On 11/28/11 4:58 PM, Andrew Johnson wrote: > The first release candidate for the 3.14.12.2 version of Base is now available > on the website for general testing. Links to the tarfile and Release Notes > can be found at http://www.aps.anl.gov/epics/base/R3-14/12.php > > Please report any problems you find to tech-talk. If no major issues are > discovered before December 12th we will release 3.14.12.2 on that date. I was able to build successfully on Mac OS X 10.7.2 with ARCH_CLASS = x86_64 using GCC and Clang. Attached are the build logs for GCC and Clang, each of which produced some warning messages. Also attached are the "runtests" logs for the GCC and Clang builds. Both reported "All tests successful" but some test cases printed messages that look abnormal. For example: epicsThreadOnceTest.t ...... 1/11 Recursive epicsThreadOnce() initialization Thread recurse (0x7fd642e00000) can't proceed, suspending. And: macEnvExpandTest.t ......... 1/71 macLib: macro FOO is undefined (expanding string ${FOO}) And: taskwdTest.t ............... 3/8 Thread testTask2 (0x7fdc8c000000) suspended Lewis Attachment:
base-3.14.12.2-rc1-clang.txt.gz Attachment:
base-3.14.12.2-rc1-gcc.txt.gz Attachment:
base-3.14.12.2-rc1-tests-clang.txt.gz Attachment:
base-3.14.12.2-rc1-tests-gcc.txt.gz
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
