Dirk Zimoch wrote:
Hi all,
When I tried to upgrade from 3.14.8 to 3.14.12, I found that some CALC
expressions are not working any more, e.g. "B=0?A"
In 3.14.8 and all previous versions that meant: If B is 0 then set VAL
to A otherwise don't change VAL.
Now, I get the error message:
Unbalanced conditional ?: operators in CALC expression 'B=0?A'
Can't set "recordname.CALC" to "B=0?A"
Was there any good reason for this incompatible change in the CALC
behavior?
Dirk
By the way, the previous behavior is documented here:
http://www.aps.anl.gov/epics/wiki/index.php/RRM_3-14_Calculation#Conditional_Expression
(A+B)<(C+D)?E
* Result is E if (A+B) < (C+D)
* Result is unchanged if (A+B) >= (C+D)
The change is not mentioned in the release notes
http://www.aps.anl.gov/epics/base/R3-14/12-docs/RELEASE_NOTES.html
Thus I guess the new behavior was not intended and is a bug.
When fixing this, it is probably worth to implement as well a feature
available in gcc: If the second operand is missing, it is the same as
the first one.
"A+B?:C" means "A+B?A+B:C" but saves space and cpu cycles.
Dirk
- Re: Unbalanced conditional ? Paul Nord
- Re: Unbalanced conditional ? Andrew Johnson
- Unbalanced conditional ? Dirk Zimoch
<2011>
<2011>
