Hi there, I am trying to give value = 1 to a PV (bo) using a boolean button on CSS. When I push the button the action should be write 1 to a PV, but in the Windows IOC it appears the message: "Illegal Choice PV : 'pv name' 1". Why?. I am using AsynPortDriver to use a variable that matchs with the pv. So, I want to use the value of the variable to block / unblock writing parameters in a LLRF register. If user push the boolean, then I send a 1 to a PV and then I write a C++ loop that if the variable is 1 then block parameters. Am I explaining correctly?. Thank you for your
help. Julio Julio.
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
