1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: StreamDevice: Input "1" does not match format %1r
To: [email protected]
Date: Tue, 22 Nov 2011 17:14:47 +0100
Martin Konrad wrote:
Hallo,
I get the following error from StreamDevice (StreamDevice 2.5 with asyn
R4-17 and base 3.14.11):
2011/10/31 14:15:24.807 a1sc01rfamp A1SC01:RFAmp:inStatus: Input "1"
As far as I understand the documentation every one-byte input should
match %1r. So why does StreamDevice complain?
The error message is printed in StreamCore.cc:1314. See the attached
file for debugging output of StreamDevice.
Any help appreciated
Martin
The problem was a mismatch between the record type (stringin) and the data type of the %r converter (integer). I have to improve the error message.
Dirk
StreamDevice: Input "1" does not match format %1r Martin Konrad
Prev: Re: streamdevice problem with 1 byte reply Dirk Zimoch
Next: Re: TEMPE_VEAT Exception Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: StreamDevice: Input "1" does not match format %1r Martin Konrad
Next: last-minute ad-hoc tour in Hawaii? S. Stein
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
