Thanks, I'd figured this already :))
On Thu, Dec 8, 2011 at 1:19 PM, Alan Greer <[email protected]> wrote:
[ajg@osllx10 ~]$ export PATH=/temp/path
[ajg@osllx10 ~]$ echo $PATH
/temp/path
[ajg@osllx10 ~]$
[ajg@osllx10 ~]$ export EPICS_HOST_ARCH=linux-x86
[ajg@osllx10 ~]$ echo $EPICS_HOST_ARCH
linux-x86
[ajg@osllx10 ~]$
Pavel Masloff wrote:
Hello everyone!
How can I set the environment variables (PATH and EPICS_HOST_ARCH) in RHEL-5 64 bit?
I ran the EpicsHostArch.pl script (>> perl EpicsHostArch.pl), but this script only returns the variable, doesn't set anything. I check by running "dev" in the command line.
And generally, what should one do to install the epics base from scratch on a linux machine?
Thanks.
Pavel.
Sincerely,
Pavel Maslov, MSc
R&D Institute for Electro-Physical Apparatus
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
-- Sincerely,
Pavel Maslov, MSc R&D Institute for Electro-Physical Apparatus
Mobile: +7 (951) 672 22 19 Phone: +7 (812) 461 01 01
- Re: [building EPICS in RHEL-5 64bit] environment variables Alan Greer
- [building EPICS in RHEL-5 64bit] environment variables Pavel Masloff
<2011>
<2011>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
