Pavel,
I agree with Dirk on many aspects especially that it is important to
understand what you are controlling as how to control it. I started out
with a Masters in Physics and evolved into controls. I have worked in
both small (Intense Pulsed Neutron Source) and large (Advanced Photon
Source) facilities,measuring size here by the number of people around to
interact with since IPNS was still a good sized facility. There are +/-
to both, the important thing is to try and find a place that you are
happy. If you are more of a self starter then you might do well in a
small facility. If you feel that you need more help getting started
then a large facility can be good since there are more folks around.
If you already have a background in something ( I assume that's how you
got where you are) then check out online courses in a field of
interest. I have been working for 20+ years and just recently went back
for some Software Engineering coursework (my degree is in Physics and I
only took FORTRAN in school). I found a nice program at the University
of Illinois in Urbana but these are available many places now. I never
had to step foot on campus. The courses that I took were driven by
group projects. This was interesting since none of us were at the
university and had to collaborate online. One semester our group even
had a student who lived in India. I was surprised at how easily this
worked out but his employer allowed him time in the morning that let him
mesh better with times most people worked on the projects in the US.
A couple of us have mentioned specific programs that we took but I do
not promote that there is anything magical about the courses that we
took that turn us into better controls people. These are just avenues
that expand our horizons. If school is the option then do your best to
find a program that best fits the interests of you and your employer
(this might encourage them to help with funding), although I suggest
that you weigh your interests higher.
Hope that this helps,
John
On 11/30/2011 3:36 AM, Dirk Zimoch wrote:
Hi Pavel,
Nuclear power plants are probably not the place where you can learn
how to build and maintain a control system. The strict approval process
of such a facility usually does not allow to change things once it is
running. The same is true for medical facilities, by the way. At a
particle accelerator one can be more "experimental". The machine
constantly changes even after years of operation, for example when
user beamlines are added or upgraded. Thus, the control system must be
modified, too.
If you want get more knowledge of the EPICS internals, I suggest to
put away CSS for a while and get into the 'command line cuisine' as
you called it. Compile EPICS on your own PC and start playing. For
example write a simulation of your power supplies and put the logic
into records instead of the PLC. Such a project requires more than the
monolayer of records you often get when interfacing with a PLC. You
will soon reach a challenging complexity.
Or get a real device and control it. If you don't have hardware like
VME crates, ADCs and so on to play with, a serial, USB or network
interface will do, too.
Maybe you can convince someone at your institute to set up the test
bench for the power supplies with EPICS and implement a automatic test
system?
In terms of formal education a course on plasma physics, nuclear
physics or similar at university level can provide a sound background
of what ITER is actually supposed to do. This is much more helpful
than a list of specifications, because at the end you do not just want
to control a power supply, you want to control a nuclear reaction.
Unfortunately, formal education on control systems simply does not exist.
Pavel Masloff wrote:
Hi Dirk,
Nice to hear from you again. You are right. Exactly. One should first
of all understand the control object. Did you work on the control
system all by yourself? Is it operating now?
By the time I started with the control system, there were 4 people
working on it. Three of them PhD students (two left the institute
during the next year) and one who became operations manager at about
the same time. Later two other diploma students joined the group.
At that time the control system was completely written in-house and
had no GUI. Only command line read and write commands. At about the
same time we got fist beam in the booster ring and found out quickly
that the control system needs much more features. We all had to run
shifts in the control room so we got a first hand experience of what
was missing.
So we, that is the 4 diploma and PhD students, decided to migrate the
control system to EPICS (version R3.13.0Beta12). That migration took
about one year and involved writing drivers as well as building the
logic for all types of devices used in an accelerator and finally
writing automated measurement and optimization programs. And GUIs of
course. Luckily, the old system was already based on VME and vxWorks,
the only choice for EPICS at that time.
One can learn a lot during this process, especially what to avoid. But
I can say it was never the control system that delayed progress. More
often we had hardware problems. So we had plenty of time to experiment
with the software. Many parts of the control system were actually
written during shifts whenever new features were needed or problems
were found. And yes, of course it is operating now.
Best regards,
Dirk
Control room! Absolutely! I was once in the control room of our
nuclear power plant in St. Petersburg. But it was more like an
excursion rather than continuous work. I am more interested not in
the HMI, though, but the underlying software, how signals are
acquired, transferred and processed, system architecture, which
sensors to use, how to link hardware with, say, EPICS.
I would like to work at some European or American lab to get some
experience before 2020 when we are supposed to deliver our equipment
to Cadarache. The thing is I don't have enough qualification, again,
to qualify. There is annual EPICS collaboration meeting. Perhaps,
this might be a good experience. Since it's not taught in college, as
Ned Arnold pointed out.
Pavel
On Mon, Nov 28, 2011 at 12:54 PM, Dirk Zimoch <[email protected]
<mailto:[email protected]>> wrote:
Hi Pavel,
In my experience it is more important to understand the application,
i.e. the machine and physics, than to have a degree in any field of
computer science. I have a degree in physics and am more or less
autodidact in programing. I came in contact with control systems and
real time computing when I started my diploma thesis on accelerator
physics. I was lucky that we had an electron synchrotron at our
university at Dortmund, Germany. I worked on the control system
during my diploma and PhD work.
When developing control system applications, I found it extremely
useful to have an understanding of the machine and underlying
physics. Another key to successfully develop control system
applications is to work in a control room or a working machine for
several months and be user of the control system. Then you learn
best what machine operators really need.
Best wishes,
Dirk
Dear colleagues!
A rather off-topic question to you. I would appreciate to hear
your answers, comments, advice.
I would love to get a Master's degree in the field specifically
related to what YOU guys do: EPICS, DAQ, creating interfaces for
scientific installations, writing drivers for hardware, linking
it to software, you name it. I have gotten a Bachelor's and a
Master's degrees in /Robotics /and /Automation and Control
/respectively. But, truth be told, the knowledge that I got
(general, I'd say, mediocre) doesn't have a lot to do with all
the work YOU do and which is yet to be done by me (as I have
decided) in my career as Control/Software Engineer.
Why would I need this? I am employed by the Efremov institute,
and our laboratory develops coil-power supply systems for the
ITER project (http://www.iter.org). I am responsible for the
control part. Here at the Institute I have all the opportunities
to gain knowledge related to electrical processes, apparatus, we
have got decent pulsed-power facilities, great engineers and
just nice people. However, the software/control area is
undeveloped and we lack software specialists who I can learn
from. Imagine, we are doing an international project, the level
of the hardware, say, is decent. OK. But in terms of software, I
must confess, we are not on the world level, which grieves me,
to be honest. Of course, I would like our institute to
competently fulfill Russia’s commitments towards ITER.
For this reason, I want to get a higher-education with focus on
software design, possibly science-oriented. Let me say a few
words about our contribution to ITER so as it will be clear
enough for you to understand what I need. As I mentioned, our
laboratory's scope of work includes creating coil-power supply
systems. One of the key function is to protect the TF, PF, CS,
CC coils by fast discharge of stored energy in case of a quench
or other type of fault event. Briefly, the information from the
sensors is processed by the Siemens S7 controllers, the time
sequence for the actuators (bypass switch, vaccuum
circuit-breaker, counter-pulse capacitor banks, pyrobreaker) is
realized by Siemens FM352 Fast Boolean processor. Our plant
system has to interact with the so-called CODAC control system,
which is based upon EPICS and CSS. Additionally, we have to
provide fast data for plasma stabilization.
With this in mind, as a developer, generally, I am not supposed
to know all the 'command line cuisine' - there is the CSS
framework, go program your PLCs and connect them to CODAC in
compliance with a readme. I had done it already and I want to go
beyond that.
I know there are lots of you on the list who are actually in
charge of CODAC, there are many guys from the US national
research laboratories. My message is addressed to you in the
first place. I would love it if you would tell me:
* what did you study (or studying) in college and where?
* which courses/classes do you find had helped you in your
current work?
* do you know any programs that provide sort of
internships at
national laboratories? (would be great if they were related
to ITER)
What are your thoughts about getting the required knowledge at
university (the other option would be working at a lab without
getting a degree)? In case of the latter where can one get such
experience?
Thank you and I look forward to hearing from you!
Sincerely,
Pavel Maslov, MS
Junior Control Engineer / Power Pulsed Lab.
Efremov Institute for Electro-Physical Apparatus
St. Petersburg, Russia
Sincerely,
Pavel Maslov, MSc
R&D Institute for Electro-Physical Apparatus
Mobile: +7 (951) 672 22 19
Phone: +7 (812) 461 01 01
John Hammonds
Software Services Group
APS Engineering Support Division
Argonne National Laboratory
[email protected]<mailto:[email protected]>
(630)252-5317
- [help] degree in Computer Science/Software Engineering Pavel Masloff
- Re: [help] degree in Computer Science/Software Engineering Pavel Masloff
- Re: [help] degree in Computer Science/Software Engineering Dirk Zimoch
UPDATE: CA Lab 32/64 Bit (interface between LabVIEW and EPICS) Carsten Winkler
Re: EPICS Base 3.14.12.2-rc1 available for testing Dirk Zimoch
<2011>
Re: gateway Andrew Johnson
<2011>
