Martin,
My own CSS - that sounds amazing! I like CSS, it's a really cool extension. What makes NSLS-II a good alternative to other versions like DESY or SNS? I am using CSS_EPICS_3.0.2, which is I guess of the SNS origin.
Do you use NSLS-II at your institute?
Kind regards, Pavel Masloff
On Tue, Dec 20, 2011 at 12:47 AM, Martin Konrad <[email protected]> wrote:
Hi Pavel,
> Can one install the EPICS IDE plugin _locally_? I mean, download the
> *.jars and install the same way as installing CDT?
Yes, that should be possible. But this is not recommended because you
have to deal with a lot of dependencies etc.
> I am provided only through a Virtual Machine (run on
> the same pc), which has a limited number of applications (I guess this
> is done due to security purposes - against viruses, trojans, etc). So
> there is no direct connection :(
If you just want to give Control System Studio a try you can start by
downloading a product for another machine - e.g. NSLS-II:
http://cs-studio.sourceforge.net/ This way you only have to copy one
file to your machine. The downside is that some settings might be wrong
for your machine - but you can fix that afterwards. If you want your own
combination of plug-ins or your own site-specific settings on several
machines you should think about creating your own CSS product (see
http://cs-studio.sourceforge.net/docbook/index.html for details).
Cheers
Martin
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel.: +49-6151-16-5121
Fax: +49-6151-16-4321
-- Sincerely,
Pavel Maslov, MSc R&D Institute for Electro-Physical Apparatus
Mobile: +7 (951) 672 22 19 Phone: +7 (812) 461 01 01
- [Eclipse] EPICS IDE plugin Pavel Masloff
- Re: [Eclipse] EPICS IDE plugin Martin Konrad
Re: [Eclipse] EPICS IDE plugin Andrew Johnson
Re: [Eclipse] EPICS IDE plugin Pavel Masloff
<2011>
<2011>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
