1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [Eclipse] EPICS IDE plugin
To: [email protected]
Date: Mon, 19 Dec 2011 17:22:36 -0600
Hi Pavel,
On 2011-12-19 Pavel Masloff wrote:
> Can one install the EPICS IDE plugin *locally*? I mean, download the *.jars
> and install the same way as installing CDT?
> There is only one method proposed - through the Eclipse Update Manager
> using http://www.aps.anl.gov/epics/eclipse/updates as a source.
> If so, where can I download the packet?
The EPICS IDE Plugin is probably not worth installing, I don't know of anybody
who actually uses it.  It was written several years by an developer who has
since retired, and as far as I know nobody else has ever looked at his code,
certainly nobody is maintaining it now.  It is mostly just a GUI wrapper for
the makeBaseApp.pl script that comes with EPICS Base, and not a comprehensive
one at that.
Don't waste your time on it.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Re: [Eclipse] EPICS IDE plugin Pavel Masloff
Prev: Re: [Eclipse] EPICS IDE plugin Martin Konrad
Next: Re: [Eclipse] EPICS IDE plugin Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: [Eclipse] EPICS IDE plugin Pavel Masloff
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
