Thanks, Mark. Will do.
Should I attempt to rebuild EPICS base with this new make.exe prior to trying
to compile/build the example IOC?
Flo
[mailto:[email protected]]
Sent: Tuesday, November 08, 2011 10:33 AM
To: Cid, Florencio A; Ron Sluiter
Cc: [email protected]
Subject: RE: IOC make error
http://cars.uchicago.edu/software/pub/make.gz
gunzip it, and rename it from make to make.exe.
Sent: Tuesday, November 08, 2011 11:28 AM
To: Mark Rivers; Ron Sluiter
Mark,
I tend to agree with you
regarding figuring out why the latest version of Cygwin make is not
working…..
In the meantime, I was wondering
if you could please have a copy of your make.gz. Thought that I
would give it a try.
Flo
Interestingly I see the following:
$ uname -r
1.7.7(0.230/5/3)
$ ls -al /bin/make*
-rwx------+ 1 epics None 495190
2008-05-23 17:48 /bin/make.exe
-rwxr-x---+ 1 epics Users 151552
2008-02-09 13:50 /bin/make.exe.old
-rw-r--r-- 1 rivers mkpasswd 179495 2009-01-12 14:03
/bin/make.gz
So my version of Cygwin is slightly older than yours, 1.7.7
vs 1.7.9. I have the same version of make as you which I am NOT using,
(it is renamed to make.exe.old) and I am using another version that is about 3
times larger. I honestly don’t remember where I got the version that I am
using. But the .gz file expands into the version of make.exe that I am
using. I can make that available if you want, but I think we need to
figure out why the latest version of Cygwin make is not working?
Sent: Tuesday, November 08, 2011 10:26 AM
Mark,
Cgwin version is as follows:
uname -r
1.7.9(0.237/5/3)
Info for /bin/make is as
follows:
ls -al make
-rwxr-xr-x
1 ui495a root 151552 Feb 9 2008 make
Flo
Those are the same settings I am using.
What version of Cygwin are you using? What is the size
and date of your /bin/make.exe?
Sent: Tuesday, November 08, 2011 10:04 AM
Mark,
I’ve set the following in the
file, CONFIG_SITE,
SHARED_LIBRARIES = NO
STATIC_BUILD = YES
Flo
I don’t think that tech-talk message of mine applies any
more. That was an attempt to use the Cygwin version of make to build for
win32-x86. That is not supported, and one should use the GnuWin version
of make to build for win32-x86.
As far as I know the current Cygwin version of make should
work OK to build for the cygwin-x86 architecture, and there is no need to roll
back to an earlier version.
Are you building statically or dynamically?
This tech-talk
entry may fix your problem.
On 11/7/2011 4:42 PM, Cid, Florencio A wrote:
Hello all,
I’ve just installed EPICS base (3.14.12.1) on Windows XP
with Cygwin (EPICS_HOST_ARCH = cygwin-x86). To verify the
installation, I was attempting to building the Example IOC application (per
Section 2.2 of the Application Developer’s Guide).
Unfortunately, I am encountering the following errors upon
attempting to compile:
$ make
make -C
./configure install
make[1]: Entering
directory `/cygdrive/c/mytop/configure'
make -C
O.cygwin-x86 -f ../Makefile TOP=../.. T_A=cygwin-x86 install
make[2]: Entering
directory `/cygdrive/c/mytop/configure/O.cygwin-x86'
perl
c:/EPICS/base/bin/cygwin-x86/convertRelease.pl checkRelease
make[2]: Leaving
make[1]: Leaving
make -C
./myexampleApp install
make[1]: Entering
directory `/cygdrive/c/mytop/myexampleApp'
make -C ./src
install
make[2]: Entering
directory `/cygdrive/c/mytop/myexampleApp/src'
make -C
O.cygwin-x86 -f ../Makefile TOP=../../.. T_A=cygwin-x86 install
make[3]: Entering
directory `/cygdrive/c/mytop/myexampleApp/src/O.cygwin-x86'
c:/EPICS/base/configure/RULES_TARGET:69:
*** multiple target patterns. Stop.
make[3]: Leaving
make[2]: ***
[install.cygwin-x86] Error 2
make[2]: Leaving
make[1]: ***
[src.install] Error 2
make[1]: Leaving
make: ***
[myexampleApp.install] Error 2
Not sure if this is an indication that I have a bad EPICS
base build and/or have something lacking in my environment, etc. Any
help/info/assistance will be greatly appreciated.
Thanks in advance,
Florencio Cid
