Hello,
here are the files that are needed to build cagateway with CMake.
Up to now this has been tested for
linux-x86_64 (Ubuntu 11.04)
linux-x86 (Ubuntu 11.10)
Can anybody help testing this stuff with Solaris/Windows/<your OS here>?
@Ralph: Can you add these files to the cagateway repository please?
It's possible to build cagateway on Debian/Ubuntu against Michael
Davidsaver's Debian packages. Just make sure you have epics-pcas-dev
installed.
I still don't understand why casCtx.h is included by cagateway while it
is not installed into the include directory of base. To me this seems to
be a bug either in cagateway or base. Handling this situation becomes
more difficult with 3.15 because the file has been moved to another
directory in this revision. Can someone help to resolve this issue? Does
it make sense to add this file to the include directory in 3.15? This
would make the epics-pcas-dev package unnecessary for 3.15+, too.
Cheers
Martin
P.S.: The path to pcre.h was wrong on my machine (in gateAs.h) - this
works for me:
-#include <pcre/pcre.h>
+#include <pcre.h>
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel.: +49-6151-16-5121
Fax: +49-6151-16-4321
# Find EPICS
# Use as:
# FIND_PACKAGE(EPICS REQUIRED)
# To use a local version first set:
# SET(CMAKE_MODULE_PATH "/somedir/epics/cmake")
# Creates variables:
# EPICS_BASE - Location
# EPICS_FOUND - Where all components found?
# EPICS_INCLUDE_DIRS - CPP search path (global and OS)
# EPICS_Com_LIBRARIES - libCom and dependencies
# EPICS_*_LIBRARY - Individual libs w/o dependencies
# EPICS_HOST_LIBRARIES - All *Host libraries and cas/gdd
# EPICS_IOC_LIBRARIES - All *Ioc libraries
# EPICS_INCLUDE_DIR
# EPICS_OS_INCLUDE_DIR
# EPICS OS classes
# AIX cygwin32 Darwin freebsd
# hpux interix Linux osf RTEMS
# solaris vxWorks WIN32
set(_EPICS_ALL_LIBS
cas gdd asHost dbStaticHost registryIoc
recIoc softDevIoc miscIoc rsrvIoc dbtoolsIoc asIoc
dbIoc registryIoc dbStaticIoc ca Com
find_package(EPICSArch)
include(FindPackageHandleStandardArgs)
find_path(EPICS_BASE
NAMES include/epicsVersion.h
dbd/base.dbd
PATHS /usr/lib/epics
/opt/epics/current
DOC "Location of EPICS Base"
if(NOT EPICS_BASE)
if(EPICS_FIND_REQUIRED)
message(FATAL_ERROR "Failed to find EPICS Base location")
endif(EPICS_FIND_REQUIRED)
endif(NOT EPICS_BASE)
find_path(EPICS_INCLUDE_DIR epicsVersion.h
PATHS ${EPICS_BASE}/include
DOC "EPICS include dir"
NO_DEFAULT_PATH
if(EPICS_INCLUDE_DIR)
find_path(EPICS_OS_INCLUDE_DIR
NAMES epicsMath.h osdTime.h osiUnistd.h
PATHS ${EPICS_INCLUDE_DIR}/os/
PATH_SUFFIXES ${OS_CLASS}
DOC "EPICS OSD include dir"
NO_DEFAULT_PATH
if(EPICS_OS_INCLUDE_DIR)
SET(EPICS_INCLUDE_DIRS
${EPICS_OS_INCLUDE_DIR}
endif(EPICS_OS_INCLUDE_DIR)
endif(EPICS_INCLUDE_DIR)
if(EPICS_INCLUDE_DIR AND EPICS_OS_INCLUDE_DIR)
foreach(COMP ${_EPICS_ALL_LIBS})
find_library(EPICS_${COMP}_LIBRARY ${COMP}
PATHS ${EPICS_BASE}/lib
PATH_SUFFIXES ${T_A}
NO_DEFAULT_PATH
DOC "Location of the EPICS ${COMP} library"
endforeach(COMP)
endif(EPICS_INCLUDE_DIR AND EPICS_OS_INCLUDE_DIR)
# Ensure all components are present if needed
# When find_package() is invoked with REQUIRED
# ensure that all of the following are set
find_package_handle_standard_args(EPICS DEFAULT_MSG
EPICS_BASE
EPICS_INCLUDE_DIR EPICS_OS_INCLUDE_DIR
EPICS_Com_LIBRARY
EPICS_ca_LIBRARY
EPICS_cas_LIBRARY
EPICS_gdd_LIBRARY
EPICS_asHost_LIBRARY
EPICS_dbStaticHost_LIBRARY
EPICS_registryIoc_LIBRARY
EPICS_recIoc_LIBRARY
EPICS_softDevIoc_LIBRARY
EPICS_miscIoc_LIBRARY
EPICS_rsrvIoc_LIBRARY
EPICS_dbtoolsIoc_LIBRARY
EPICS_asIoc_LIBRARY
EPICS_dbIoc_LIBRARY
EPICS_dbStaticIoc_LIBRARY
set(EPICS_Com_LIBRARIES ${EPICS_Com_LIBRARY})
#TODO: error checking below
if(NOT RTEMS)
find_package(Threads REQUIRED)
list(APPEND EPICS_Com_LIBRARIES ${CMAKE_THREAD_LIBS_INIT})
endif(NOT RTEMS)
if(UNIX AND NOT RTEMS)
find_library(LIBRT rt)
find_library(LIBDL dl)
list(APPEND EPICS_Com_LIBRARIES ${LIBRT} ${LIBDL})
endif(UNIX AND NOT RTEMS)
if(RTEMS)
find_library(RTEMSCPU rtemscpu)
find_library(RTEMSNFS nfs)
list(APPEND EPICS_Com_LIBRARIES ${RTEMSCPU} ${RTEMSNFS})
if(RTEMS_NEED_BSPEXT)
find_library(BSPEXT bspExt)
list(APPEND EPICS_Com_LIBRARIES ${BSPEXT})
endif(RTEMS_NEED_BSPEXT)
endif(RTEMS)
# Libraries needed to build an IOC
set(EPICS_BASE_IOC_LIBS
${EPICS_recIoc_LIBRARY}
${EPICS_softDevIoc_LIBRARY}
${EPICS_miscIoc_LIBRARY}
${EPICS_rsrvIoc_LIBRARY}
${EPICS_dbtoolsIoc_LIBRARY}
${EPICS_asIoc_LIBRARY}
${EPICS_dbIoc_LIBRARY}
${EPICS_registryIoc_LIBRARY}
${EPICS_dbStaticIoc_LIBRARY}
${EPICS_ca_LIBRARY}
${EPICS_Com_LIBRARIES}
set(EPICS_INSTALL_BIN "bin/${T_A}" CACHE FILEPATH "Location for installed binaries")
set(EPICS_INSTALL_LIB "lib/${T_A}" CACHE FILEPATH "Location for all libraries")
set(EPICS_INSTALL_INCLUDE "include" CACHE FILEPATH "Location for C/C++ headers")
set(EPICS_INSTALL_INCLUDE_OS "include/os/${OS_CLASS}" CACHE FILEPATH "Location for OSD C/C++ Headers")
set(EPICS_INSTALL_DBD "dbd" CACHE FILEPATH "Location for EPICS DBD files")
set(EPICS_INSTALL_DB "db" CACHE FILEPATH "Location for EPICS DB files")
mark_as_advanced(
EPICS_BIN_DIR EPICS_LIB_DIR
EPICS_DBD_DIR EPICS_DB_DIR
EPICS_CMAKE_DIR
# Determine EPICS Arch and OS Class
# Use as:
# find_package(EPICSArch)
# T_A - Target Archetecture
# OS_CLASS - Primary (first) OSI system class
# OS_CLASSES - List of all OSI classes
# IOC - True if target can build IOC things
# HOST - True if target can build Host things
include(FindPackageMessage)
if(UNIX)
if(CMAKE_SYSTEM_NAME MATCHES Linux)
set(HOST 1)
set(IOC 1)
set(OS_CLASS Linux)
set(OS_CLASSES Linux posix default)
if(CMAKE_SYSTEM_PROCESSOR MATCHES "^i.86$")
set(T_A "linux-x86")
elseif(CMAKE_SYSTEM_PROCESSOR MATCHES "^x86_64$")
set(T_A "linux-x86_64")
elseif(CMAKE_SYSTEM_PROCESSOR MATCHES "^powerpc")
set(T_A "linux-ppc")
else(CMAKE_SYSTEM_PROCESSOR MATCHES "^i.86$")
message(FATAL_ERROR "Unknown Linux Variant: ${CMAKE_SYSTEM_PROCESSOR}")
endif(CMAKE_SYSTEM_PROCESSOR MATCHES "^i.86$")
elseif(RTEMS)
set(HOST 0)
set(IOC 1)
set(OS_CLASS RTEMS)
set(OS_CLASSES RTEMS posix default)
set(T_A "RTEMS-${RTEMS_BSP}")
else(CMAKE_SYSTEM_NAME MATCHES Linux)
message(FATAL_ERROR "Unknown *nix Variant: ${CMAKE_SYSTEM_NAME}")
endif(CMAKE_SYSTEM_NAME MATCHES Linux)
elseif(WIN32)
set(HOST 1)
set(IOC 1)
set(OS_CLASS WIN32)
set(OS_CLASSES WIN32 default)
if(MINGW)
set(T_A "win32-x86-mingw")
elseif(CYGWIN)
set(T_A "win32-x86-cygwin")
elseif(MSVC)
set(T_A "win32-x86")
elseif(BORLAND)
set(T_A "win32-x86-borland")
else(MINGW)
message(FATAL_ERROR "Unknown Windows variant")
endif(MINGW)
else(UNIX)
message(FATAL_ERROR "Unable to determine EPICS OS class")
endif(UNIX)
if(CMAKE_BUILD_TYPE STREQUAL "Debug")
set(T_A "${T_A}-debug")
endif(CMAKE_BUILD_TYPE STREQUAL "Debug")
find_package_message(EPICSArch
"EPICS Target: ${T_A} (${OS_CLASS})"
"[${T_A}][${OS_CLASS}]"
# Martin Konrad <[email protected]>
# License: GPLv2/v3
# Try to find libpcre (Perl Compatible Regular Expressions)
# Once done this will define
# PCRE_FOUND - system has libpcre
# PCRE_INCLUDE_DIR - the libpcre include directory
# PCRE_LIBRARY - where to find libpcre
# PCRE_LIBRARIES - Link these to use libpcre
if(PCRE_INCLUDE_DIR AND PCRE_LIBRARIES)
# in cache already
set(LIBUSB_FOUND TRUE)
else(PCRE_INCLUDE_DIR AND PCRE_LIBRARIES)
if(NOT WIN32)
# use pkg-config to get the directories and then use these values
# in the FIND_PATH() and FIND_LIBRARY() calls
find_package(PkgConfig)
pkg_check_modules(PC_PCRE libpcre)
endif(NOT WIN32)
find_path(PCRE_INCLUDE_DIR
NAMES
pcre.h
HINTS
${PCRE_PKG_INCLUDE_DIRS}
PATHS
/usr/include
/usr/local/include
find_library(PCRE_LIBRARY
NAMES
pcre
HINTS
${PCRE_PKG_LIBRARY_DIRS}
PATHS
/usr/lib
/usr/local/lib
set(PCRE_LIBRARIES ${PCRE_LIBRARY})
# handle the QUIETLY AND REQUIRED arguments AND set PCRE_FOUND to TRUE if
# all listed variables are TRUE
# include(${CMAKE_CURRENT_LIST_DIR}/FindPackageHandleStandardArgs.cmake)
find_package_handle_standard_args(PCRE DEFAULT_MSG PCRE_LIBRARY PCRE_INCLUDE_DIR)
mark_as_advanced(PCRE_INCLUDE_DIR PCRE_LIBRARY)
endif(PCRE_INCLUDE_DIR AND PCRE_LIBRARIES)
Using CMake instead of the classical EPICS build environment is recommended to build CA gateway.
BUILDING:
To build cagateway using CMake run the following commands in the top level directory of CA gateway:
mkdir build
cd build/
cmake ..
make
If you want to change the defaults (e.g. use the perl compatible regular expression library) you can use either
cmake -DUSE_PCRE ..
or you can use ccmake/cmake-gui to adjust the options in an interactive manner.
PACKAGING:
After building the project you can create Debian and RPM packages by entering:
make package
If you want only a deb file use
cpack -G DEB
instead, if you only want a RPM file say
cpack -G RPM
cmake_minimum_required(VERSION 2.8 FATAL_ERROR)
project(epics-cagateway)
set(VERSION_MAJOR 2)
set(VERSION_MINOR 0)
set(VERSION_MAINTENANCE 4)
set(VERSION_BUILD 0)
set(VERSION_STRING "${VERSION_MAJOR}.${VERSION_MINOR}.${VERSION_MAINTENANCE}.${VERSION_BUILD}")
set(gateway_SRCS
gateway.cc
gateAsCa.cc
gateAs.cc
gateAsyncIO.cc
gatePv.cc
gateResources.cc
gateServer.cc
gateStat.cc
gateVc.cc
set(CMAKE_MODULE_PATH "${CMAKE_SOURCE_DIR}")
find_package(EPICS REQUIRED ca cas asHost gdd Com)
include_directories(${EPICS_INCLUDE_DIRS})
set(CMAKE_CXX_FLAGS "-Dlinux -O3 -Wall")
option(NODEBUG "Turn off Gateway debug calls" OFF)
if(NODEBUG)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -DNODEBUG")
endif(NODEBUG)
option(STAT_PVS "Use status PVs" ON)
if(STAT_PVS)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -DSTAT_PVS")
endif(STAT_PVS)
option(RATE_STATS "Use rate statistics" ON)
if(RATE_STATS)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -DRATE_STATS")
endif(RATE_STATS)
option(CONTROL_PVS "Use control PV's" ON)
if(CONTROL_PVS)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -DCONTROL_PVS")
endif(CONTROL_PVS)
option(HEARTBEAT_PV "Use heartbeat PV" OFF)
if(HEARTBEAT_PV)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -DHEARTBEAT_PV")
endif(HEARTBEAT_PV)
option(CAS_DIAGNOSTICS "Use CAS diagnostics statistics" ON)
if(CAS_DIAGNOSTICS)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -DCAS_DIAGNOSTICS")
endif(CAS_DIAGNOSTICS)
option(HANDLE_EXCEPTIONS "Install exception handler and print exceptions to log file" ON)
if(CAS_DIAGNOSTICS)
option(USE_DENYFROM "Use deny from" YES)
if(USE_DENYFROM)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -DUSE_DENYFROM")
endif(USE_DENYFROM)
option(USE_NEG_REGEXP "Use neg regexp" ON)
if(USE_NEG_REGEXP)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -DUSE_NEG_REGEXP")
endif(USE_NEG_REGEXP)
option(USE_PCRE "Use Perl compatible regular expressions" OFF)
if(USE_PCRE)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -DUSE_PCRE")
find_package(PCRE REQUIRED)
endif(USE_PCRE)
add_executable(gateway ${gateway_SRCS})
target_link_libraries(gateway ${EPICS_Com_LIBRARY} ${EPICS_HOST_LIBRARIES} ${EPICS_ca_LIBRARY} ${EPICS_asHost_LIBRARY} ${EPICS_cas_LIBRARY} ${EPICS_gdd_LIBRARY} ${PCRE_LIBRARIES})
# Package information
set(CPACK_PACKAGE_VERSION ${VERSION_STRING})
set(CPACK_PACKAGE_CONTACT "Martin Konrad <[email protected]>")
set(CPACK_PACKAGE_DESCRIPTION "Channel access gateway for EPICS\n The Experimental Physics and Industrial Control System is a collection of tools, libraries and applications for creating a distributed soft real-time control system.\n .\n This package provides the EPICS channel access gateway. It acts as a kind of proxy for channel access and therefore allows clients to access IOCs in other subnets. In addition to that it provides channel access security.")
set(CPACK_DEBIAN_PACKAGE_HOMEPAGE "http://www.aps.anl.gov/epics/extensions/gateway/")
set(CPACK_DEBIAN_PACKAGE_DESCRIPTION ${CPACK_PACKAGE_DESCRIPTION})
set(CPACK_DEBIAN_PACKAGE_DEPENDS "libepics3.14.11 (>=3.14.11)")
if(USE_PCRE)
set(CPACK_DEBIAN_PACKAGE_DEPENDS "${CPACK_DEBIAN_PACKAGE_DEPENDS}, libpcre3")
endif(USE_PCRE)
# Package settings
if(${UNIX})
set(CPACK_GENERATOR "DEB;RPM")
set(CPACK_CMAKE_GENERATOR "Unix Makefiles")
set(CPACK_PACKAGE_NAME ${PROJECT_NAME})
set(CPACK_PACKAGE_FILE_NAME ${PROJECT_NAME}-${VERSION_STRING}${PACK_ARCH})
endif(${UNIX})
install(TARGETS gateway DESTINATION bin)
install(DIRECTORY docs/ DESTINATION share/doc/${PROJECT_NAME} PATTERN ".svn" EXCLUDE)
include(CPack)
- Re: cagateway: building with CMake, creating Debian/RPM packages Ralph Lange
EZCA and ezcaIDL improvements? Mark Rivers
<2011>
RE: EZCA and ezcaIDL improvements? Mark Rivers
<2011>
