensions/src/labca_3_3/bin/linux-x86/labca/lcaGet.mexglx+00003272 mexFunction+000536 [ 19] 0x0078f8fb /usr/local/matlab/bin/glnx86/../../bin/glnx86/../../bin/glnx86/libmex.so+00039163 mexRunMexFile+000109 [ 20] 0x0078c459 /usr/local/matlab/bin/glnx86/../../bin/glnx86/../../bin/glnx86/libmex.so+00025689 [ 21] 0x0078db69 /usr/local/matlab/bin/glnx86/../../bin/glnx86/../../bin/glnx86/libmex.so+00031593 [ 22] 0x001fe982 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_dispatcher.so+00432514 Mfh_file::dispatch_fh(int, mxArray_tag**, int, mxArray_tag**)+000318 [ 23] 0x00df420f /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+03146255 [ 24] 0x00df99b2 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+03168690 [ 25] 0x00dfa5fa /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+03171834 [ 26] 0x00c2ee57 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+01289815 [ 27] 0x00c50054 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+01425492 [ 28] 0x00c50113 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+01425683 [ 29] 0x00d988c8 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+02771144 [ 30] 0x00bc3988 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+00850312 [ 31] 0x00c2c6e4 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+01279716 [ 32] 0x00c01634 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+01103412 [ 33] 0x00c004fe /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+01099006 [ 34] 0x001fe982 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_dispatcher.so+00432514 Mfh_file::dispatch_fh(int, mxArray_tag**, int, mxArray_tag**)+000318 [ 35] 0x00c06f3b /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+01126203 [ 36] 0x00bb5578 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+00791928 [ 37] 0x00bb9c96 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+00810134 [ 38] 0x00bba3b9 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+00811961 [ 39] 0x00b76cdf /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwm_interpreter.so+00535775 inEvalCmdWithLocalReturn+000081 [ 40] 0x00181758 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwbridge.so+00091992 [ 41] 0x00182763 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwbridge.so+00096099 mnParser+000333 [ 42] 0x0080de57 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00200279 mcrInstance::mnParser_on_interpreter_thread()+000051 [ 43] 0x00816f54 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00237396 [ 44] 0x007f5abe /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00101054 [ 45] 0x007f5ba1 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00101281 [ 46] 0x007f05ef /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00079343 [ 47] 0x0181b591 /usr/local/matlab/bin/glnx86/../../bin/glnx86/../../bin/glnx86/libmwuix.so+00390545 [ 48] 0x018163b8 /usr/local/matlab/bin/glnx86/../../bin/glnx86/../../bin/glnx86/libmwuix.so+00369592 [ 49] 0x0181e366 /usr/local/matlab/bin/glnx86/../../bin/glnx86/../../bin/glnx86/libmwuix.so+00402278 [ 50] 0x0625863c /usr/local/matlab/bin/glnx86/../../bin/glnx86/../../bin/glnx86/libuij.so+00251452 [ 51] 0x06254d8f /usr/local/matlab/bin/glnx86/../../bin/glnx86/../../bin/glnx86/libuij.so+00236943 svWS_ProcessPendingEvents(int, int, bool)+000595 [ 52] 0x0625820a /usr/local/matlab/bin/glnx86/../../bin/glnx86/../../bin/glnx86/libuij.so+00250378 UIJ_WS_ProcessPendingEvents(int, int)+000044 [ 53] 0x0094673f /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwservices.so+00378687 svWS_ProcessPendingEvents+000037 [ 54] 0x007f0e55 /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00081493 [ 55] 0x007f117a /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00082298 [ 56] 0x007f13ab /usr/local/matlab/bin/glnx86/../../bin/glnx86/libmwmcr.so+00082859 [ 57] 0x0024de99 /lib/i386-linux-gnu/libpthread.so.0+00024217 [ 58] 0x0385673e /lib/i386-linux-gnu/libc.so.6+00853822 clone+000094 Best wishes
peng
Re: pyepics: Strategies for working with fast-changing large arrays Matt Newville
Problem of "The CA server's beacon address list was empty after initialization" 王林
<2011>
RTEMS-MVME2300 Qazi Zia-ul-Haque
<2011>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
