Hi All
release 2.1.3 of the sequencer is now (finally) available. This release does
not introduce any new features, it just fixes a number of (indeed shallow)
bugs and incompatibilities. Most of the changes are in snc's lexer, but I
have also fixed a bug in the runtime library and renamed some identifiers in
seqCom.h to enable better interoperability on windows.
As usual, documentation, release notes, download links, and install
instructions can be found on the sequencer homepage:
http://tinyurl.com/epics-seq/
The following is the list of user relevant changes since 2.1.2.
* snc: several more or less necessary changes to the lexer
- make lexer spec compatible with re2c 0.9.9
- run re2c with options -s and -b (for efficiency)
- fixed line marker parsing on windows, so that
error and warning refer to the original source file
- allow whitespace before and after the '#' in line markers
- allow only octal digits in '\ooo' char constants
- replace memcpy with memmove when collecting garbage in the buffer
- read input with stdio, not the low-level io calls;
fix eof and read error handling
- fixed a bug in the lexer that appears
when compiling long source files with many macros
- input and stderr are now unbuffered, output is block buffered;
note that windows does not support line buffering
which was used for stdout and stderr before
- fixed a Big Bad buffer overrun bug in gen_tables.c which caused
snc to crash when fed with programs that
use more than a few hands full of assigned variables
* seq:
- fixed wait for initial connect and monitor
- replaced boolean -> seqBool, bitMask -> seqMask in public interface
(seqCom.h)
* tests:
- added regression test for clean compilation when including windows.h
* docs:
- document 0.9.9 as the minimum re2c version required
* configure:
- made 3.14.12.1 the default base release
Many thanks to Mark Rivers for relentlessly testing compilation with many
existing programs on various platforms.
Cheers
Ben
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführer: Prof. Dr. Anke Rita Kaysser-Pyzalla, Dr. Ulrich Breuer
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
- Re: Announce: sequencer release 2.1.3 Benjamin Franksen
dxp R3-1 Mark Rivers
<2011>
<2011>
