1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Undefined symbol of devReadProbe and devRegisterAddress
To: [email protected]
Cc: [email protected]
Date: Tue, 22 Nov 2011 13:05:29 -0600
On 2011-11-16 [email protected] wrote:
>  cd topbin
>  value = 0 = 0x0
>  #load epics 3.14.12.1 core
>  ld 0,0, "rapp.munch"
>  Undefined symbol: devReadProbe (binding 1 type 0)
>  Undefined symbol: devRegisterAddress (binding 1 type 0)
>  ld error: Module contains undefined symbol(s) and may be unusable.
>  value = 0 = 0x0
I think this is an indication that you're linking the libraries into your IOC
binary in the wrong order; your device support is the only code that needs the
devLib routines to be present, so you must link libCom *after*  your code that
calls devLib.  The issue is subtle though, see below...
>  After searching tech-talk for reference to solve the problems, I used
>  nmppc and arppc extract devLibVME.o from libCom.a and loaded it before
>  iocCore, but I got more undefined symbol hint. I guess I must have
>  configured some error somewhere, but I can’t find a way yet to solve the
>  problem. Is there any one who can give me some advice? Any comment will be
>  much appreciated.
Doing that won't help, we need to fix this in the Makefile, which you very
helpfully posted.
>  There it is the Makefile of app:
>  # Add all the support libraries needed by this IOC
>  rapp_LIBS_vxWorks += vxStats
>  rapp_LIBS_vxWorks += CaenV812
^^^ These are causing the problem.
>  # Finally link to the EPICS Base libraries
>  rapp_LIBS += $(EPICS_BASE_IOC_LIBS)
Libraries that appear in the target-specific rapp_LIBS_vxWorks variable get
linked *after* libraries from the general rapp_LIBS variable, which contains
libCom and hence the devLib routines that your libCaenV812.a needs.
To fix your problem, change the two lines above that I marked to add those
libraries to the rapp_LIBS variable instead.  You probably used the _vxWorks
variable because those libraries aren't available for your host architecture,
but the correct way to resolve that is to only build the IOC on vxWorks, so
change the line setting PROD_IOC to set PROD_IOC_vxWorks instead.
Alternatively you could link to libCom a second time by adding the line
    rapp_LIBS_vxWorks += Com
anywhere after the other two settings above.  However I would recommend my
other solution as it may prevent other similar problems in the future.
HTH,
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Undefined symbol of devReadProbe and devRegisterAddress housg
Prev: RE: TEMPE_VEAT Exception Szalata, Zenon M.
Next: Re: EPICS stackoverflow site Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Undefined symbol of devReadProbe and devRegisterAddress housg
Next: Re: Undefined symbol of devReadProbe and devRegisterAddress housg
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
