Hi Zen,
On 2011-11-21 Szalata, Zenon M. wrote:
> Now, I load the IOC software, without errors. However, when I enable
> interrupts in the SIS module, for each trigger (gate) I get the following
> error:
> interrupt:
> Clearing VMEbus exception, attrib reg TEMPE_VEAT = 0xc00ccd00
TEMPE_VEAT is the Tsi148 chip's VMEbus Exception Attributes Register, which
stores information about bus errors. You can get the Tsi148 PCI/X-to-VME Bus
Bridge User Manual from Tundra to find the full register definition, but that
particular value means the following:
0x80000000 = VES: Register contains exception data
0x40000000 = VEOF: More exceptions happened after this one
0x00080000 = BERR: It was a bus error
0x00040000 = LWORD* asserted
0x00000000 = not WRITE, so it was a read cycle
0x00000000 = not IACK, so it was a regular I/O operation
0x00008000 = DS1* asserted
0x00004000 = DS0* asserted
0x00000d00 = AM=0x0d, A32 Supervisory data access
There is another register TEMPE_VEAL which would give you the A32 address
where the bus error occurred if you read it.
So basically your code is trying to read a D32 value from an A32 location with
a supervisory AM, but it's not getting any response (or the target is
rejecting an access of that AM or size).
This could have a number of causes, and solving it might need you to change
the configuration of the SIS board, or the BSP's settings of the VME master
windows.
HTH,
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- Re: TEMPE_VEAT Exception Steven M. Hartman
- TEMPE_VEAT Exception Szalata, Zenon M.
Re: StreamDevice: Input "1" does not match format %1r Dirk Zimoch
<2011>
RE: TEMPE_VEAT Exception Szalata, Zenon M.
<2011>
