Andrew,
The MPST setting I needed was "Always".
Kevin
On 11/18/11 10:41 AM, Andrew Johnson wrote:
> Hi Kevin,
> On 2011-11-17 you wrote:
>> I'm using a stringout record and I noticed that it only writes the
>> string to the PV specified in the OUT field when the string changes. I
>> was hoping to change this. I took a look at the stringout fields and
>> noticed two fields that are set to "On Change":
> Looking at the source code the record does call the device support's write
> routine every time it processes. Your dbpr output which I snipped showed that
> you're using Soft Channel device support but the OUT field is empty, so it's
> not actually writing the string value anywhere. However it looks like you
> don't really need it to, and you're really asking about it posting channel
> access monitors instead...
>> Unfortunately I can't find documentation for the APST and MPST fields.
>> I've searched tech-talk, as well as this page (and fields common to all
>> & many record types):
>> http://www.aps.anl.gov/epics/wiki/index.php/RRM_3-14_String_Output
>> Is there a record documentation location I've missed? What do the APST
>> and MPST fields do?
> They control when the record posts CA monitors (MPST => value monitors, APST
> => archive monitors) on the VAL field. For your needs I think you just want
> to set the MPST field to "Every time" (or whatever the choice string actually
> is).
> The APST and MPST fields exist in the aai, aao, stringin and waveform records
> too, but it looks like you're right that no documentation exists to describe
> them. I'm copying this reply to tech-talk in the hope that someone who has a
> wiki account will be willing to add something about them to the
> http://www.aps.anl.gov/epics/wiki/index.php/RRM_3-14_Common "Fields common to
> many record types" and to the pages for those 5 record types.
> - Andrew
- Re: documentation for stringout fields Andrew Johnson
Re: EPICS stackoverflow site J. Lewis Muir
<2011>
vxWorks NTP Sync graham.cox
<2011>
