1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: IOC make error
To: "'Cid, Florencio A'" <[email protected]>, "'Mark Rivers'" <[email protected]>, "'Ron Sluiter'" <[email protected]>
Cc: [email protected]
Date: Tue, 8 Nov 2011 09:33:13 -0700
Unfortunately, recent versions of the windows win32-x86 (the native windows port) build of EPICS base appear to be quite sensitive to the version of mingw gnu make. At the codeathon, I actually had to install several versions of mingw gnu make onto my laptop before I found one that worked. I started with the very latest one which didn’t work. As I recall, I rolled back to 3.82 and I actually had to try more than one version of 3.82 before I found one that worked.
I’m not certain if similar issues exist when building cygnus-x86 on windows.
This is what is currently installed, and working on my windows workstation with the win32-x86 build.
C:\hill\epicsInBazaar\cvs-trunk>mingw32-make --version
GNU Make 3.82
Built for i386-pc-mingw32
Copyright (C) 2010  Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Jeff
______________________________________________________
Jeffrey O. Hill           Email
[email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
From: [email protected] [mailto:[email protected]] On Behalf Of Cid, Florencio A
Sent: Tuesday, November 08, 2011 9:04 AM
To: 'Mark Rivers'; Ron Sluiter
Mark,
I’ve set the following in the file, CONFIG_SITE,
SHARED_LIBRARIES = NO
STATIC_BUILD = YES
Flo
Sent: Tuesday, November 08, 2011 8:30 AM
To: Ron Sluiter; Cid, Florencio A
I don’t think that tech-talk message of mine applies any more.  That was an attempt to use the Cygwin version of make to build for win32-x86.  That is not supported, and one should use the GnuWin version of make to build for win32-x86.
As far as I know the current Cygwin version of make should work OK to build for the cygwin-x86 architecture, and there is no need to roll back to an earlier version.
Are you building statically or dynamically?
From: [email protected] [mailto:[email protected]] On Behalf Of Ron Sluiter
Sent: Tuesday, November 08, 2011 9:27 AM
To: Cid, Florencio A
Cc: '[email protected]'
Subject: Re: IOC make error
This tech-talk entry may fix your problem.
On 11/7/2011 4:42 PM, Cid, Florencio A wrote:
Hello all,
I’ve just installed EPICS base (3.14.12.1) on Windows XP with Cygwin (EPICS_HOST_ARCH = cygwin-x86).   To verify the installation, I was attempting to building the Example IOC application (per Section 2.2 of the Application Developer’s Guide).
Unfortunately, I am encountering the following errors upon attempting to compile:
$ make
make -C ./configure install
make[1]: Entering directory `/cygdrive/c/mytop/configure'
make -C O.cygwin-x86 -f ../Makefile TOP=../.. T_A=cygwin-x86 install
make[2]: Entering directory `/cygdrive/c/mytop/configure/O.cygwin-x86'
perl c:/EPICS/base/bin/cygwin-x86/convertRelease.pl checkRelease
make[2]: Leaving directory `/cygdrive/c/mytop/configure/O.cygwin-x86'
make[1]: Leaving directory `/cygdrive/c/mytop/configure'
make -C ./myexampleApp install
make[1]: Entering directory `/cygdrive/c/mytop/myexampleApp'
make -C ./src install
make[2]: Entering directory `/cygdrive/c/mytop/myexampleApp/src'
make -C O.cygwin-x86 -f ../Makefile TOP=../../.. T_A=cygwin-x86 install
make[3]: Entering directory `/cygdrive/c/mytop/myexampleApp/src/O.cygwin-x86'
c:/EPICS/base/configure/RULES_TARGET:69: *** multiple target patterns.  Stop.
make[3]: Leaving directory `/cygdrive/c/mytop/myexampleApp/src/O.cygwin-x86'
make[2]: *** [install.cygwin-x86] Error 2
make[2]: Leaving directory `/cygdrive/c/mytop/myexampleApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/cygdrive/c/mytop/myexampleApp'
make: *** [myexampleApp.install] Error 2
Not sure if this is an indication that I have a bad EPICS base build and/or have something lacking in my environment, etc.  Any help/info/assistance will be greatly appreciated.
Thanks in advance,
Florencio Cid
IOC make error Cid, Florencio A
Re: IOC make error Ron Sluiter
RE: IOC make error Mark Rivers
RE: IOC make error Cid, Florencio A
Prev: RE: IOC make error Cid, Florencio A
Next: RE: IOC make error Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: IOC make error Mark Rivers
Next: About the problem of areaDetector module's compiling and run
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
