This is my first attempt ever to build EPICS (and it's the first time I try to compile something really big, as a matter of fact). In accordance with the following instructions (http://www.aps.anl.gov/epics/base/win32.php) and recommendations by Dirk Zimoch (thanks!), I tried to build EPICS baseR3.14.12.1 on Windows 7 Starter using:
This is what I get : "Installing generic include file ../../../include/tsDefs.h" rc -l 0x409 -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../. ./src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../sr c/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../sr c/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCo m/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/ misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I. ./../../include/os/WIN32 -I../../../include -fo Com.res ../Com.rc process_begin: CreateProcess(NULL, rc -l 0x409 -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/l ibCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../ ../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../.. /../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/l ibCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/l ibCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/tim er -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include -fo Com.res ../Com.rc, ...) failed. make (e=2): No such file. mingw32-make[3]: *** [Com.res] Error 2 mingw32-make[3]: Leaving directory `C:/epics/base/bin/win32-x86/src/libCom/O.win32-x86' mingw32-make[2]: *** [install.win32-x86] Error 2 mingw32-make[2]: Leaving directory `C:/epics/base/bin/win32-x86/src/libCom' mingw32-make[1]: *** [libCom.install] Error 2 mingw32-make[1]: Leaving directory `C:/epics/base/bin/win32-x86/src' mingw32-make: *** [src.install] Error 2 mingw32-make: Leaving directory `C:/epics/base/bin/win32-x86' Why can it be so? The same thing using GnuWin32: "Installing generic include file ../../../include/tsDefs.h" rc -l 0x409 -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../. ./src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../sr c/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../sr c/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCo m/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/ misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I. ./../../include/os/WIN32 -I../../../include -fo Com.res ../Com.rc process_begin: CreateProcess(NULL, rc -l 0x409 -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/l ibCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../ ../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../.. /../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/l ibCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/l ibCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/tim er -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include -fo Com.res ../Com.rc, ...) failed. make (e=2): No such file. make[3]: *** [Com.res] Error 2 make[3]: Leaving directory `C:/epics/base/bin/win32-x86/src/libCom/O.win32-x86' make[2]: *** [install.win32-x86] Error 2 make[2]: Leaving directory `C:/epics/base/bin/win32-x86/src/libCom' make[1]: *** [libCom.install] Error 2 make[1]: Leaving directory `C:/epics/base/bin/win32-x86/src' make: *** [src.install] Error 2 make: Leaving directory `C:/epics/base/bin/win32-x86' I set the PATH Environment Variable to: C:\Perl\site\bin;C:\Perl\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;C:\Program Files\WIDCOMM\Bluetooth Software\;C:\Program Files\QuickTime\QTSystem\;C:\MinGW\bin;C:\GnuWin32\bin I don't know if there was a need to do so. Because I can see it's mentioned in the win32.bat file. Here's my win32.bat (in the ming32-make case): @ECHO OFF REM ************************************************************************* REM Copyright (c) 2002 The University of Chicago, as Operator of Argonne REM National Laboratory. REM Copyright (c) 2002 The Regents of the University of California, as REM Operator of Los Alamos National Laboratory. REM EPICS BASE Versions 3.13.7 REM and higher are distributed subject to a Software License Agreement found REM in file LICENSE that is included with this distribution. REM ************************************************************************* REM Revision-Id: [email protected] REM REM Site-specific EPICS environment settings REM REM sites should modify these definitions REM ====================================================== REM ====== REQUIRED ENVIRONMENT VARIABLES FOLLOW ====== REM ====================================================== REM ====================================================== REM ---------------- WINDOWS --------------------------- REM ====================================================== REM ----- WIN95 ----- REM set PATH=C:\WINDOWS;C:\WINDOWS\COMMAND REM ----- WINNT, WIN2000 ----- REM set PATH=C:\WINNT;C:\WINNT\SYSTEM32 REM ----- WINXP, Vista, Windows 7 ----- set PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\SYSTEM32\Wbem REM ====================================================== REM ---------------- make and perl --------------------- REM ====================================================== REM --------------- ActiveState perl ------------------- set PATH=C:\Perl\bin;%PATH% REM --------------- mingw make ------------------------ set PATH=C:\mingw\bin;%PATH% REM set PATH=C:\mingw-make82-3\bin;%PATH% REM --------------- gnuwin32 make ---------------------- REM set PATH=C:\gnuwin32\bin;%PATH% REM ====================================================== REM ---------------- cygwin tools ------------------------ REM ====================================================== REM (make & perl if above perl and make are REMs) REM Dont use cygwin GNU make and Perl! REM cygwin contains tk/tcl, vim, perl, and many unix tools REM need grep from here NOT from cvs directory REM set PATH=%PATH%;.;.. REM set PATH=%PATH%;c:\cygwin\bin REM ====================================================== REM --------------- Visual c++ ------------------------- REM ====================================================== REM ------ Microsoft Visual Studio 2005 ------ REM call "C:\Program files\Microsoft Visual Studio 8\VC\vcvarsall.bat" x86_amd64 REM set PATH=%PATH%;C:\Program Files\Microsoft SDKs\Windows\v6.0A\bin REM set INCLUDE=%INCLUDE%;C:\Program Files\Microsoft SDKs\Windows\v6.0A\include REM REM set LIBPATH=%LIBPATH%;C:\Program Files\Microsoft SDKs\Windows\v6.0A\lib REM set LIB=%LIB%;C:\Program Files\Microsoft SDKs\Windows\v6.0A\lib REM ------ Microsoft Visual Studio 2008 ------ REM call "C:\Program files\Microsoft Visual Studio 9.0\VC\bin\vcvars32.bat" REM call "C:\Program files\Microsoft Visual Studio 9.0\VC\vcvarsall.bat" x86_amd64 REM set PATH=C:\Program Files\Microsoft SDKs\Windows\v7.0\bin;%PATH% REM set INCLUDE=C:\Program Files\Microsoft SDKs\Windows\v7.0\include;%INCLUDE% REM set LIBPATH=C:\Program Files\Microsoft SDKs\Windows\v7.0\lib;%LIBPATH% REM set LIB=C:\Program Files\Microsoft SDKs\Windows\v7.0\lib;%LIB% REM ----- Visual Studion 2010 ----- REM -- windows-x64 --- REM call "C:\Program files\Microsoft Visual Studio 10.0\VC\vcvarsall.bat" x64 REM -- win32-x86 --- REM call "C:\Program files\Microsoft Visual Studio 10.0\VC\vcvarsall.bat" x86 REM ====================================================== REM --------------- EPICS -------------------------------- REM ====================================================== REM set EPICS_HOST_ARCH=windows-x64 set EPICS_HOST_ARCH=win32-x86 set PATH=%PATH%;C:\epics\base\bin\%EPICS_HOST_ARCH% REM set PATH=%PATH%;G:\epics\extensions\bin\%EPICS_HOST_ARCH% REM ====================================================== REM ------- OPTIONAL ENVIRONMENT VARIABLES FOLLOW -------- REM ====================================================== REM ====================================================== REM ----------------- remote CVS ------------------------- REM ====================================================== REM set CVS_RSH=c:/cygwin/bin/ssh.exe REM set CVSROOT=:ext:[email protected]:/usr/local/epicsmgr/cvsroot REM set HOME=c:/users/%USERNAME% REM set HOME=c:/users/jba REM ====================================================== REM ------------------- Bazaar --------------------------- REM ====================================================== REM set PATH=%PATH%;C:\Program files\Bazaar REM ====================================================== REM ----------------- GNU make flags --------------------- REM ====================================================== set MAKEFLAGS=-w REM ====================================================== REM -------------- vim (use cygwin vim ) ----------------- REM ====================================================== REM HOME needed by vim to write .viminfo file. REM VIM needed by vim to find _vimrc file. REM set VIM=c:\cygwin REM ====================================================== REM --------------- Epics Channel Access ----------------- REM Modify and uncomment the following lines REM to override the base/configure/CONFIG_ENV defaults REM ====================================================== REM set EPICS_CA_ADDR_LIST=n.n.n.n n.n.n.n REM set EPICS_CA_AUTO_ADDR_LIST=YES REM set EPICS_CA_CONN_TMO=30.0 REM set EPICS_CA_BEACON_PERIOD=15.0 REM set EPICS_CA_REPEATER_PORT=5065 REM set EPICS_CA_SERVER_PORT=5064 REM set EPICS_TS_MIN_WEST=420 REM ====================================================== REM --------------- JAVA --------------------------------- REM ====================================================== REM Needed for java extensions REM set CLASSPATH=G:\epics\extensions\javalib REM set PATH=%PATH%;C:\j2sdk1.4.1_01\bin REM set CLASSPATH=%CLASSPATH%;C:\j2sdk1.4.1_01\lib\tools.jar REM ====================================================== REM --------------- Exceed ------------------------------- REM Needed for X11 extensions REM ====================================================== REM set EX_VER=7.10 REM set EX_VER=12.00 REM set EX_VER=14.00 REM set PATH=%PATH%;C:\Exceed%EX_VER%\XDK\ REM set PATH=%PATH%;C:\Program Files\Hummingbird\Connectivity\%EX_VER%\Exceed\ Didn't change anything else. I think I missed something. What do you think I've missed? Thank you. -- Sincerely, Pavel Maslov, MSc R&D Institute for Electro-Physical Apparatus Mobile: +7 (951) 672 22 19 Phone: +7 (812) 461 01 01
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
