> ./debug\CaObject.o:D:\Qt\Qt
> EPICS\epicsqt\ca_framework\plugins-build-desktop/../../../../QtEPICS/epicsqt/ca_framework/api/src/CaObject.cpp:88:
> undefined reference to `epicsEventCreate'
Please make sure that you have something like
LIBS += -L$$(EPICS_BASE)/lib/$$(EPICS_HOST_ARCH) \
-lca \
-lCom \
-L$$(QCAFRAMEWORK)/qwt-5.2.1/lib \
-lqwt
in ca_framework/plugins/QCaDesignerPlugin.pro and double check that
EPICS_BASE, EPICS_HOST_ARCH and QCAFRAMEWORK are set correctly . After
changing the project file try to rebuild from scratch:
cd ca_framework/plugins/
make distclean
qmake
make
> EPICS_BASE=C:\EPICS\base-3.14.8.2
> EPICS_HOST_ARCH=win32-x86
That's enough on my Linux machine.
> And in PATH I added "C:\EPICS\base-3.14.8.2\bin\win32-x86" .
I'm not a Windows developer so please correct me if I'm wrong: If you
later want to run the executable you also have to add
C:\EPICS\base-3.14.8.2\lib\win32-x86 to the search path because the
Windows runtime linker only looks for DLLs in the search path. But this
should not play a role during linking...
Hope that helps
Martin
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel.: +49-6151-16-5121
Fax: +49-6151-16-4321
- Re: epicsQt plugin build errors Andrew Johnson
- epicsQt plugin build errors Zhang Yuliang
RE: reading large data arrays over slow networks Jeff Hill
Re: reading large data arrays over slow networks Andrew Johnson
<2011>
<2011>
