1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: reading large data arrays over slow networks
To: [email protected]
Date: Thu, 03 Nov 2011 16:20:41 -0500
Ron,
Is this the same problem that you and Andrew were looking into last week?
Kevin
On 11/3/11 3:08 PM, Matt Newville wrote:
> Hi,
> I'm seeing an issue with Channel Access getting "large data arrays"
> and hope someone can provide some insight.  First, this is not an
> issue with EPICS_CA_MAX_ARRAY_BYTES, which is set large enough.
> Rather the issue I'm seeing seems to raise the naive question:
>     Once I do a ca_array_get(type, count, chid, pvalue), when can I
> successfully read the data in pvalue?
> That is, how do I know how long to wait in ca_pend_event() and
> ca_pend_io()?    In most cases of a fast network and scalar values or
> small arrays, values on the order of
>    ca_pend_event(1.e-3);
>    ca_pend_io(1.0);
> seem to work well.   But, if the array is "large" or the network
> "slow", I have a hard time predicting these values, and accessing the
> data may give incorrect values unless I've waited "long enough".
> Using either a slow network or pend_event/io times that is clearly
> "too short",  say,
>    ca_pend_event(1.e-5);
>    ca_pend_io(0.01);
> leaves the data at pvalue incorrect (all zeros).  Trying to access
> this data from python, I can get python to segfault for large enough
> data (say, 4.2M ints).  I'm not sure I fully understand why python is
> crashing -- the segfault happens well after ca_array_get() returns,
> but can happen in ca_pend_event() a short time later.  If I save but
> don't try to access the data in pvalue, or wait "long enough", it
> seems I never have a crash.
> Related questions are:  What is supposed to happen if ca_pend_event()
> and/or ca_pend_io() do time out?  and: Is there a way to tell if
> pend_event() or pend_io() have timed out or if there are events that
> are pending?
> I was hoping to be able to do something like
>    ret_ev = ca_pend_event(1.e-3);
>    ret_io = ca_pend_io(1.);
>    while (ret_io == ECA_TIMEOUT) {
> Unfortunately, it seems that checking the return values are not so
> helpful, as pend_event() always(?) returns ECA_TIMEOUT and pend_io()
> seems to return ECA_TIMEOUT no more than one time before returning
> ECA_NORMAL.
> For what it's worth, I'm using base 3.14-12.1.   Thanks in advance for
> any insight.
> --Matt Newville <newville at cars.uchicago.edu> 630-252-0431
reading large data arrays over slow networks Matt Newville
Prev: Re: reading large data arrays over slow networks Andrew Johnson
Next: Re: epicsQt plugin build errors Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: reading large data arrays over slow networks Peter Jemian
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
