1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: epics base 3.14.12.1 build error on fedora 16
To: Florian Feldbauer <[email protected]>
Date: Fri, 16 Dec 2011 14:02:40 +0300
cancel this, I've figured this. Didn't understand the syntax at first glance. Silly me. Thanks.
Pavel
On Fri, Dec 16, 2011 at 1:42 PM, Pavel Masloff <[email protected]> wrote:
Hey Florian?
I guess it may sound foolish, but how can I apply the first patch (0001-Drop-mutable-references.patch)?
Pavel
2011/12/16 Florian Feldbauer <[email protected]>
Hello Pavel,
I had the same problems on Fedora15. I used these two patches to fix the problems.
Best regards,
Florian
On 12/16/2011 11:31 AM, Pavel Masloff wrote:
Hello Miroslav!
I have experienced the same problem you had - http://www.aps.anl.gov/epics/tech-talk/2011/msg00964.php
How did you resolve it? I have changed "size_t _refCount;" to "std :: size_t _refCount;" in epicsSingleton.h as was proposed. But still I get this:
In file included from ../cac.cpp:39:0:
../cac.h:269:26: error: reference ‘mutex’ cannot be declared ‘mutable’
[-fpermissive]
../cac.h:270:26: error: reference ‘cbMutex’ cannot be declared ‘mutable’
[-fpermissive]
In file included from ../cac.cpp:47:0:
../udpiiu.h:152:26: error: reference ‘cbMutex’ cannot be declared
‘mutable’ [-fpermissive]
../udpiiu.h:153:26: error: reference ‘cacMutex’ cannot be declared
make[3]: *** [cac.o] Error 1
Sincerely,
Pavel Maslov, MSc
R&D Institute for Electro-Physical Apparatus
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
| Florian Feldbauer                 |
| Ph.D. student                     |
| Institut für Experimentalphysik I |
| Ruhr-Universität Bochum           |
| Universitätsstr. 150              |
| D-44780 Bochum                    |
| Office: NB 2/173                  |
| Phone:  (+49)234 / 32-23538       |
| Fax:    (+49)234 / 32-14170       |
| Web:    http://www.ep1.rub.de     |
Sincerely,
Pavel Maslov, MSc
Sincerely,
Pavel Maslov, MSc
epics base 3.14.12.1 build error on fedora 16 Pavel Masloff
Re: epics base 3.14.12.1 build error on fedora 16 Florian Feldbauer
Re: epics base 3.14.12.1 build error on fedora 16 Pavel Masloff
Prev: Re: epics base 3.14.12.1 build error on fedora 16 Florian Feldbauer
Next: Re: Sequencer build errors on Windows Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: CSS Export Waveform data John Dobbins
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
