I am going to guess that moving the "#include <ctime>" to be first in the
stack as follows might take care of this, and that this might be less of a
mess (messes accumulate) compared to interspersing the import from namespace
std into the middle of the #include list which might cause issues on other
compilers.
#include <ctime>
#include <cstddef>
#include <cstdio>
#include <cmath>
#include <climits>
#include <cstring>
We have, it seems, one of everything old here including an old Solaris
machine so I was trying to reproduce the issue here. The old perl upgrade
install on our old solaris is finally done. Now the EPICS R3.14 latest build
is failing I suspect because gnu make 3.79.1 is installed. Hopefully will
get this reproduced soon on Monday. However, if you can try the above idea
first it might be easier and faster.
The order of the include statements has no effect. What I did to solve
the problem is to move the namespace import in front of all imports:
using namespace std;
#include <cstddef>
#include <cstdio>
#include <ctime>
#include <cmath>
#include <climits>
#include <cstring>
#include "epicsTime.h"
#include "epicsThread.h"
#include "errlog.h"
#include "epicsUnitTest.h"
#include "testMain.h"
Dirk
PS: Yes, the perl and make upgrade is a pain. That is exactly why I did
not like the requirement for the new versions. One could also demand to
upgrade to a newer C++ compiler, but then maybe EPICS libraries would
not work together with the installed programs (e.g. EPICS-TCL interface).
- EPICS Base 3.14.12.2-rc1 available for testing Andrew Johnson
- Re: EPICS Base 3.14.12.2-rc1 available for testing Dirk Zimoch
- RE: EPICS Base 3.14.12.2-rc1 available for testing Jeff Hill
Re: [help] EPICS build no good Pavel Masloff
problem using shell command in EDM Maurizio Montis
<2011>
Micro Research cPCI EVG support (request) Michael Davidsaver
<2011>
