I seem to recall some similar problems a while back, but this is new since I moved to R3.14.12.2.
After I do a 'make clean' I can run 'make' once and everything builds:
> make
perl /usr/local/epics/R3.14.12/base/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../..
mkdir O.Common
make -C O.darwin-x86 -f ../Makefile TOP=../.. T_A=darwin-x86 install
echo "../O.Common/irmSup.db : " >> irmSup.db.d
Inflating database from ../irmSup.substitutions
msi -I. -I.. -I ../../db -I/usr/local/epics/R3.14.12/modules/soft/synApps_5_6/support/asyn-4-18/db -I/usr/local/epics/R3.14.12/base/db -S../irmSup.substitutions > irmSup.tmp
mv irmSup.tmp ../O.Common/irmSup.db
Installing created db file ../../db/irmSup.db
clang -c -DUNIX -Ddarwin -O3 -g -Wall -arch x86_64 -fno-common -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../include/os/Darwin -I../../include -I/usr/local/epics/R3.14.12/modules/soft/synApps_5_6/support/asyn-4-18/include -I/usr/local/epics/R3.14.12/base/include/os/Darwin -I/usr/local/epics/R3.14.12/base/include -I/opt/local/include -I/sw/include ../irmSup.c
/usr/bin/ar -rc libirmSup.a irmSup.o
but on subsequent 'make' invocations I get:
> make
make[1]: *** No rule to make target `{', needed by `../O.Common/irmSup.db'. Stop.
make: *** [install.darwin-x86] Error 2
I've attached the support module Makefile and the set of substitution and templates.
code.tar.bz2
Description: BZip2 compressed data
My perl is
> perl -v
This is perl 5, version 12, subversion 3 (v5.12.3) built for darwin-thread-multi-2level
(with 2 registered patches, see perl -V for more detail)
And make is
> make -v
GNU Make 3.81
Any ideas as to what's gone wrong?
Eric Norum
[email protected]
- Re: Problem with msi rules in R3.14.12.2 Eric Norum
- Re: Problem with msi rules in R3.14.12.2 Andrew Johnson
Re: CSS Export Waveform data John Dobbins
<2011>
Re: [Eclipse] EPICS IDE plugin Andrew Johnson
<2011>
