Martin,
That rings a bell. If I recall correctly, those records were commented out of base/src/rec/Makefile in some version of base that I was using at some point. Or maybe the records were built, but they weren't included in base/dbd/base.dbd. Something like that. The easiest thing is probably to edit base/src/rec/Makefile and rebuild base.
Tim
----- Original Message -----
To: [email protected]
Sent: Wednesday, October 26, 2011 6:16:18 PM
Subject: StreamDevice 2.5: does not find record type aai
I get an error (see attached file) when I try to build StreamDevice 2.5
against EPICS base (Michael Davidsavers Debian package 3.14.11-8) and
Asyn R4-17. It complains about the record type aai which cannot be found
for the stream device support. If I comment out the lines 15 and 16 in
stream.dbd the build finishes.
Do you have any idea why aai and aao are not found? Everything worked
fine with StreamDevice 2.4.
Cheers
Martin
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel.: +49-6151-16-5121
Fax: +49-6151-16-4321
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
- StreamDevice 2.5: does not find record type aai Martin Konrad
Delta Tau UK - Tech Talk - precision motion for Synchrotron Rings Delta Tau UK
<2011>
RE: StreamDevice 2.5: does not find record type aai Davidsaver, Michael
<2011>
