./debug\CaObject.o:D:\Qt\Qt
EPICS\epicsqt\ca_framework\plugins-build-desktop/../../../../QtEPICS/epicsqt/ca_framework/api/src/CaObject.cpp:88:
undefined reference to `epicsEventCreate'
EPICS\epicsqt\ca_framework\plugins-build-desktop/../../../../QtEPICS/epicsqt/ca_framework/api/src/CaObject.cpp:89:
undefined reference to `epicsMutexOsiCreate'
EPICS\epicsqt\ca_framework\plugins-build-desktop/../../../../QtEPICS/epicsqt/ca_framework/api/src/CaObject.cpp:104:
undefined reference to `epicsMutexDestroy'
EPICS\epicsqt\ca_framework\plugins-build-desktop/../../../../QtEPICS/epicsqt/ca_framework/api/src/CaObject.cpp:105:
undefined reference to `epicsEventDestroy'
EPICS\epicsqt\ca_framework\plugins-build-desktop/../../../../QtEPICS/epicsqt/ca_framework/api/src/CaObject.cpp:478:
undefined reference to `dbr_size'
undefined reference to `dbr_value_size'
EPICS\epicsqt\ca_framework\plugins-build-desktop/../../../../QtEPICS/epicsqt/ca_framework/api/src/CaObject.cpp:479:
undefined reference to `ca_name'
collect2: ld returned 1 exit status
mingw32-make[1]: *** [debug\QCaPlugin.dll] Error 1
mingw32-make: *** [debug] Error 2
The process
"C:/Qt/2010.04/mingw/bin/mingw32-make.exe" exited with code %2.
Error while building project plugins (target:
Desktop)
When executing build step 'Make'
In the manual "EPICSQt Developers Guide", it is said
that
undefined references which usually indicate issues with PATH settings. The
environment variable for EPICS in my machine setted as
follows:
EPICS_BASE=C:\EPICS\base-3.14.8.2
EPICS_HOST_ARCH=win32-x86
And in PATH I added
"C:\EPICS\base-3.14.8.2\bin\win32-x86" .
Anything else need to do?
Thank you!
Zhang Yuliang
