Interestingly
I see the following:
uname -r
1.7.7(0.230/5/3)
$ ls -al
/bin/make*
-rwx------+
1 epics None 495190 2008-05-23 17:48 /bin/make.exe
-rwxr-x---+
1 epics Users 151552 2008-02-09 13:50 /bin/make.exe.old
-rw-r--r--
1 rivers mkpasswd 179495 2009-01-12 14:03 /bin/make.gz
So my
version of Cygwin is slightly older than yours, 1.7.7 vs 1.7.9. I have the
same version of make as you which I am NOT using, (it is renamed to
make.exe.old) and I am using another version that is about 3 times larger. I
honestly don’t remember where I got the version that I am using. But the
.gz file expands into the version of make.exe that I am using. I can make that
available if you want, but I think we need to figure out why the latest version
of Cygwin make is not working?
Sent: Tuesday, November 08, 2011
10:26 AM
To: Mark
Rivers; Ron Sluiter
Cc: [email protected]
Subject: RE: IOC make error
Mark,
Cgwin version is as follows:
$ uname -r
1.7.9(0.237/5/3)
Info for /bin/make is as follows:
$ ls -al make
-rwxr-xr-x 1 ui495a root 151552 Feb 9 2008 make
Flo
Those are the same settings I am
using.
What version of Cygwin are you
using? What is the size and date of your /bin/make.exe?
10:04 AM
To: Mark
Rivers; Ron Sluiter
Mark,
I’ve set the following in the
file, CONFIG_SITE,
SHARED_LIBRARIES = NO
STATIC_BUILD = YES
Flo
I don’t think that tech-talk
message of mine applies any more. That was an attempt to use the Cygwin
version of make to build for win32-x86. That is not supported, and one
should use the GnuWin version of make to build for win32-x86.
As far as I know the current Cygwin
version of make should work OK to build for the cygwin-x86 architecture, and
there is no need to roll back to an earlier version.
Are you building statically or
dynamically?
This tech-talk
entry may fix your problem.
On 11/7/2011 4:42 PM, Cid, Florencio A wrote:
Hello all,
I’ve just installed EPICS base (3.14.12.1) on
Windows XP with Cygwin (EPICS_HOST_ARCH = cygwin-x86). To verify
the installation, I was attempting to building the Example IOC application (per
Section 2.2 of the Application Developer’s Guide).
Unfortunately, I am encountering the following errors
upon attempting to compile:
$ make
make -C ./configure
install
make[1]: Entering directory
`/cygdrive/c/mytop/configure'
make -C O.cygwin-x86 -f
../Makefile TOP=../.. T_A=cygwin-x86 install
make[2]: Entering
directory `/cygdrive/c/mytop/configure/O.cygwin-x86'
perl
c:/EPICS/base/bin/cygwin-x86/convertRelease.pl checkRelease
make[2]: Leaving
make[1]: Leaving
directory `/cygdrive/c/mytop/configure'
make -C ./myexampleApp
install
make[1]: Entering
directory `/cygdrive/c/mytop/myexampleApp'
make -C ./src install
make[2]: Entering directory
`/cygdrive/c/mytop/myexampleApp/src'
../Makefile TOP=../../.. T_A=cygwin-x86 install
make[3]: Entering
directory `/cygdrive/c/mytop/myexampleApp/src/O.cygwin-x86'
c:/EPICS/base/configure/RULES_TARGET:69:
*** multiple target patterns. Stop.
make[3]: Leaving
make[2]: ***
[install.cygwin-x86] Error 2
make[2]: Leaving
directory `/cygdrive/c/mytop/myexampleApp/src'
make[1]: ***
[src.install] Error 2
make[1]: Leaving directory
make: ***
[myexampleApp.install] Error 2
Not sure if this is an indication that I have a bad
EPICS base build and/or have something lacking in my environment, etc.
Any help/info/assistance will be greatly appreciated.
Thanks in advance,
Florencio
Cid
