1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [help] EPICS build no good
To: Pavel Masloff <[email protected]>
Cc: [email protected]
Date: Mon, 5 Dec 2011 12:30:43 -0600
Hi Pavel,
On 2011-12-05 Pavel Masloff wrote:
> Here it is softioc -h:
> D:\>softIoc -h
> Usage: softIoc [-D softIoc.dbd] [-h] [-S] [-a ascf]
>         [-m macro=value,macro2=value2] [-d file.db]
>         [-x prefix] [st.cmd]
> Compiled-in path to softIoc.dbd is:
>         'D:\baseR3.14.12.1\new'/dbd/softIoc.dbd
Wierd, please send us the contents of this file from your build tree:
  baseR3.14.12.1\src\softIoc\O.win32-x86-mingw\epicsInstallDir.h
Also cd into that directory and delete that file, then run make (still inside
the O.win32-x86-mingw directory) and send us the Make output.
> By the way, in the config,site file there are no quotes at all:
> INSTALL_LOCATION=d:\baseR3.14.12.1\new
Why are you setting INSTALL_LOCATION in your CONFIG_SITE file?  I would
recommend until you get your build working properly that you remove that
setting and just have base install its files into the source tree.  The
softIoc problem is probably related to this setting — you'll probably need to
run 'make distclean all' from the top of the source tree after you change the
file though.
> Do you mean I should have put in single quotes? And, perhaps, there are
> some other settings before compiling that I should have set?
No, CONFIG_SITE settings generally never need quotes unless you have spaces in
paths (which I would also recommend against doing).
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
[help] EPICS build no good Pavel Masloff
Re: [help] EPICS build no good Andrew Johnson
Re: [help] EPICS build no good Pavel Masloff
Prev: BACnet for EPICS is available now. Webb, Steven B.
Next: Re: [help] EPICS build no good Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: [help] EPICS build no good Pavel Masloff
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
