1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: question about the promptgroup meaning in DBD file
To: [email protected]
Date: Tue, 20 Dec 2011 14:33:45 -0600
Hi Lana,
On 2011-12-20 Abadie Lana wrote:
> Thanks for clarification, the reason is wanted to group the different
> fields: the promptgroup was a good start but sometimes quite hard to
> follow. Lana
VDCT's inspector window can group fields together using the PromptGroup
information, but most of the standard record types were developed by a number
of different people and not all of the authors understood how that worked.
If someone could go through all the record types and clean up these values to
group the fields more sensibly I would be very happy to merge the resulting
changes into Base.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
RE: question about the promptgroup meaning in DBD file Abadie Lana
[Eclipse] EPICS IDE plugin Pavel Masloff
Re: [Eclipse] EPICS IDE plugin Pavel Masloff
Prev: EPICS Website and tech-talk mailing list Andrew Johnson
Next: Re: [Eclipse] EPICS IDE plugin Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: question about the promptgroup meaning in DBD file Rolf Keitel
Next: RE: question about the promptgroup meaning in DBD file Abadie Lana
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
