Hi Pierrick,
The read/write access is determined by access security. See section 8
of the Application Developers Guide - Access Security,
http://www.aps.anl.gov/epics/base/R3-14/12-docs/AppDevGuide/node9.html.
Strictly controlled by EPICS, no network firewalls involved.
Geoff
On 12/21/2011 1:46 PM, Pierrick Hanlet wrote:
I've not been successful in finding where this is documented.
When using caInfo on a record, one piece of infomation displayed is
read/write access to the record. What are the different means of
setting this read/write access? Can a network firewall setting affect
this value, or is it strictly controlled by epics?
Thank you,
Pierrick
Pierrick Hanlet
Fermilab, P.O. Box 500, M.S. 221
Batavia, IL 60510
[email protected]
(630)840-5555/8871/6039 office/lab/fax
http://www-d0.fnal.gov/~hanlet
"Whether you think you can or think you can't, either way, you are correct" -- Henry Ford
- cainfo and access Pierrick Hanlet
Re: cainfo and access Andrew Johnson
application build error with new sequence program S. Stein
<2011>
<2011>
