1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Strip chart in CSS_BOY
To: Josh Stein <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 17 Nov 2011 16:41:23 -0500
On 11/17/11 16:19 , "Josh Stein" <[email protected]> wrote:
>Silly question, but I cannot seem to find a simple way of doing a strip
>chart with BOY. I figured it would be an option under the X-Y plot, but
>fail to find anything. I thought first of using a system PV (like
>sys://time), but that seems restrictive.
>I would like the x-axis to be time; with a user-selectable "depth" to
>the graph.
You currently have two options:
1) Use the Data Browser Widget
Create New Data Browser Plot,
add PV
Set desired axis and time range
Save as *.plt
Add Data Browser Widget to BOY
Set its File Name to the *.plt
++ Can also display archived data
++ PV can be Œmonitored¹, showing brief spikes
-- Fewer display options
2) Use XYGraph Widget
Configure Behavior,
Trigger PV: ³sim://noise²
(This PV updates once a second and will trigger plot updates)
Primary X Axis(0),
Time Format: ³HH:MM:ss²
(To get a "time' axis)
Configure Trace 0,
Trace Type: Step Horizontally,
Update Mode: Trigger,
Y PV: Name of PV to plot
++ Has many more display options
-- Cannot show archived data
-- PV scanned at update rate, can miss brief spikes
Kay
Strip chart in CSS_BOY Josh Stein
Prev: Strip chart in CSS_BOY Josh Stein
Next: EPICS stackoverflow site Abraham Massry
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
