1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Tektronix 3000/5000 oscilloscopes
To: Pavel Masloff <[email protected]>
Date: Mon, 12 Dec 2011 08:33:52 -0800
On Dec 12, 2011, at 7:51 AM, Pavel Masloff wrote:
Hello, Nick!
Dear colleagues!
Could you please explain how to use your TDS3000 support for my Tektronix 3054C (i have only the Ethernet interface)?
I am using the RHEL x86 operating system. I have successfully installed epics base (R3-14-12-1), extensions (1.7), sequencer (seq-2.1.3), asyn driver support (asyn4-18), tektronix tds3000 device support (tds3000-2.4) according to the manual. And they all seem to be working fine.
I think I have some problems with creating an application. I can't understand how to perform the following:
Using the software
In order to use the support in an application do the following:
    Add the following to <top>/configure/RELEASE
    TDS3000 = <full path to installation directory>
    ASYN = <full path to installation directory>
    Add the following to the application Makefile.
    <app>_LIBS_vxWorks += asyn
    <app>_LIBS_vxWorks += devTDS3000
There are two things wrong:
1) You are specifying libraries for vxWorks, but you are building an application for Linux.
2) Order of libraries is important.  The asyn library must come after the devTDS3000 library.
Try changing the above two application Makefile lines to:
<app>_LIBS += devTDS3000
<app>_LIBS += asyn
Eric Norum
[email protected]
Re: Tektronix 3000/5000 oscilloscopes Pavel Masloff
[help] EPICS build no good Pavel Masloff
Re: [help] EPICS build no good Andrew Johnson
Re: [help] EPICS build no good Pavel Masloff
Re: [help] EPICS build no good Dirk Zimoch
Tektronix 3000/5000 oscilloscopes Eric Norum
Prev: Re: About the interface LabCA problem that Matlab can't read image data from areaDetector Till Straumann
Next: Re: Tektronix 3000/5000 oscilloscopes Pavel Masloff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Tektronix 3000/5000 oscilloscopes Mark Rivers
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
