Hi Jeff,
I am encountering a confused problem about archiving PV provided
by a PCAS. The value of pv can archive once and only once, and after
that although the value of pv has changed, there is only one value in the
channel archiver. It seems that the other values are discarded, and I check the
stutus of the ca connetion, it is ok.
The EPICS base used by the PCAS is 3.14.8.2, I want to know whether the pv
of pcas can archived by Channel
Archiver. The following are ca-test [pv]
outputs:
[zhangyl@timinglinux1 ~]$ ca_test IPV1_REC
native type: DBR_FLOAT
native count: 1
DBR_STRING 99
DBR_SHORT 99
DBR_FLOAT 99.0000
DBR_ENUM 99
DBR_CHAR 99
DBR_LONG 99
DBR_DOUBLE 99.0000
DBR_STS_STRING 3 2 Value: 99
DBR_STS_SHORT 3 2 Value: 99
DBR_STS_FLOAT 3 2 Value: 99.0000
DBR_STS_ENUM 3 2 Value: 99
DBR_STS_CHAR 3 2 Value: 99
DBR_STS_LONG 3 2 Value: 99
DBR_STS_DOUBLE 3 2 Value: 99.0000
DBR_TIME_STRING 3 2 TimeStamp: 2011/11/09 17:15:20.990038 Value: 99
DBR_TIME_SHORT 3 2 TimeStamp: 2011/11/09 17:15:20.990038 Value: 99
DBR_TIME_FLOAT 3 2 TimeStamp: 2011/11/09 17:15:20.990038 Value: 99.0000
DBR_TIME_ENUM 3 2 TimeStamp: 2011/11/09 17:15:20.990038 Value: 99
DBR_TIME_CHAR 3 2 TimeStamp: 2011/11/09 17:15:20.990038 Value: 99
DBR_TIME_LONG 3 2 TimeStamp: 2011/11/09 17:15:20.990038 Value: 99
DBR_TIME_DOUBLE 3 2 TimeStamp: 2011/11/09 17:15:20.990038 Value: 99.0000
DBR_GR_STRING 3 2 Value: 99
DBR_GR_SHORT 3 2
0 0 90 85 15 10 Value: 99
DBR_GR_FLOAT 3 2 0
0.000 0.000 90.000 85.000 15.000 10.000 Value: 99.0000
DBR_GR_ENUM Channel read request failed
DBR_GR_CHAR 3 2
DBR_GR_LONG 3 2
DBR_GR_DOUBLE 3 2 0
DBR_CTRL_STRING 3 2 Value: 99
DBR_CTRL_SHORT 3 2
0 0 90 85 15 10 0 0 Value: 99
DBR_CTRL_FLOAT 3 2 0
0.000 0.000 90.000 85.000 15.000 10.000 0.000 0.000 Value: 99.0000
DBR_CTRL_ENUM Channel read request failed
DBR_CTRL_CHAR 3 2
DBR_CTRL_LONG 3 2
DBR_CTRL_DOUBLE 3 2 0
0.000 0.000 90.000 85.000 15.000 10.000 0.000 0.000 Value: 99.000000
DBR_STSACK_STRING Channel read request failed
DBR_CLASS_NAME Channel read request failed
I noticed that there are Channel read request failed.
Thank you!
Zhang Yuliang
