1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS Base 3.14.12.2-rc1 available for testing
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 30 Nov 2011 16:56:53 +0100
Andrew Johnson wrote:
The first release candidate for the 3.14.12.2 version of Base is now available on the website for general testing. Links to the tarfile and Release Notes can be found at http://www.aps.anl.gov/epics/base/R3-14/12.php Please report any problems you find to tech-talk. If no major issues are discovered before December 12th we will release 3.14.12.2 on that date.
Thanks to everyone who has helped with this process.
- Andrew
I tried it on my old sun solaris. It failed with:
/afs/psi.ch/sys/@sys/sepp/bin/CC -c -D_POSIX_C_SOURCE=199506L -D_XOPEN_SOURCE=500 -DUNIX -DSOLARIS=8 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I.. -I../../../include/os/solaris -I../../../include ../casw.cpp "../udpiiu.h", line 158: Error: Cannot declare a member of the abstract type udpiiu::M_repeaterTimerNotify.
"../casw.cpp", line 306: Warning: statement is unreachable.
1 Error(s) and 1 Warning(s) detected.
make[3]: *** [casw.o] Error 1
make[3]: Leaving directory `/afs/psi.ch/group/8431/dirk/solaris/base-3.14.12.2-rc1/src/ca/O.solaris-sparc'
make[2]: *** [install.solaris-sparc] Error 2
The reason is that the base class repeaterTimerNotify has a pure virtual destructor (virtual ~repeaterTimerNotify () = 0;) which is not overwritten by udpiiu::M_repeaterTimerNotify. Thus udpiiu::M_repeaterTimerNotify is still abstract and cannot be instantiated.
Add: ~M_repeaterTimerNotify () {};
I wonder why no other compiler complains? Even though the C++ standard states that the system will generate a destructor for you if you don't, declaring the destructor pure virtual in the base class clearly requests that the user defines one.
After fixing this I get:
/afs/psi.ch/sys/@sys/sepp/bin/CC -c -D_POSIX_C_SOURCE=199506L -D_XOPEN_SOURCE=500 -DUNIX -DSOLARIS=8 -mt -D__EXTENSIONS__ -O +w -I. -I../O.Common -I. -I.. -I../../../../include/os/solaris -I../../../../include ../epicsTimeTest.cpp "/usr/include/sys/time.h", line 50: Error: Type name expected instead of "time_t".
1 Error(s) detected.
make[3]: *** [epicsTimeTest.o] Error 1
The problem is a bug in the way the solaris compiler handles the standard C header file time.h when included from C++ via ctime. It hides the typedef long time_t; into namespace std and later in the same header file fails to find it.
To fix this, I had to move
using namespace std;
in front of
#include <ctime>
Next problem:
/afs/psi.ch/sys/@sys/sepp/bin/CC -c -D_POSIX_C_SOURCE=199506L -D_XOPEN_SOURCE=500 -DUNIX -DSOLARIS=8 -mt -D__EXTENSIONS__ -O +w -xcode=pic32 -I. -I../O.Common -I. -I.. -I../../../../src/cas/generic -I../../../../src/cas/io/bsdSocket -I../../../../src/cas/generic/st -I../../../../src/cas/../ca -I../../../../include/os/solaris -I../../../../include ../../../../src/cas/generic/st/casStreamOS.cc "../../../../src/cas/generic/st/casStreamOS.cc", line 304: Error: "casStreamOS::armRecv()" has already been called and cannot be defined inline.
make[4]: *** [casStreamOS.o] Error 1
Damn, why is this an error instead of a warning? Anyway:
Put inline void casStreamOS::armRecv() before casStreamIOWakeup::expire().
cap5 does not work at all because my perl version has been compiled with a different compiler and all the compiler options don't work. The reason was that I needed a newer perl version to compile EPICS than the one that was already installed. It seems the guy who compiled perl 5.8.8 used gcc instead of the system compiler.
Maybe the cap5/Makefile should check for compatibility between the current compiler and the options returned from perlConfig.pl (perlConfig.pl cc) or change not only CFLAGS but CC too.
Otherwise all is fine :-)
I successfully compiled for
vxWorks 5.5 ppc604 (aka Tornado 2.2)
vxWorks 6.3 ppc603 (used on cRIO)
vxWorks 6.7 ppc604
linux xscale_be (Montavista gcc version 3.4.3)
linux ppc405 (embedded in Virtex 5, Crosstool gcc version 4.0.2)
Scientific Linux 5.1 x86
Scientific Linux 6.0 x86_64
Scientific Linux 6.0 x86 (cross build on 64 bit machine)
For your info:
> perl -v
This is perl, v5.8.8 built for sun4-solaris
> perl perlConfig.pl cc
gcc
> /afs/psi.ch/sys/@sys/sepp/bin/cc -V
cc: Sun WorkShop 6 update 2 C 5.3 2001/05/15
> uname -a
SunOS pssvxw.psi.ch 5.8 Generic_108528-19 sun4u sparc SUNW,Sun-Blade-100
Dirk
RE: EPICS Base 3.14.12.2-rc1 available for testing Jeff Hill
EPICS Base 3.14.12.2-rc1 available for testing Andrew Johnson
Prev: Re: [help] degree in Computer Science/Software Engineering John Hammonds
Next: Re: EPICS Base 3.14.12.2-rc1 available for testing Pelaia II, Tom
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: EPICS Base 3.14.12.2-rc1 available for testing matthew.pearson
Next: RE: EPICS Base 3.14.12.2-rc1 available for testing Jeff Hill
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
