Hi Ben,
I just tested the behavior of my asynPortDriver class when building
dynamically on win32-x86.
If I declare the class as follows it works fine. My
testAsynPortDriverApp links and runs fine.
class epicsShareFunc asynPortDriver {
public:
If I delete the epicsShareFunc in the definition of the class then I
get the following link errors when building testAsynPortDriverApp:
cl /nologo /EHsc /GR -c /nologo /D__STDC__=0
/D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox/GL /W3
/w44355 /D_WIN32_WINNT=0x0503 /MD /TP -I.
-I..\\O.Common -I. -I..
-I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include
-IJ:\\epics\\devel\\ipac-2-11\\include -IJ:\\epics\\devel\\seq-2-1-3\\include
-IH:\\epics\\base-3.14.12.2\\include\\os\\WIN32
-IH:\\epics\\base-3.14.12.2\\include ..\\testAsynPortDriver.cpp
link /nologo /subsystem:windows /dll /LTCG /incremental:no /opt:ref
/release /implib:testAsynPortDriverSupport.lib
/out:testAsynPortDriverSupport.dll testAsynPortDriver.obj
..\\..\\..\\lib\\win32-x86-dynamic\\asyn.lib H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\recIoc.lib
H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\softDevIoc.lib
H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\miscIoc.lib
H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\rsrvIoc.lib
H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\dbtoolsIoc.lib
H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\asIoc.lib
H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\dbIoc.lib
H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\registryIoc.lib
H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\dbStaticIoc.lib
H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\ca.lib
H:\\epics\\base-3.14.12.2\\lib\\win32-x86-dynamic\\Com.lib
Creating library testAsynPortDriverSupport.lib and object
testAsynPortDriverSupport.exp
testAsynPortDriver.obj : error LNK2001: unresolved external symbol
"public: virtual void __thiscall asynPortDriver::reportParams(struct
_iobuf *,int)" (?reportParams@asynPortDriver@@UAEXPAU_iobuf@@H@Z)
"public: virtual enum asynStatus __thiscall asynPortDriver::callParamCallbacks(void)"
(?callParamCallbacks@asynPortDriver@@UAE?AW4asynStatus@@XZ)
"public: virtual enum asynStatus __thiscall asynPortDriver::callParamCallbacks(int)"
(?callParamCallbacks@asynPortDriver@@UAE?AW4asynStatus@@H@Z)
"public: virtual enum asynStatus __thiscall asynPortDriver::callParamCallbacks(int,int)"
(?callParamCallbacks@asynPortDriver@@UAE?AW4asynStatus@@HH@Z)
So it appears to be both necessary and sufficient to put the
epicsShareFunc in the definition of the class itself.
Sent: Friday, December 16, 2011 7:19 AM
To: Benjamin Franksen; Josh Stein
Cc: [email protected]; [email protected]
Subject: RE: Sequencer build errors on Windows
Hi Ben,
I normally build statically on win32-x86, so I don't have a lot of
experience with ensuring that the functions are visible in DLLs. However,
I know that I did make it work with the asynPortDriver class in asyn, and this
is what I did:
/** Base class for asyn port drivers; handles most of the bookkeeping
for writing an asyn port driver
* with standard asyn interfaces and a parameter library. */
public:
asynPortDriver(const char *portName, int maxAddr,
int paramTableSize, int interfaceMask, int interruptMask,
int asynFlags, int autoConnect, int priority, int stackSize);
virtual ~asynPortDriver();
virtual asynStatus lock();
virtual asynStatus unlock();
virtual asynStatus getAddress(asynUser *pasynUser,
int *address);
virtual asynStatus readInt32(asynUser *pasynUser,
epicsInt32 *value);
virtual asynStatus writeInt32(asynUser *pasynUser,
epicsInt32 value);
virtual asynStatus readUInt32Digital(asynUser
*pasynUser, epicsUInt32 *value, epicsUInt32 mask);
virtual asynStatus writeUInt32Digital(asynUser
*pasynUser, epicsUInt32 value, epicsUInt32 mask);
So it was sufficient to declare the class with epicsShareFunc, not the
individual methods. I am quite sure that my test application that uses
this class linked fine when building dynamically.
From: [email protected] on behalf of Benjamin Franksen
Sent: Fri 12/16/2011 6:04 AM
To: Josh Stein
Subject: Re: Sequencer build errors on Windows
On Wednesday, December 07, 2011, Josh Stein wrote:
> Hello Benjamin and community,
> I am attempting to build version 2.1.3 of the
sequencer on a windows
> machine. I have the MinGW tools installed along with a windows
version
> of re2c. I have also already successfully built EPICS base, the
example
> app and an older version of the sequencer (2.0.14) in the past.
> When executing the build from the 2.1.3 top level directory, the
> following warnings and errors are shown and the make is stopped:
> ../../../include/pv.h:75:37: warning: inline function 'pvSystem*
> pvSystem::getSystem()' declared as dllimport: attribute
ignored
> [-Wattributes]
> ../../../include/pv.h:77:35: error: function 'pvStat
pvSystem::attach()'
> definition is marked dllimport
> ../../../include/pv.h:78:35: error: function 'pvStat
pvSystem::flush()'
I would like to pose this question to the community, especially the C++
experts.
These are the relevant lines:
class pvSystem {
public:
epicsShareFunc pvSystem( int debug = 0 );
epicsShareFunc virtual ~pvSystem();
epicsShareFunc inline pvSystem *getSystem() { return
this; }
epicsShareFunc virtual pvStat attach() { return
pvStatOK; }
epicsShareFunc virtual pvStat flush() { return
pvStatOK; }
The code in the src/pv subsystem in the sequencer uses 'epicsShareFunc'
for
C++ class methods in many places (also in the method implementations).
While
it seems it has worked so far, I wonder if epicsShareFunc' is necessary
here
or even intended. I looked at some EPICS base header and cpp files and
found
'epicsShareFunc' is not used for C++ class methods.
So, can I just remove 'epicsShareFunc' qualifiers on class methods?
At least on my win32-x86 VM this worked fine (build & tests).
Cheers
Ben
Helmholtz-Zentrum Berlin für Materialien und Energie
GmbH
Mitglied der Hermann von Helmholtz-Gemeinschaft
Deutscher Forschungszentren e.V.
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim
Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla,
Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
