Check everything. Sometimes you have to start again from scratch.
For example, are you positive you are using the compilers from the mingw
installation? All I see in the output is g++. This might explain why
-fpermissive did not work.
Geoff
On 12/5/2011 10:16 AM, Pavel Masloff wrote:
it had been set so prior
2011/12/5 Janet Anderson <[email protected] <mailto:[email protected]>>
__
Looks like the definitions of CC and CCC are incorrect. Try
setting CC=gcc and CCC=g++ in
configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw.
Janet
Hey Mark,
I don't know where this error comes from (the single quotes). I
thought running softIoc.exe is a simple way to check the
installation.
No, your suggestions didn't work (sorry, partly in Russian, I can
translate if you need):
"Installing generic include file ../../../include/tsDefs.h"
windres -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32
-I../../../src/libCom/osi/os/posix
-I../../../src/libCom/osi/os/default -I..
-I../../../src/libCom/bucketLib -I../../../src/libCom/ring
-I../../../src/libCom/calc -I../../../src/libCom/cvtFast
-I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
-I../../../src/libCom/dbmf -I../../../
src/libCom/ellLib -I../../../src/libCom/env
-I../../../src/libCom/error -I../../../src/libCom/fdmgr
-I../../../src/libCom/freeList -I../../../src/libCom/gpHash
-I../../../src/libCom/iocsh -I../../../src/libCom/logClient
-I../../../src/libCom/macLib -I../../../src/libCom/misc
-I../../../src/libCom/osi -I../../../src/libCom/taskwd
-I../../../src/libCom/timer -I../../../src/libCom/tsDefs
-I../../../include/os/WIN32 -I../../../include ../Com.rc
Com.coff
g++ -c -D_MINGW -O3 -Wall -fpermissive
-m32 -D_DLL -MMD -I. -I../O.Common -I.
-I../../../src/libCom/dbmf -I../../../src/libCom/ellLib
-I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I..
-I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../
-I../../../inclu
../../../src/libCom/bucketLib/bucketLib.c
../../../src/libCom/bucketLib/bucketLib.c: В функции <ITEM**
bucketStringCompare(ITEM**, const void*)>:
../../../src/libCom/bucketLib/bucketLib.c:125:21: предупреждение:
некорректное преобразование из <const void*> в <const
char*> [-fpermissive]
../../../src/libCom/bucketLib/bucketLib.c: В функции <BUCKETID
bucketUnsignedHash(BUCKET*, const void*)>:
../../../src/libCom/bucketLib/bucketLib.c:147:25: предупреждение:
unsigned int*> [-fpermissive]
bucketStringHash(BUCKET*, const void*)>:
../../../src/libCom/bucketLib/bucketLib.c:197:21: предупреждение:
-m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src
/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/posix
-I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/
bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc
-I../../../src/libCom/cvtFast -I../../../src/libCom/cppS
td -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf
-I../../../src/libCom/ellLib -I../../../src/libCom/env
-I../../../inclu
../../../src/libCom/ring/epicsRingPointer.cpp
-I../../../inclu
../../../src/libCom/ring/epicsRingBytes.c
../../../src/libCom/ring/epicsRingBytes.c: В функции <void*
epicsRingBytesCreate(int)>:
../../../src/libCom/ring/epicsRingBytes.c:42:78: предупреждение:
некорректное преобразование из <void*> в <ringPvt* {aka
ringPvt*}> [-fpermissive]
../../../src/libCom/ring/epicsRingBytes.c:44:63: предупреждение:
некорректное преобразование из <void*> в <volatile char
*> [-fpermissive]
-I../../../inclu
../../../src/libCom/calc/postfix.c
../../../src/libCom/calc/postfix.c:129:1: предупреждение:
deprecated conversion from string constant to <char*> [-Wwrite
-strings]
../../../src/libCom/calc/postfix.c:163:1: предупреждение:
-strings]
../../../src/libCom/calc/postfix.c: В функции <long int
postfix(const char*, char*, short int*)>:
../../../src/libCom/calc/postfix.c:272:42: предупреждение:
некорректное преобразование из <int> в <rpn_opcode> [-fpermis
sive]
-I../../../inclu
../../../src/libCom/calc/calcPerform.c
-I../../../inclu
../../../src/libCom/cvtFast/cvtFast.c
-I../../../inclu
../../../src/libCom/cxxTemplates/resourceLib.cpp
../../../src/libCom/cxxTemplates/epicsOnce.cpp
In file included from
../../../src/libCom/cxxTemplates/epicsOnce.cpp:29:0:
../../../src/libCom/cxxTemplates/epicsSingleton.h:37:5: ошибка:
<size_t> не является именем типа
../../../src/libCom/cxxTemplates/epicsSingleton.h: In constructor
<SingletonUntyped::SingletonUntyped()>:
../../../src/libCom/cxxTemplates/epicsSingleton.h:162:23: ошибка:
в классе <SingletonUntyped> не имеет поля с именем <_refCount>
mingw32-make[3]: *** [epicsOnce.o] Error 1
mingw32-make[3]: Leaving directory
`C:/epics/base/bin/win32-x86-mingw/src/libCom/O.win32-x86-mingw'
mingw32-make[2]: *** [install.win32-x86-mingw] Error 2
mingw32-make[2]: Leaving directory
`C:/epics/base/bin/win32-x86-mingw/src/libCom'
mingw32-make[1]: *** [libCom.install] Error 2
mingw32-make[1]: Leaving directory
`C:/epics/base/bin/win32-x86-mingw/src'
mingw32-make: *** [src.install] Error 2
mingw32-make: Leaving directory `C:/epics/base/bin/win32-x86-mingw'
On Sun, Dec 4, 2011 at 11:46 PM, Mark Rivers
<[email protected] <mailto:[email protected]>> wrote:
I don't know about the problem with softIoc. Where is it
getting those single quotes?
Did you try my suggestion of -fpermissive when building with
MinGW? I think it should have at least eliminated the error
you reported.
<mailto:[email protected]>]
Sent: Sun 12/4/2011 1:48 PM
To: Mark Rivers
Cc: [email protected] <mailto:[email protected]>;
Subject: Re: [help] EPICS build no good
Hey Mark,
The base I am trying to build is 3.14.12.1.
Mingw32-make didn't work. So i tried Microsoft Visual Studio
2010 Express. The compilation ended successfully with a few
warnings.
However, when I try to run softIoc.exe, I see the following error:
d:\>softIoc
filename="..\dbLexRoutines.c" line number=243
Invalid argument dbRead opening file
'D:\baseR3.14.12.1\new'/dbd/softIoc.dbd
Pavel
On Sat, Dec 3, 2011 at 1:26 AM, Mark Rivers
wrote:
Hi Pavel,
What version of base is this?
I think you can avoid this error by adding this line to
base/configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw
USR_CFLAGS += -fpermissive
USR_CXXFLAGS += -fpermissive
But if this is the latest version of base then I think
there is an error that should be fixed.
Sent: Friday, December 02, 2011 4:13 PM
To: Mark Rivers
<mailto:[email protected]>; [email protected]
Mark,
I did what you'd proposed.
This is what i get:
-I../../../src/libCom/osi/os/posix -I../../../src/libC
m/osi/os/default -I.. -I../../../src/libCom/bucketLib
-I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../
rc/libCom/cvtFast -I../../../src/libCom/cppStd
-I../../..
-I../../../src/libC
-I../../../src/libC
I../../../src/libCom/tsDefs -I../../../include/os/WIN32
-I../../../include ../Com.rc Com.coff
g++ -c -D_MINGW -O3 -Wall -m32
-D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/
-I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd
-I../../.
-I../../../s
-I../../../src/l
I../../../include
../../../src/libCom/bucketLib/bucketLib.c: In function
<ITEM** bucketStringCompare(ITEM**, const void*)>:
error: incorrect transform from <const void*> to <const char*>
-fpermissive]
../../../src/libCom/bucketLib/bucketLib.c: in function
<BUCKETID bucketUnsignedHash(BUCKET*, const void*)>:
error: incorrect transform from <const void*> to <const unsigne
<BUCKETID bucketStringHash(BUCKET*, const void*)>:
-fpermissive]
mingw32-make[3]: *** [bucketLib.o] Error 1
On Sat, Dec 3, 2011 at 12:45 AM, Mark Rivers
wrote:
Hi Pavel,
I understand now. I thought you were just using MinGW
for gnumake. But you want to use the gcc compiler as well.
You have set the wrong value for EPICS_HOST_ARCH. You
have set it to win32-x86, which is the architecture that
requires Visual Studio.
You need to set the environment variable
EPICS_HOST_ARCH to win32-x86-mingw. That will use gcc.
Sent: Friday, December 02, 2011 3:41 PM
To: Mark Rivers; [email protected]
Hi Mark,
Do I really need MS Visual Studio?
According to this
(http://www.aps.anl.gov/epics/base/win32.phphttp://www.aps.anl.gov/epics/base/win32.php):
Download and install a compiler:
* Microsoft Visual C++ Express 2010, or
* MinGW version of GCC
* You can also use Microsoft's commercial C++
development tools if you have them.
I used MinGW. I see 'or' here.
On Sat, Dec 3, 2011 at 12:27 AM, Mark Rivers
wrote:
Hi Pavel,
I think the problem is that you have not set up your
environment for Visual Studio. Your PATH environment variable
does not include the path to the Visual Studio compiler. You
need to execute the "vcvarsall.bat file that comes with Visual
Studio.
This is the batch file I use to set up EPICS builds for
win32-x86.
rem This file sets up for an EPICS win32-x86 build
set EPICS_HOST_ARCH=win32-x86
rem This is the location of "make"
set PATH=C:\Program
Files\GnuWin32\bin;C:\Perl\bin;H:\epics\base\bin\win32-x86;%PATH%
"C:\Program Files\Microsoft Visual Studio
9.0\VC\vcvarsall.bat" x86
[mailto:[email protected]
<mailto:[email protected]>] On Behalf Of Pavel Masloff
Sent: Friday, December 02, 2011 2:52 PM
To: [email protected]
<mailto:[email protected]>; Dirk Zimoch; [email protected]
Subject: [help] EPICS build no good
Hello,
This is my first attempt ever to build EPICS (and it's
the first time I try to compile something really big, as a
matter of fact).
In accordance with the following instructions
(http://www.aps.anl.gov/epics/base/win32.php) and
recommendations by Dirk Zimoch (thanks!), I tried to build
EPICS baseR3.14.12.1 on Windows 7 Starter using:
* ActiveState Perl (ActivePerl-5.14.2.1402-MSWin32-x86)
This is what I get :
rc -l 0x409 -I. -I../O.Common -I.
-I../../../sr
-I../../../sr
c/libCom/env -I../../../src/libCom/error
-I../../../src/libCom/fdmgr -I../../../src/libCom/freeList
m/gpHash -I../../../src/libCom/iocsh
-I../../../src/libCom/logClient -I../../../src/libCom/macLib
misc -I../../../src/libCom/osi
-I../../../src/libCom/taskwd -I../../../src/libCom/timer
-I../../../src/libCom/tsDefs -I.
./../../include/os/WIN32 -I../../../include -fo
Com.res ../Com.rc
process_begin: CreateProcess(NULL, rc -l 0x409 -I.
-I../../../src/l
-I../..
-I../../../src/l
-I../../../src/l
-I../../../include/os/WIN32 -I../../../include -fo Com.res
../Com.rc, ...) failed.
make (e=2): No such file.
mingw32-make[3]: *** [Com.res] Error 2
`C:/epics/base/bin/win32-x86/src/libCom/O.win32-x86'
mingw32-make[2]: *** [install.win32-x86] Error 2
`C:/epics/base/bin/win32-x86/src/libCom'
`C:/epics/base/bin/win32-x86/src'
`C:/epics/base/bin/win32-x86'
Why can it be so? The same thing using GnuWin32:
-I../../../sr
-I../../../sr
Com.res ../Com.rc
-I../../../src/l
-I../..
-I../../../src/l
-I../../../src/l
make: Leaving directory `C:/epics/base/bin/win32-x86'
I set the PATH Environment Variable to:
C:\Perl\site\bin;C:\Perl\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program
Files\WIDCOMM\Bluetooth Software\;C:\Program
Files\QuickTime\QTSystem\;C:\MinGW\bin;C:\GnuWin32\bin
I don't know if there was a need to do so. Because I
can see it's mentioned in the win32.bat file. Here's my
win32.bat (in the ming32-make case):
@ECHO OFF
REM
REM Copyright (c) 2002 The University of Chicago, as
Operator of Argonne
REM National Laboratory.
REM Copyright (c) 2002 The Regents of the University
of California, as
REM Operator of Los Alamos National Laboratory.
REM EPICS BASE Versions 3.13.7
REM and higher are distributed subject to a Software
License Agreement found
REM in file LICENSE that is included with this
distribution.
REM
REM Revision-Id:
[email protected]
REM
REM Site-specific EPICS environment settings
REM
REM sites should modify these definitions
REM ======================================================
REM ====== REQUIRED ENVIRONMENT VARIABLES FOLLOW ======
REM ---------------- WINDOWS ---------------------------
REM ----- WIN95 -----
REM set PATH=C:\WINDOWS;C:\WINDOWS\COMMAND
REM ----- WINNT, WIN2000 -----
REM set PATH=C:\WINNT;C:\WINNT\SYSTEM32
REM ----- WINXP, Vista, Windows 7 -----
set
PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\SYSTEM32\Wbem
REM ---------------- make and perl ---------------------
REM --------------- ActiveState perl -------------------
set PATH=C:\Perl\bin;%PATH%
REM --------------- mingw make ------------------------
set PATH=C:\mingw\bin;%PATH%
REM set PATH=C:\mingw-make82-3\bin;%PATH%
REM --------------- gnuwin32 make ----------------------
REM set PATH=C:\gnuwin32\bin;%PATH%
REM ---------------- cygwin tools ------------------------
REM (make & perl if above perl and make are REMs)
REM Dont use cygwin GNU make and Perl!
REM cygwin contains tk/tcl, vim, perl, and many unix
tools
REM need grep from here NOT from cvs directory
REM set PATH=%PATH%;.;..
REM set PATH=%PATH%;c:\cygwin\bin
REM --------------- Visual c++ -------------------------
REM ------ Microsoft Visual Studio 2005 ------
REM call "C:\Program files\Microsoft Visual Studio
8\VC\vcvarsall.bat" x86_amd64
REM set PATH=%PATH%;C:\Program Files\Microsoft
SDKs\Windows\v6.0A\bin
REM set INCLUDE=%INCLUDE%;C:\Program Files\Microsoft
SDKs\Windows\v6.0A\include
REM REM set LIBPATH=%LIBPATH%;C:\Program
Files\Microsoft SDKs\Windows\v6.0A\lib
REM set LIB=%LIB%;C:\Program Files\Microsoft
REM ------ Microsoft Visual Studio 2008 ------
9.0\VC\bin\vcvars32.bat"
9.0\VC\vcvarsall.bat" x86_amd64
REM set PATH=C:\Program Files\Microsoft
SDKs\Windows\v7.0\bin;%PATH%
REM set INCLUDE=C:\Program Files\Microsoft
SDKs\Windows\v7.0\include;%INCLUDE%
REM set LIBPATH=C:\Program Files\Microsoft
SDKs\Windows\v7.0\lib;%LIBPATH%
REM set LIB=C:\Program Files\Microsoft
SDKs\Windows\v7.0\lib;%LIB%
REM ----- Visual Studion 2010 -----
REM -- windows-x64 ---
10.0\VC\vcvarsall.bat" x64
REM -- win32-x86 ---
10.0\VC\vcvarsall.bat" x86
REM --------------- EPICS --------------------------------
REM set EPICS_HOST_ARCH=windows-x64
set PATH=%PATH%;C:\epics\base\bin\%EPICS_HOST_ARCH%
REM set
PATH=%PATH%;G:\epics\extensions\bin\%EPICS_HOST_ARCH%
REM ------- OPTIONAL ENVIRONMENT VARIABLES FOLLOW --------
REM ----------------- remote CVS -------------------------
REM set CVS_RSH=c:/cygwin/bin/ssh.exe
REM set
CVSROOT=:ext:[email protected]:/usr/local/epicsmgr/cvsroot
<mailto:CVSROOT=:ext:[email protected]:/usr/local/epicsmgr/cvsroot>
REM set HOME=c:/users/%USERNAME%
REM set HOME=c:/users/jba
REM ------------------- Bazaar ---------------------------
REM set PATH=%PATH%;C:\Program files\Bazaar
REM ----------------- GNU make flags ---------------------
set MAKEFLAGS=-w
REM -------------- vim (use cygwin vim ) -----------------
REM HOME needed by vim to write .viminfo file.
REM VIM needed by vim to find _vimrc file.
REM set VIM=c:\cygwin
REM --------------- Epics Channel Access -----------------
REM Modify and uncomment the following lines
REM to override the base/configure/CONFIG_ENV defaults
REM set EPICS_CA_ADDR_LIST=n.n.n.n n.n.n.n
REM set EPICS_CA_AUTO_ADDR_LIST=YES
REM set EPICS_CA_CONN_TMO=30.0
REM set EPICS_CA_BEACON_PERIOD=15.0
REM set EPICS_CA_REPEATER_PORT=5065
REM set EPICS_CA_SERVER_PORT=5064
REM set EPICS_TS_MIN_WEST=420
REM --------------- JAVA ---------------------------------
REM Needed for java extensions
REM set CLASSPATH=G:\epics\extensions\javalib
REM set PATH=%PATH%;C:\j2sdk1.4.1_01\bin
REM set
CLASSPATH=%CLASSPATH%;C:\j2sdk1.4.1_01\lib\tools.jar
REM --------------- Exceed -------------------------------
REM Needed for X11 extensions
REM set EX_VER=7.10
REM set EX_VER=12.00
REM set EX_VER=14.00
REM set PATH=%PATH%;C:\Exceed%EX_VER%\XDK\
Files\Hummingbird\Connectivity\%EX_VER%\Exceed\
Didn't change anything else. I think I missed
something. What do you think I've missed?
Thank you.
Sincerely,
Pavel Maslov, MSc
R&D Institute for Electro-Physical Apparatus
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
Sincerely,
Pavel Maslov, MSc
Sincerely,
Pavel Maslov, MSc
Sincerely,
Pavel Maslov, MSc
Sincerely,
Pavel Maslov, MSc
Sincerely,
Pavel Maslov, MSc
- [help] EPICS build no good Pavel Masloff
- RE: [help] EPICS build no good Mark Rivers
- Re: [help] EPICS build no good Pavel Masloff
<2011>
<2011>
