1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [help] EPICS build no good
Cc: [email protected]
Date: Mon, 5 Dec 2011 21:13:53 +0300
Hey Andrew, hi guys!
Here it is softioc -h:
D:\>softIoc -h
Usage: softIoc [-D softIoc.dbd] [-h] [-S] [-a ascf]
        [-m macro=value,macro2=value2] [-d file.db]
        [-x prefix] [st.cmd]
Compiled-in path to softIoc.dbd is:
        'D:\baseR3.14.12.1\new'/dbd/softIoc.dbd
By the way, in the config,site file there are no quotes at all:
INSTALL_LOCATION=d:\baseR3.14.12.1\new
Do you mean I should have put in single quotes? And, perhaps, there are some other settings before compiling that I should have set?
2011/12/5 Andrew Johnson<[email protected]>
Hi Pavel,
On 12/4/11 3:18 PM, Pavel Masloff wrote:
I don't know where this error comes from (the single quotes). I thought running softIoc.exe is a simple way to check the installation.
Running 'softIoc -h' may help us a little, it displays the compiled-in path to the base/dbd/softIoc.dbd file rather than using it and showing it to us in an error message.
Windows understands forward slashes and internally we use them rather than back-slashes; in the softIoc output I would expect to see back-slashes in your path to base, but forward slashes in the /dbd/softIoc.dbd part that gets appended to point to the .dbd file, so this error looks to me like there are single quotes in the setting for the install location somehow.
d:\>softIoc
filename="..\dbLexRoutines.c" line number=243
Invalid argument dbRead opening file 'D:\baseR3.14.12.1\new'/dbd/softIoc.dbd
- Andrew
Sincerely,
Pavel Maslov, MSc
R&D Institute for Electro-Physical Apparatus
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
Re: [help] EPICS build no good Andrew Johnson
[help] EPICS build no good Pavel Masloff
RE: [help] EPICS build no good Mark Rivers
Re: [help] EPICS build no good Pavel Masloff
Prev: Re: [help] EPICS build no good Andrew Johnson
Next: BACnet for EPICS is available now. Webb, Steven B.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: [help] EPICS build no good Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
