I committed the change to add -I$(COMMON_DIR) to the DBFLAGS definition.
The change will be in the next base release. Thanks.
Janet
Allison, Stephanie wrote:
Hello,
The following line was removed from RULES.Db sometime between epics base 3.14.8.2 and 3.14.11:
DBFLAGS += -I$(COMMON_DIR)
where
COMMON_DIR = ../O.Common
This means that a database built from a substitutions file that depends on a database already built in O.Common will fail.
For instance, if the Makefile looks like this:
DB += aabb.db
DB += ccdd.db
and the directory contains:
aabb.substitutions
ccdd.substitutions
and
ccdd.substitutions includes aabb.db, the build will now fail.
Can the "DBFLAGS += -I$(COMMON_DIR)" be added back to RULES.Db? If no, is there another solution to this problem? Other than creating subdirectories under Db and building in the proper order.
Thank you,
Stephanie Allison
- Re: Change to RULES.Db between 3.14.8.2 and 3.14.11 -I../O.Common no longer in include paths Williams Jr., Ernest L.
- Change to RULES.Db between 3.14.8.2 and 3.14.11 -I../O.Common no longer in include paths Allison, Stephanie
Australian Synchrotron Employment Opportunities Controls Lou Corvetti
<2011>
<2011>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
