Zhang, Dehong wrote:
For some commands, my device replies with only an "ACK" or "NAK",
no EOS. Streamdevice gets the byte ok, then gets stuck waiting for
more input, but there is no more.
We are "still" using base 3.14.9, asyn 4.10 and streamdevice 2.4.
The replytimeout is set to 900, readtimeout is 100, maxinput is 0.
The problem seems to be asyn not timing out. Could you guys advise
on what I may have missed? Is there a quick fix, instead of upgrading
the whole complex to new versions?
Thanks much and best regards,
Dehong
If a protocol has only ACK as a reply, you can work with maxinput=1 and
no interminator. Interminator and maxinput can both be set on a per
protocol base.
If I understand correctly, none of the replies has a terminator, all
start with ACK (if successful) and probably those which return a value
have a fixed number of characters. Is that correct?
inTerminator="";
simpleCommand {
maxInput=1;
out "command";
in ACK;
readValue {
maxInput=5; # assume 5 char reply: ACK + 4 char int
out "value?";
in ACK "%d";
Dirk
- RE: streamdevice problem with 1 byte reply Zhang, Dehong
- streamdevice problem with 1 byte reply Zhang, Dehong
RE: TEMPE_VEAT Exception Szalata, Zenon M.
Re: StreamDevice: Input "1" does not match format %1r Dirk Zimoch
<2011>
RE: streamdevice problem with 1 byte reply Mark Rivers
<2011>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
