Now that you have fixed that record please send the output of
dbpr "record" 10
for all 4 records.
Also send the complete output when you start the IOC.
It does not make sense that dbpr is reporting DPVT=nil if you see the error message, since the error message is printed after DPVT is allocated.
Sent: Mon 11/28/2011 6:33 PM
To: Mark Rivers; [email protected]
Subject: RE: Asyn: "devAsynInt32::initCommon Link must be INST_IO"
Thanks Mark and Eric.
I made the suggested changes to the template file:
record(ao, "KLYS:$(AREA):$(LOCATION):WF_TRIG_DELAY_WRITE") {
field(DESC, "Waveform trigger delay (write)")
field(DTYP, "asynInt32")
field(OUT, "@asyn($(PORT) $(CHANNEL) $(TIMEOUT))WF_TRIG_DELAY_WRITE")
record(ao, "KLYS:$(AREA):$(LOCATION):MOD_TRIG_DELAY_WRITE") {
field(DESC, "Remote modulator trigger delay (write)")
field(OUT, "@asyn($(PORT) $(CHANNEL) $(TIMEOUT))MOD_TRIG_DELAY_WRITE")
record(ai, "KLYS:$(AREA):$(LOCATION):WF_TRIG_DELAY_READ") {
field(DESC, "Waveguide trigger delay (read)")
field(INP, "@asyn($(PORT) $(CHANNEL) $(TIMEOUT))WF_TRIG_DELAY_READ")
field(SCAN, "$(SCAN)")
record(ai, "KLYS:$(AREA):$(LOCATION):MOD_TRIG_DELAY_READ") {
field(DESC, "Remote modulator trigger delay (read)")
field(INP, "@asyn($(PORT) $(CHANNEL) $(TIMEOUT))MOD_TRIG_DELAY_READ")
However, in the previous mksu.template file only the KLYS:$(AREA):$(LOCATION):MOD_TRIG_DELAY_WRITE record had the DTYP/OUT in the wrong order and the error message appeared for all four records.
This is the Makefile section that defines the example.dbd:
DBD += example.dbd
example_DBD += base.dbd
example_DBD += asyn.dbd
example_DBD += drvAsynIPPort.dbd
example_DBD += mksu.dbd
Following the initialization it seems I have an issue when hitting line 181 in the devAsynInt32.c:181. The routine initCommon() is failing on pasinEpicsUtils->parseLink(), which is defined in asynEpicsUtils.c:67. In it the plink->type is 0 (CONSTANT) where I think the correct value would be INST_IO.
The asyn version is 4-14 by the way.
Luciano
-----Original Message-----
Sent: Monday, November 28, 2011 15:57
To: Piccoli, Luciano; [email protected]
Hi Luciano,
I am not sure what is wrong.
You said previously:
> Using gdb I see that they have the link type set to 0 (CONSTANT).
That is not what "dbpr" is showing for your record. It shows
OUT:INST_IO @asyn(Mksu 0 1)WF_TRIG_DELAY_WRITE
That looks correct, as does DTYP.
DTYP: asynInt32
Here are the fields that don't look correct in your record:
DPVT: (nil)
SEVR: <nil>
ASP: (nil)
DPVT is initialized in the initCommon function in
asyn/devEpics/devAsynInt32.c. It allocates that memory before it parses
the link, and parsing the link is where it prints the error message in
your original message. So I don't see how it prints that error message
and still has DPVT=(nil). And I don't understand why it is printing
that error message when dbpr shows the OUT link has the correct syntax.
I suspect a problem with your example.dbd file. How did you create that
file? Does it include all of the asyn dbd stuff?
Here is the output for an ao record with asyn device support for one of
my IOCs. Note that none of the files are are (nil) in your record are
(nil) in mine.
ioc13lab> dbpr "13LAB:tca1SCA1_HI",10
ACKS: NO_ALARM ACKT: YES ADEL: 0 ALST: 0
AOFF: 0 ASG: ASLO: 0 ASP: 0x0
BKPT: 00 DESC: SCA 1 high limit DISA: 0
DISP: 0 DISS: NO_ALARM DISV: 1 DOL:CONSTANT
DPVT: 0x114c108 DRVH: 100 DRVL: 0 DSET:
0x1c7736c
DTYP: asynFloat64 EGU: EGUF: 0 EGUL: 0
EOFF: 0 ESLO: 1 EVNT: 0
FLNK:CONSTANT 0
HHSV: NO_ALARM HIGH: 0 HIHI: 0 HOPR: 100
HSV: NO_ALARM HYST: 0 INIT: 0
IVOA: Continue normally IVOV: 0 LALM: 0
LBRK: 0 LCNT: 0 LINR: NO CONVERSION LLSV:
NO_ALARM
LOLO: 0 LOPR: 0 LOW: 0 LSET:
0xff2fb8
LSV: NO_ALARM MDEL: 0
MLIS: 00 bd b5 78 00 bd b5 78 00 00 00 01 MLOK: 01 2b
e4 50
MLST: 0 NAME: 13LAB:tca1SCA1_HI NSEV:
NO_ALARM
NSTA: NO_ALARM OIF: Full OMOD: 0 OMSL:
supervisory
ORAW: 0 ORBV: 0 OROC: 0
OUT:INST_IO @asyn(icbTca1)HI1 OVAL: 0 PACT: 0
PBRK: 0x0 PHAS: 0 PINI: YES PPN: 0x0
PPNR: 0x0 PREC: 2 PRIO: LOW PROC: 0
PUTF: 0 PVAL: 0 RBV: 0 RDES:
0x1cdf8b0
ROFF: 0 RPRO: 0 RSET: 0x1c7781c RVAL: 0
SCAN: Passive SDIS:CONSTANT SEVR: NO_ALARM
SIML:CONSTANT
SIMM: NO SIMS: NO_ALARM SIOL:CONSTANT SPVT: 0x0
STAT: NO_ALARM TIME: 2011-11-04 11:11:27.320887998 TPRO: 0
TSE: 0 TSEL:CONSTANT UDF: 0 VAL: 0
value = 0 = 0x0
Sent: Monday, November 28, 2011 11:57 AM
Hi Mark,
Here is the info you requested:
epics> asynReport 10
MksuServer multiDevice:No canBlock:Yes autoConnect:Yes
enabled:Yes connected:Yes numberConnects 1
nDevices 0 nQueued 0 blocked:No
asynManagerLock:No synchronousLock:No
exceptionActive:No exceptionUsers 0 exceptionNotifys 0
interposeInterfaceList
asynOctet pinterface 0x68efa0 drvPvt 0x8f70aa8
interfaceList
asynCommon pinterface 0x68e05c drvPvt 0x8f27858
asynOctet pinterface 0x8f278a0 drvPvt 0x8f27858
Port 194.168.0.21:56789 UDP: Connected
fd: 4
Characters written: 0
Characters read: 0
Mksu multiDevice:Yes canBlock:Yes autoConnect:Yes
nDevices 1 nQueued 0 blocked:No
interfaceList
asynCommon pinterface 0x68f12c drvPvt 0x8f70cf8
asynDrvUser pinterface 0x68f204 drvPvt 0x8f70cf8
asynInt32 pinterface 0x68f138 drvPvt 0x8f70cf8
asynInt16Array pinterface 0x68f1b4 drvPvt 0x8f70cf8
addr 0 autoConnect Yes enabled Yes connected No
exceptionActive No
exceptionActive No exceptionUsers 0 exceptionNotifys 0
blocked No
Mksu: missing report - MksuServer
Port: Mksu
Parameter list 0
Number of parameters is: 4
Parameter 0 type=asynInt32, name=WF_TRIG_DELAY_WRITE, value is
undefined
Parameter 1 type=asynInt32, name=MOD_TRIG_DELAY_WRITE, value is
undefined
Parameter 2 type=asynInt32, name=WF_TRIG_DELAY_READ, value is
undefined
Parameter 3 type=asynInt32, name=MOD_TRIG_DELAY_READ, value is
undefined
epics> dbpr KLYS:IN20:3130:WF_TRIG_DELAY_WRITE 10
ALST: 0
(nil)
BKPT: 00 DESC: Waveform trigger delay (write)
DISA: 0
DOL:CONSTANT
DPVT: (nil) DRVH: 0 DRVL: 0
DSET: 0x68f470
DTYP: asynInt32 EGU: EGUF: 0
EGUL: 0
FLNK:CONSTANT 0
HOPR: 0
HSV: NO_ALARM HYST: 0 INIT: 1
LALM: 0
LLSV: NO_ALARM
LSET: 0x8f7d120
MLIS: 00 00 00 00 00 00 00 00 00 00 00 00
MLOK: 40 46 f7 08
MLST: 0 NAME: KLYS:IN20:3130:WF_TRIG_DELAY_WRITE
NSEV: NO_ALARM NSTA: NO_ALARM OIF: Full
OMOD: 0
OMSL: supervisory ORAW: 0 ORBV: 0
OROC: 0
OVAL: 0
PACT: 0 PBRK: (nil) PHAS: 0
PINI: NO
PPN: (nil) PPNR: (nil) PREC: 0
PRIO: LOW
PROC: 0 PUTF: 0 PVAL: 0 RBV:
0
RDES: 0x8f2f7f8 ROFF: 0 RPRO: 0
RSET: 0x25a8e0
RVAL: 0 SCAN: Passive SDIS:CONSTANT
SEVR: <nil>
SIML:CONSTANT SIMM: NO SIMS: NO_ALARM
SIOL:CONSTANT
SPVT: 0x8f74b40 STAT: UDF TIME: <undefined>
TPRO: 0
0
epics>
File mksu.template:
File mksu.substitutions:
file ../../db/mksu.template
pattern
{AREA, LOCATION, PORT, CHANNEL, TIMEOUT, SCAN}
{IN20, 3130, Mksu, 0, 1, "I/O Intr"}
Luciano
Sent: Thursday, November 24, 2011 05:05
Hi Luciano,
Can you send mksu.substitutions and whatever .template or .db files it
loads?
What do you get at the IOC prompt for
asynReport 10
From: [email protected] on behalf of Piccoli, Luciano
Sent: Wed 11/23/2011 5:56 PM
To: [email protected]
Subject: Asyn: "devAsynInt32::initCommon Link must be INST_IO"
I'm writing a simple asyn driver which I started out from the HMS
example. When starting the ioc I get these messages:
lpiccoli@cdlx22 iocMksu]$ ./st.cmd
#! ../../bin/linux-x86/example
dbLoadDatabase("../../dbd/example.dbd")
example_registerRecordDeviceDriver(pdbbase)
drvMksu_init()
drvAsynIPPortConfigure("MksuServer", "194.168.0.21:56789 UDP",
0, 0, 1)
initMksu("Mksu", "MksuServer")
dbLoadTemplate("mksu.substitutions")
iocInit()
Starting iocInit
## EPICS R3.14.10-lcls1 $R3-14-10$ $2008/10/27 19:39:04$
## EPICS Base built Jul 15 2009
KLYS:IN20:3130:MOD_TRIG_DELAY_READ devAsynInt32::initCommon
KLYS:IN20:3130:WF_TRIG_DELAY_READ devAsynInt32::initCommon Link
must be INST_IO
KLYS:IN20:3130:MOD_TRIG_DELAY_WRITE devAsynInt32::initCommon
KLYS:IN20:3130:WF_TRIG_DELAY_WRITE devAsynInt32::initCommon
epics>
It looks like something is not getting set correctly, the link type of
those records should be INST_IO. Using gdb I see that they have the link
Am I missing something in the st.cmd file? Suggestions are welcome :)
Thank you,
Luciano
- RE: Asyn: "devAsynInt32::initCommon Link must be INST_IO" Piccoli, Luciano
- Asyn: "devAsynInt32::initCommon Link must be INST_IO" Piccoli, Luciano
- RE: Asyn: "devAsynInt32::initCommon Link must be INST_IO" Mark Rivers
Re: [help] degree in Computer Science/Software Engineering djquock
<2011>
<2011>
