1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: streamdevice problem with 1 byte reply
To: "Zhang, Dehong" <[email protected]>, <[email protected]>
Date: Mon, 21 Nov 2011 16:47:28 -0600
It seems like the right way to fix this is to have your protocol file change the input EOS to ACK or NAK for those commands.
Of course I agree that asyn should be timing out.  What happens when you do asynSetTraceTraceMask=255 on the underlying port driver?  Do you see the read request, and not see it timeout?
Sent: Mon 11/21/2011 4:41 PM
To: [email protected]
Subject: streamdevice problem with 1 byte reply
For some commands, my device replies with only an "ACK" or "NAK",
no EOS.  Streamdevice gets the byte ok, then gets stuck waiting for
more input, but there is no more.
We are "still" using base 3.14.9, asyn 4.10 and streamdevice 2.4.
The replytimeout is set to 900, readtimeout is 100, maxinput is 0.
The problem seems to be asyn not timing out.  Could you guys advise
on what I may have missed?  Is there a quick fix, instead of upgrading
the whole complex to new versions?
Thanks much and best regards,
Dehong
RE: streamdevice problem with 1 byte reply Zhang, Dehong
Prev: streamdevice problem with 1 byte reply Zhang, Dehong
Next: RE: streamdevice problem with 1 byte reply Zhang, Dehong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
