Hi.
If you want to get help then you should provide more detailed
information.
By just saying that you 'met this problem' and 'matlab would shut up
automatically'
you are not really giving us a clear picture of what you were
experiencing.
If you ask for help then it is always a good idea to submit an
*unedited* console
log of your session. Please do not edit anything away since valuable
clues
are often at a place where you wouldn't expect them.
A very vague request for help ("it doesn't work, please help") is
more likely
to not being answered as it generates more work for the expert(s)
since they
usually have to write an email like this one prior to being able to
help.
Regards
- Till
On 12/10/2011 06:14 AM, 的 wrote:
Hi everbody
I used procilica camera to read image data in EPICS.
And use LabCA as interface to link Matlab and areaDetector
based in EPICS. So I met this problem. Maybe the Channel
Access interface only supports reading arrays as doubles
(64-bit floating points), but the Prosilica is normally
sending 8-bit data. Thus when I use Matlab to read image
datas, Matlab would shut up automatically. Or that is the
other question? Does anyone met this question? And how to
solve it ?
Thank you !
nbsp; !
Peng
- About the interface LabCA problem that Matlab can't read image data from areaDetector 的
Re: About the interface LabCA problem that Matlab can't read image data from areaDetector Till Straumann
Re: Tektronix 3000/5000 oscilloscopes Eric Norum
<2011>
pyepics3 Stripchart howto wanted Peter Milne
<2011>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
