1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [help] EPICS build no good
To: Geoff Savage <[email protected]>, [email protected]
Date: Mon, 5 Dec 2011 19:52:11 +0300
Yeah, what about these slashes? ))
I've no idea why they are forward. How can it be fixed I wonder?
2011/12/5 Geoff Savage <[email protected]>
How about the the slashes should be back slashes?
On 12/5/2011 10:43 AM, Pavel Masloff wrote:
Geoff!
Wait a minute. I successfully compiled using VS 2010 Express. But
softIoc.exe doesn't want to work:
/filename="..\dbLexRoutines.c" line number=243
Invalid argument dbRead opening file
'D:\baseR3.14.12.1\new'/dbd/softIoc.dbd/
Do you know why this happens?
Let me tell you how I built it.
1. Set global environment variables (EPICS_HOST_ARCH=win32-x86;
PATH=C:\GnuWin32\bin;d:\baseR3.14.12.1\new\bin\win32-x86)
2. Source files are located in d:\baseR3.14.12.1\base-3.14.12.1\
3. INSTALL_LOCATION=d:\baseR3.14.12.1\new
The compilation was successful. There were a few warnings, though.
Pavel
2011/12/5 Geoff Savage <[email protected] <mailto:[email protected]>>
   Check everything.  Sometimes you have to start again from scratch.
   For example, are you positive you are using the compilers from the
   mingw installation?  All I see in the output is g++.  This might
   explain why -fpermissive did not work.
   Geoff
   On 12/5/2011 10:16 AM, Pavel Masloff wrote:
       it had been set so prior
       2011/12/5 Janet Anderson <[email protected]
       <mailto:[email protected]> <mailto:[email protected]
       <mailto:[email protected]>>>
           __
           Looks like the definitions of CC and CCC  are incorrect.  Try
           setting CC=gcc and CCC=g++ in
           configure/os/CONFIG_SITE.__win32-x86-mingw.win32-x86-__mingw.
           Janet
               Hey Mark,
               I don't know where this error comes from (the single
           quotes). I
               thought running softIoc.exe is a simple way to check the
               installation.
               No, your suggestions didn't work (sorry, partly in
           Russian, I can
               translate if you need):
           "Installing generic include file ../../../include/tsDefs.h"
               windres -I. -I../O.Common -I.
           -I../../../src/libCom/osi/os/__WIN32
               -I../../../src/libCom/osi/os/__posix
               -I../../../src/libCom/osi/os/__default -I..
               -I../../../src/libCom/__bucketLib -I../../../src/libCom/ring
               -I../../../src/libCom/calc -I../../../src/libCom/cvtFast
               -I../../../src/libCom/cppStd
           -I../../../src/libCom/__cxxTemplates
               -I../../../src/libCom/dbmf -I../../../
               src/libCom/ellLib -I../../../src/libCom/env
               -I../../../src/libCom/error -I../../../src/libCom/fdmgr
               -I../../../src/libCom/freeList -I../../../src/libCom/gpHash
               -I../../../src/libCom/iocsh
           -I../../../src/libCom/__logClient
               -I../../../src/libCom/macLib -I../../../src/libCom/misc
               -I../../../src/libCom/osi -I../../../src/libCom/taskwd
               -I../../../src/libCom/timer -I../../../src/libCom/tsDefs
               -I../../../include/os/WIN32 -I../../../include
             ../Com.rc
               Com.coff
               g++ -c             -D_MINGW     -O3   -Wall     -fpermissive
               -m32    -D_DLL   -MMD -I. -I../O.Common -I.
               -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib
           -I../../../src/libCom/gpHash -I..
               /../../src/libCom/iocsh -I../../../src/libCom/__logClient
           -I../../
               -I../../../inclu
               ../../../src/libCom/bucketLib/__bucketLib.c
               ../../../src/libCom/bucketLib/__bucketLib.c: В функции
           <ITEM**
               bucketStringCompare(ITEM**, const void*)>:
               ../../../src/libCom/bucketLib/__bucketLib.c:125:21:
           предупреждение:
               некорректное преобразование из <const void*> в <const
               char*> [-fpermissive]
           <BUCKETID
               bucketUnsignedHash(BUCKET*, const void*)>:
               ../../../src/libCom/bucketLib/__bucketLib.c:147:25:
           предупреждение:
               unsigned int*> [-fpermissive]
           <BUCKETID
               bucketStringHash(BUCKET*, const void*)>:
               ../../../src/libCom/bucketLib/__bucketLib.c:197:21:
           предупреждение:
               -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I../../../src
               /libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/__posix
               -I../../../src/libCom/cvtFast -I../../../src/libCom/cppS
               td -I../../../src/libCom/__cxxTemplates
               -I../../../src/libCom/ellLib -I../../../src/libCom/env
           -I../../
               -I../../../inclu
               ../../../src/libCom/ring/__epicsRingPointer.cpp
           -I../../
               -I../../../inclu
               ../../../src/libCom/ring/__epicsRingBytes.c
               ../../../src/libCom/ring/__epicsRingBytes.c: В функции
           <void*
               epicsRingBytesCreate(int)>:
               ../../../src/libCom/ring/__epicsRingBytes.c:42:78:
           предупреждение:
               некорректное преобразование из <void*> в <ringPvt* {aka
                ringPvt*}> [-fpermissive]
               ../../../src/libCom/ring/__epicsRingBytes.c:44:63:
           предупреждение:
               некорректное преобразование из <void*> в <volatile char
               *> [-fpermissive]
           -I../../
               -I../../../inclu
               ../../../src/libCom/calc/__postfix.c
               ../../../src/libCom/calc/__postfix.c:129:1: предупреждение:
               deprecated conversion from string constant to <char*>
           [-Wwrite
               -strings]
               ../../../src/libCom/calc/__postfix.c:163:1: предупреждение:
           [-Wwrite
               -strings]
               ../../../src/libCom/calc/__postfix.c: В функции <long int
               postfix(const char*, char*, short int*)>:
               ../../../src/libCom/calc/__postfix.c:272:42: предупреждение:
               некорректное преобразование из <int> в <rpn_opcode>
           [-fpermis
               sive]
           -I../../
               -I../../../inclu
               ../../../src/libCom/calc/__calcPerform.c
           -I../../
               -I../../../inclu
               ../../../src/libCom/cvtFast/__cvtFast.c
           -I../../
               -I../../../inclu
               ../../../src/libCom/__cxxTemplates/resourceLib.cpp
           -I../../
               ../../../src/libCom/__cxxTemplates/epicsOnce.cpp
               In file included from
               ../../../src/libCom/__cxxTemplates/epicsOnce.cpp:29:__0:
             ../../../src/libCom/__cxxTemplates/epicsSingleton.h:__37:5: ошибка:
           <size_t> не является именем типа
               ../../../src/libCom/__cxxTemplates/epicsSingleton.h: In
           constructor
           <SingletonUntyped::__SingletonUntyped()>:
             ../../../src/libCom/__cxxTemplates/epicsSingleton.h:__162:23: ошибка:
               в классе <SingletonUntyped> не имеет поля с именем
           <_refCount>
               mingw32-make[3]: *** [epicsOnce.o] Error 1
               mingw32-make[3]: Leaving directory
             `C:/epics/base/bin/win32-x86-__mingw/src/libCom/O.win32-x86-__mingw'
               mingw32-make[2]: *** [install.win32-x86-mingw] Error 2
               mingw32-make[2]: Leaving directory
               `C:/epics/base/bin/win32-x86-__mingw/src/libCom'
               mingw32-make[1]: *** [libCom.install] Error 2
               mingw32-make[1]: Leaving directory
               `C:/epics/base/bin/win32-x86-__mingw/src'
               mingw32-make: *** [src.install] Error 2
               mingw32-make: Leaving directory
           `C:/epics/base/bin/win32-x86-__mingw'
               On Sun, Dec 4, 2011 at 11:46 PM, Mark Rivers
           <[email protected] <mailto:[email protected].edu>
           <mailto:[email protected].__edu
           <mailto:[email protected].edu>>> wrote:
                   I don't know about the problem with softIoc.  Where
           is it
                   getting those single quotes?
                   Did you try my suggestion of -fpermissive when
           building with
                   MinGW?  I think it should have at least eliminated
           the error
                   you reported.
                   __________________________________
           [mailto:pavel.masloff@gmail.__com
           <mailto:pavel.masloff@gmail.com>
           <mailto:pavel.masloff@gmail.__com
           <mailto:pavel.masloff@gmail.com>>]
                   Sent: Sun 12/4/2011 1:48 PM
                   To: Mark Rivers
                   Cc: [email protected]
           <mailto:[email protected]>>__;
           <mailto:[email protected] <mailto:[email protected]>>
                   Hey Mark,
                   The base I am trying to build is 3.14.12.1.
                   Mingw32-make didn't work. So i tried Microsoft
           Visual Studio
                   2010 Express. The compilation ended successfully
           with a few
                   warnings.
                   However, when I try to run softIoc.exe, I see the
           following error:
                   d:\>softIoc
           'D:\baseR3.14.12.1\new'/dbd/__softIoc.dbd
                   Pavel
                   On Sat, Dec 3, 2011 at 1:26 AM, Mark Rivers
                   wrote:
                          Hi Pavel,
                          What version of base is this?
                          I think you can avoid this error by adding
           this line to
             base/configure/os/CONFIG_SITE.__win32-x86-mingw.win32-x86-__mingw
                          USR_CFLAGS += -fpermissive
                          USR_CXXFLAGS += -fpermissive
                          But if this is the latest version of base
           then I think
                   there is an error that should be fixed.
                          __________________________________________
                          Sent: Friday, December 02, 2011 4:13 PM
                          To: Mark Rivers
           <mailto:[email protected]>>__; [email protected]
                          Mark,
                          I did what you'd proposed.
                          This is what i get:
                   -I../../../src/libCom/osi/os/__posix -I../../../src/libC
                          m/osi/os/default -I..
                          rc/libCom/cvtFast -I../../../src/libCom/cppStd
                   -I../../..
                   -I../../../src/libC
                   -I../../../src/libC
                   -I../../../include        ../Com.rc Com.coff
               -m32
                   -I../../.
                          /src/libCom/cxxTemplates
                   -I../../../s
                   -I../../../src/l
                          I../../../include
           In function
           <ITEM** bucketStringCompare(ITEM**, const void*)>:
                   error: incorrect transform from <const void*> to
           <const char*>
                          -fpermissive]
           in function
           <BUCKETID bucketUnsignedHash(BUCKET*, const void*)>:
           <const unsigne
           In function
           <BUCKETID bucketStringHash(BUCKET*, const void*)>:
           <const char*>
                          -fpermissive]
                          mingw32-make[3]: *** [bucketLib.o] Error 1
                          On Sat, Dec 3, 2011 at 12:45 AM, Mark Rivers
                   wrote:
                          Hi Pavel,
                          I understand now.  I thought you were just
           using MinGW
                   for gnumake.  But you want to use the gcc compiler
           as well.
                          You have set the wrong value for
           EPICS_HOST_ARCH.  You
                   have set it to win32-x86, which is the architecture that
                   requires Visual Studio.
                          You need to set the environment variable
                   EPICS_HOST_ARCH to win32-x86-mingw.  That will use gcc.
                          Sent: Friday, December 02, 2011 3:41 PM
                          To: Mark Rivers; [email protected]
                          Hi Mark,
                          Do I really need MS Visual Studio?
                          According to this
             (http://www.aps.anl.gov/epics/__base/win32.phphttp://www.aps.__anl.gov/epics/base/win32.php <http://www.aps.anl.gov/epics/base/win32.phphttp://www.aps.anl.gov/epics/base/win32.php>):
                          Download and install a compiler:
                          * Microsoft Visual C++ Express 2010, or
                          * MinGW version of GCC
                          * You can also use Microsoft's commercial C++
                   development tools if you have them.
                          I used MinGW. I see 'or' here.
                          On Sat, Dec 3, 2011 at 12:27 AM, Mark Rivers
                   wrote:
                          Hi Pavel,
                          I think the problem is that you have not set
           up your
                   environment for Visual Studio.  Your PATH
                   does not include the path to the Visual Studio
           compiler.  You
                   need to execute the "vcvarsall.bat file that comes
           with Visual
                   Studio.
                          This is the batch file I use to set up EPICS
           builds for
                   win32-x86.
                          rem This file sets up for an EPICS win32-x86
           build
                          set EPICS_HOST_ARCH=win32-x86
                          rem This is the location of "make"
                          set PATH=C:\Program
             Files\GnuWin32\bin;C:\Perl\__bin;H:\epics\base\bin\win32-__x86;%PATH%
           "C:\Program Files\Microsoft Visual Studio
                   9.0\VC\vcvarsall.bat" x86
           <mailto:tech-talk-bounces@aps.anl.gov>
           <mailto:tech-talk-bounces@aps.__anl.gov
           <mailto:tech-talk-bounces@aps.anl.gov>>
                   [mailto:tech-talk-bounces@aps.__anl.gov
           <mailto:tech-talk-bounces@aps.anl.gov>>] On Behalf Of Pavel
           Masloff
                          Sent: Friday, December 02, 2011 2:52 PM
                          To: [email protected]
           <mailto:[email protected]>>__; Dirk Zimoch;
                          Subject: [help] EPICS build no good
                          Hello,
                          This is my first attempt ever to build EPICS
           (and it's
                   the first time I try to compile something really
           big, as a
                   matter of fact).
                          In accordance with the following instructions
           <http://www.aps.anl.gov/epics/base/win32.php>) and
                   recommendations by Dirk Zimoch (thanks!), I tried to
           build
                   EPICS baseR3.14.12.1 on Windows 7 Starter using:
                          * ActiveState Perl
           (ActivePerl-5.14.2.1402-__MSWin32-x86)
                          This is what I get :
                          rc -l 0x409 -I. -I../O.Common -I.
                   -I../../../src/libCom/osi/os/__default -I.. -I../../.
                          ./src/libCom/bucketLib -I../../../src/libCom/ring
                   -I../../../sr
                          c/libCom/cppStd
                   -I../../../sr
                          c/libCom/env -I../../../src/libCom/error
                          m/gpHash -I../../../src/libCom/iocsh
                          misc -I../../../src/libCom/osi
                   -I../../../src/libCom/taskwd -I../../../src/libCom/timer
                   -I../../../src/libCom/tsDefs -I.
                 -fo
                   Com.res ../Com.rc
                          process_begin: CreateProcess(NULL, rc -l
           0x409 -I.
                   -I../O.Common -I. -I../../../src/libCom/osi/os/__WIN32
                   -I../../../src/l
                          ibCom/osi/os/default -I..
                   -I../..
                   -I../../../src/l
                   -I../../../src/l
                   -I../../../include/os/WIN32 -I../../../include -fo
           Com.res
                   ../Com.rc, ...) failed.
                          make (e=2): No such file.
                          mingw32-make[3]: *** [Com.res] Error 2
                   `C:/epics/base/bin/win32-x86/__src/libCom/O.win32-x86'
                          mingw32-make[2]: *** [install.win32-x86] Error 2
                   `C:/epics/base/bin/win32-x86/__src/libCom'
                   `C:/epics/base/bin/win32-x86/__src'
                   `C:/epics/base/bin/win32-x86'
                          Why can it be so? The same thing using GnuWin32:
                   -I../../../sr
                          c/libCom/cppStd
                   -I../../../sr
                 -fo
                   Com.res ../Com.rc
           0x409 -I.
                   -I../../../src/l
                   -I../..
                   -I../../../src/l
                   -I../../../src/l
           Com.res
                          I set the PATH Environment Variable to:
           C:\Perl\site\bin;C:\Perl\bin;%__SystemRoot%\system32;%__SystemRoot%;%SystemRoot%\__System32\Wbem;%SYSTEMROOT%\__System32\WindowsPowerShell\v1.__0\;C:\Program
                   Files\WIDCOMM\Bluetooth Software\;C:\Program
                   Files\QuickTime\QTSystem\;C:\__MinGW\bin;C:\GnuWin32\bin
                          I don't know if there was a need to do so.
           Because I
                   can see it's mentioned in the win32.bat file. Here's my
                   win32.bat (in the ming32-make case):
                          @ECHO OFF
                          REM
             ******************************__******************************__*************
                          REM  Copyright (c) 2002 The University of
           Chicago, as
                   Operator of Argonne
                          REM      National Laboratory.
                          REM  Copyright (c) 2002 The Regents of the
           University
                   of California, as
                          REM      Operator of Los Alamos National
           Laboratory.
                          REM  EPICS BASE Versions 3.13.7
                          REM  and higher are distributed subject to a
           Software
                   License Agreement found
                          REM  in file LICENSE that is included with this
                   distribution.
                          REM
                          REM  Revision-Id:
                   [email protected]__20110419162804-__n948b5t79d7ctygo
           <mailto:[email protected]__20110419162804-__n948b5t79d7ctygo
           <mailto:[email protected]20110419162804-n948b5t79d7ctygo>>
                          REM
                          REM  Site-specific EPICS environment settings
                          REM
                          REM  sites should modify these definitions
                          REM
           ==============================__========================
                          REM    ====== REQUIRED ENVIRONMENT VARIABLES
           FOLLOW ======
                          REM
                          REM
                          REM   ---------------- WINDOWS
                          REM
                          REM ----- WIN95 -----
                          REM set PATH=C:\WINDOWS;C:\WINDOWS\__COMMAND
                          REM ----- WINNT, WIN2000  -----
                          REM set PATH=C:\WINNT;C:\WINNT\__SYSTEM32
                          REM ----- WINXP, Vista, Windows 7 -----
                          set
             PATH=C:\WINDOWS\system32;C:\__WINDOWS;C:\WINDOWS\SYSTEM32\__Wbem
                          REM
                          REM   ---------------- make and perl
                          REM
                          REM   --------------- ActiveState perl
                          set PATH=C:\Perl\bin;%PATH%
                          REM    --------------- mingw make
                          set PATH=C:\mingw\bin;%PATH%
                          REM set PATH=C:\mingw-make82-3\bin;%__PATH%
                          REM   --------------- gnuwin32 make
                          REM set PATH=C:\gnuwin32\bin;%PATH%
                          REM
                          REM ---------------- cygwin tools
                          REM
                          REM    (make & perl if above perl and make
           are REMs)
                          REM    Dont use cygwin GNU make and Perl!
                          REM    cygwin contains tk/tcl, vim, perl, and
           many unix
                   tools
                          REM    need grep from here NOT from cvs directory
                          REM set PATH=%PATH%;.;..
                          REM set PATH=%PATH%;c:\cygwin\bin
                          REM
                          REM   --------------- Visual c++
                          REM
                          REM    ------ Microsoft Visual Studio 2005 ------
                          REM call "C:\Program files\Microsoft Visual
           Studio
                   8\VC\vcvarsall.bat" x86_amd64
                          REM set PATH=%PATH%;C:\Program Files\Microsoft
                   SDKs\Windows\v6.0A\bin
                          REM set INCLUDE=%INCLUDE%;C:\Program
           Files\Microsoft
                   SDKs\Windows\v6.0A\include
                          REM REM set LIBPATH=%LIBPATH%;C:\Program
                   Files\Microsoft SDKs\Windows\v6.0A\lib
                          REM set LIB=%LIB%;C:\Program Files\Microsoft
                          REM    ------ Microsoft Visual Studio 2008 ------
           Studio
                   9.0\VC\bin\vcvars32.bat"
           Studio
                   9.0\VC\vcvarsall.bat" x86_amd64
                          REM set    PATH=C:\Program Files\Microsoft
                   SDKs\Windows\v7.0\bin;%PATH%
                          REM set INCLUDE=C:\Program Files\Microsoft
                   SDKs\Windows\v7.0\include;%__INCLUDE%
                          REM set LIBPATH=C:\Program Files\Microsoft
                   SDKs\Windows\v7.0\lib;%__LIBPATH%
                          REM set     LIB=C:\Program Files\Microsoft
                   SDKs\Windows\v7.0\lib;%LIB%
                          REM    ----- Visual Studion 2010 -----
                          REM --  windows-x64 ---
           Studio
                   10.0\VC\vcvarsall.bat" x64
                          REM --  win32-x86 ---
           Studio
                   10.0\VC\vcvarsall.bat" x86
                          REM
                          REM --------------- EPICS
           ------------------------------__--
                          REM
                          REM set EPICS_HOST_ARCH=windows-x64
                          set
           PATH=%PATH%;C:\epics\base\bin\__%EPICS_HOST_ARCH%
                          REM set
             PATH=%PATH%;G:\epics\__extensions\bin\%EPICS_HOST___ARCH%
                          REM
                          REM ------- OPTIONAL ENVIRONMENT VARIABLES
           FOLLOW --------
                          REM
                          REM
                          REM ----------------- remote CVS
                          REM
                          REM set CVS_RSH=c:/cygwin/bin/ssh.exe
                          REM set
             CVSROOT=:ext:[email protected]:/__usr/local/epicsmgr/cvsroot
           <mailto:CVSROOT
           <mailto:CVSROOT>=:ext:jba@aps.__anl.gov:/usr/local/epicsmgr/__cvsroot>
                          REM set HOME=c:/users/%USERNAME%
                          REM set HOME=c:/users/jba
                          REM
                          REM ------------------- Bazaar
                          REM
                          REM set PATH=%PATH%;C:\Program files\Bazaar
                          REM
                          REM ----------------- GNU make flags
                          REM
                          set MAKEFLAGS=-w
                          REM
                          REM -------------- vim (use cygwin vim )
                          REM
                          REM HOME needed by vim to write .viminfo file.
                          REM VIM needed by vim to find _vimrc file.
                          REM set VIM=c:\cygwin
                          REM
                          REM --------------- Epics Channel Access
                          REM    Modify and uncomment the following lines
                          REM    to override the
           base/configure/CONFIG_ENV defaults
                          REM
                          REM set EPICS_CA_ADDR_LIST=n.n.n.n  n.n.n.n
                          REM set EPICS_CA_AUTO_ADDR_LIST=YES
                          REM set EPICS_CA_CONN_TMO=30.0
                          REM set EPICS_CA_BEACON_PERIOD=15.0
                          REM set EPICS_CA_REPEATER_PORT=5065
                          REM set EPICS_CA_SERVER_PORT=5064
                          REM set EPICS_TS_MIN_WEST=420
                          REM
                          REM --------------- JAVA
           ------------------------------__---
                          REM
                          REM    Needed for java extensions
                          REM set CLASSPATH=G:\epics\extensions\__javalib
                          REM set PATH=%PATH%;C:\j2sdk1.4.1_01\__bin
                          REM set
                   CLASSPATH=%CLASSPATH%;C:\__j2sdk1.4.1_01\lib\tools.jar
                          REM
                          REM --------------- Exceed
                          REM    Needed for X11 extensions
                          REM
                          REM set EX_VER=7.10
                          REM set EX_VER=12.00
                          REM set EX_VER=14.00
                          REM set PATH=%PATH%;C:\Exceed%EX_VER%\__XDK\
                   Files\Hummingbird\__Connectivity\%EX_VER%\Exceed\
                          Didn't change anything else. I think I missed
                   something. What do you think I've missed?
                          Thank you.
                          Sincerely,
                          Pavel Maslov, MSc
                          R&D Institute for Electro-Physical Apparatus
                          Mobile: +7 (951) 672 22 19
                          Phone: +7 (812) 461 01 01
                          Sincerely,
                          Pavel Maslov, MSc
                          Sincerely,
                          Pavel Maslov, MSc
                   Sincerely,
                   Pavel Maslov, MSc
               Sincerely,
               Pavel Maslov, MSc
       Sincerely,
       Pavel Maslov, MSc
Sincerely,
Pavel Maslov, MSc
Sincerely,
Pavel Maslov, MSc
[help] EPICS build no good Pavel Masloff
RE: [help] EPICS build no good Mark Rivers
Re: [help] EPICS build no good Pavel Masloff
Re: [help] EPICS build no good Geoff Savage
Prev: Re: [help] EPICS build no good Geoff Savage
Next: Re: [help] EPICS build no good Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
