1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [make] mingw, gnuwin32, cygwin
To: EPICS Tech Talk <[email protected]>
Date: Wed, 21 Dec 2011 21:29:12 +0400
pardon me:
Can I install the Epics base using gnuwin32 and MS VS 2010 (which I did), but build applications using MinGW or cygwin?
On Wed, Dec 21, 2011 at 9:12 PM, Pavel Masloff <[email protected]> wrote:
Can I install the Epics base using gnuwin32 and MS VS 2010 (which I did), but build applications using gnuwin32 or cygwin?
Because some modules were created for linux only, therefore, for example, I can't install the s7plc driver, because it needs a program called "cat". And cat.exe I found in the cygwin bin directory.
Sincerely,
Pavel Maslov, MSc
R&D Institute for Electro-Physical Apparatus
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
Sincerely,
Pavel Maslov, MSc
RE: [make] mingw, gnuwin32, cygwin Mark Rivers
Prev: RE: question about the promptgroup meaning in DBD file Abadie Lana
Next: RE: [make] mingw, gnuwin32, cygwin Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: CA Watcher - an other camonitor Pavel Masloff
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
