Hi Graham,
On 2011-11-21 [email protected] wrote:
> When using the EPICS_TS_NTP_INET environment variable on a vxWorks 3.14.10
> IOC, issuing the command NTPTime_Report(1) I see the NTP server I am
> synchronised to as my boot server rather than the one specified in
> EPICS_TS_NTP_INET.
> If I then issue an osdNTPInit command, I see NTPTime_Report(1) show correct
> NTP synchronisation with my desired NTP server from EPICS_TS_NTP_INET.
> So, who is responsible for issuing osdNTPInit? Is it called automatically
> during iocInit somehow, or should I be calling it explicitly in my startup
> file?
It is called automatically from a C++ static constructor, so it looks at the
value of the EPICS_TS_NTP_INET variable at the time when the vxWorks ld
command gets run. If you want it to tell it to use a non-default NTP server
you will need to have set the environment variable before your .munch file
gets loaded. We can't wait until iocInit() since other routines such as
driver or device support initialization, dbLoadDatabase() or dbLoadRecords()
need to know the time before then.
HTH,
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- vxWorks NTP Sync graham.cox
undefined symbol when loading EPICS IOC on vxWorks 王林
Software controls position available at W.M. Keck Observatory Kevin Tsubota
<2011>
<2011>
